Go Back   Toyota GR86, 86, FR-S and Subaru BRZ Forum & Owners Community - FT86CLUB > 2nd Gens: GR86 and BRZ > BRZ Second-Gen (2022+) — General Topics
BRZ Second-Gen (2022+) — General Topics General topics for the second-gen BRZ
Old 12-12-2021, 11:47 PM   #15
DeeAich
Drives: '22 BRZ
Originally Posted by Yoshoobaroo View Post
That’s a problem with your phone, CarPlay streams all assets from the phone.
Too bad, the Aussie woman is usually on point, I'll have to try someone else.
Originally Posted by azndavepgh View Post
That bothered me initially, but now I'm getting used to it.
Yeah, I find myself just driving with the doors unlocked
DeeAich is offline   Reply With Quote
Old 12-13-2021, 12:00 AM   #16
eyeballs
Drives: '22 BRZ
I'll say it again...that frickin center console. My elbow opens it up nearly every drive.
eyeballs is offline   Reply With Quote
The Following User Says Thank You to eyeballs For This Useful Post:
funwheeldrive (12-13-2021)
Old 12-13-2021, 12:06 AM   #17
Scubadriver
Drives: 2022 BRZ Limited
Originally Posted by 22 BRZ View Post
Yup, and there is a little graphic in the manual that explains it for anyone who is curious. This is how I've found it working:
- Left button pressed once turns off only TC, and only up to 50 km/h, and the VSC will still clamp down if you slide too far/fast.
- Right button pressed once puts everything in track mode (so the TC and VSC will still engage to a point, and I think I can still feel the brake LSD a bit).
- Left button held down turns everything off, including the brake LSD, but leaves the ABS on.
So sort of three different levels depending on how you want it.
So does this mean pedal dance is no longer required for track?
Scubadriver is offline   Reply With Quote
Old 12-13-2021, 02:59 AM   #18
timurrrr
timurrrr's Avatar
Drives: 2022 GR86
Mandatory link to the "other quirks and features"
The Following User Says Thank You to timurrrr For This Useful Post:
Old 12-13-2021, 04:22 AM   #19
22 BRZ
22 BRZ's Avatar
Drives: 2022 Subaru BRZ 6MT IR
Sorry, that answer is a bit beyond me. I never had a gen 1 car, and I'm not versed enough in electronic brake force distribution to understand whether the "off mode" changes that. My butt dyno tell me that I've felt the brake LSD in track mode, but not in "off" mode. However, that was only after I read the manual and did some investigation, so I could be interpreting more than is there.
2022 BRZed, Red, Base, Manual, Simple
22 BRZ is offline   Reply With Quote
Old 12-13-2021, 10:14 AM   #20
Interceptor777
Interceptor777's Avatar
Drives: 2022 BRZ, 1999 "touge-spec" Miata
According to the manual, it should not be required (if it even still works). The TC Off button seems to actually turn everything off.
Interceptor777 is offline   Reply With Quote
Old 12-13-2021, 11:32 AM   #21
Varelco
Drives: '15 GT86 & '22 GR86
For all the limited owners out there. Heated seats... how are they? Over here in the UK the first gen heated seats were next to useless.
Varelco is offline   Reply With Quote
Old 12-13-2021, 11:59 AM   #22
Interceptor777
The high setting is VERY strong. I use the high setting for the initial warm up and then low setting to keep the seat warm but even then it does get too warm sometimes.
The Following 2 Users Say Thank You to Interceptor777 For This Useful Post:
Pete (12-13-2021), Varelco (12-14-2021)
Old 12-13-2021, 12:26 PM   #23
Pete
Pete's Avatar
Drives: 22 BRZ
True story, I have renamed them "the assburners".
2013 FRS -> 2011 CTS-V -> 2006 Cayman S -> 2015 GTI -> 2022 BRZ
Pete is offline   Reply With Quote
Old 12-13-2021, 12:58 PM   #24
imLawZ
Drives: 2022 BRZ WRB
The back seats are much less usable this gen than the 1st gen.
Last gen, I was able to use the back seats (not often) in a pinch to carry two passengers on a short drive. Yesterday, I tried doing the same thing with the same two passengers on the 2nd gen but there was absolutely no room (seats seem to be bigger?)
imLawZ is offline   Reply With Quote
The Following 2 Users Say Thank You to imLawZ For This Useful Post:
DarkSunrise (12-13-2021), funwheeldrive (12-13-2021)
Old 12-13-2021, 01:59 PM   #25
sds
Drives: '22 BRZ Limited 6MT
I think the space under the seat is also shallower which effectively limits legroom. Regardless, it's not great at all...
sds is offline   Reply With Quote
Old 12-13-2021, 02:49 PM   #26
StE92ve
StE92ve's Avatar
Drives: 2014 Mazda CX-5
Originally Posted by tenderization View Post
Too many posts seem to be oriented towards how the car drives without enough thought towards inane documentation of the quirks and features.
the homelink garage door opener doesn't get power unless the ignition is on (not just ACC). A bit annoying as I'm used to killing the engine as soon as the car's in the garage to avoid fumigating the house (more of a problem with the RX-7 but still).
Maybe the battery operated homelink in the GR86 has an advantage here as power would always be on. But, I don't see the BRZ homelink as a disadvantage since I always close the garage door with the wall mounted remote once I'm out of the car.
Originally Posted by DeeAich View Post
Also, not a fan of the door locks. I feel they should auto-lock on drive away and unlock on shut off.
There's not a setting in the infotainment menu to change this?
StE92ve is offline   Reply With Quote
Old 12-13-2021, 03:11 PM   #27
dragoontwo
dragoontwo's Avatar
Drives: 22 BRZ limited
Not on the MT, maybe on the AT.
Old 12-13-2021, 05:16 PM   #28
OkieSnuffBox
Drives: '23 BRZ Limited
What is the "brake LSD?"
The Following User Says Thank You to OkieSnuffBox For This Useful Post:
Pete (12-13-2021)
BRAINDUMP - FT86 Quirks, common fixes and when things need upgrading Aztec Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 6 08-28-2015 06:44 PM
Magazine features crouchy35 AUSTRALIA 1 06-03-2013 06:59 PM
Interesting features on the FR-S... Senzai Scion FR-S / Toyota 86 GT86 General Forum 59 05-08-2013 05:41 PM
Strange Quirks Aznek Scion FR-S / Toyota 86 GT86 General Forum 30 08-15-2012 10:40 AM
FR-S Standard Features zAnSh1n Scion FR-S / Toyota 86 GT86 General Forum 182 04-04-2012 05:23 PM
