Old 12-09-2021, 12:13 AM   #1
IamKevin2
Drives: 2017 Toyota 86
Tires Options for Rays 57cr
yo, I am new here and new to cars in general so my knowledge is little. I’ve been doing some research to find tires to go with the rays 57cr. Idk what’s good and what’s not. So I am looking for a some daily driving tires, and am in need of a recommendation. Budget is okay, but I don’t want to go over $800. some tires I’ve been told is landsail, fire hawk, BF Goodrich comp 2, and I found some toyo proxey. Are these options nice? What other options can I look at
IamKevin2 is offline   Reply With Quote
Old 12-09-2021, 10:21 AM   #2
ZDan
ZDan's Avatar
Drives: '23 BRZ
What size wheels?
Go to www.tirerack.com to see how different tires compare. Best tire depends on your wants/needs/usage envelope. Dry grip, wet grip, cold/snow grip, desired life, feel/handling, noise, comfort, etc.
Based on yer location and "daily driving", look in the "Ultra High Performance" or "Max Performance" categories. Maybe "Ultra High Performance All Season" if you even *might* drive somewhere cold/snowy.
I wouldn't bother with "Landsail"! Stick with known good major brands.
Old 12-09-2021, 12:25 PM   #3
RToyo86
RToyo86's Avatar
Drives: 17 Asphalt 86
Indy 500s are a good budget summer tire. They don't have the best all around performance like the top tier UHP tires. PS4s, ECS.
Road noise and wear will vary too.
I got some dirt cheap yoko advan sport V105. Not sure if I trashed them due to toe out but road noise is loud. Much louder than PS4S I ran previously.
Need wheel width for tires. Assuming they're 17x9 a 245/40R17 is go to size and fits nicely.
Old 12-09-2021, 02:17 PM   #4
Westen86
Purist
Westen86's Avatar
Drives: 2013 FRS - Hot Lava
https://www.tyrereviews.com/
WTB: Everything Verus
RaceComp SS-1, Complete SuperPro bushings, TR Motorsport FF10 17x9 +45, GruppeS UEL, HKS Hi-Power V2, OFT(93/E85)
Westen86 is offline   Reply With Quote
Old 12-09-2021, 04:00 PM   #5
IamKevin2
Originally Posted by ZDan View Post
What size wheels?
Wheel size I’m probably gonna get 18x9.5 +22
Old 12-09-2021, 05:50 PM   #6
ZDan
ZDan's Avatar
Drives: '23 BRZ
You might want to reconsider that size/offset! Unless you have cutout arches and flares, you're going to poke and rub like crazy... Do they come in +35 offset? That should work with 245/35-18s, if you have some negative camber... Is car lowered and if so how much?
Old 12-09-2021, 08:31 PM   #7
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
Why? Typical wheel size is 17X9 +38 in the 57CR for this platform. It will get you closeish to flush front and rear, and gives enough strut clearance. It also gives you a lot of reasonable priced tires in 245/40/17.
Firehawk Indy in 245/40/17 is 160 on TR. 245/35/18 is 200 for the same tire.
The Following 2 Users Say Thank You to NoHaveMSG For This Useful Post:
GPhilly (02-01-2022), ZDan (12-09-2021)
Old 12-09-2021, 11:49 PM   #8
IamKevin2
Idk tbh, that was the size I was gonna go with some Kansei KNPs but I decided to get rays instead , and thought going with the same size would be nice
Old 12-09-2021, 11:50 PM   #9
IamKevin2
They come in a +38, +22, +12 offset
Old 12-09-2021, 11:57 PM   #10
whataboutbob
AutoX-10/10ths every run
Start here to determine what size/offsets are known to work for wheels: https://www.ft86club.com/forums/showthread.php?t=7535
Build thread:Here
Old 12-10-2021, 12:02 AM   #11
ZDan
ZDan's Avatar
Drives: '23 BRZ
For sure you want +38, unless you have cut fenders/widebody/etc.
Also if dragstrip performance is a priority you might think about smaller diameter wheels so you can run taller sidewall tires.
Old 12-10-2021, 12:31 AM   #12
IamKevin2
Oh man this is a lot of information
Old 12-10-2021, 12:31 AM   #13
IamKevin2
Alright bet thanks
The Following User Says Thank You to IamKevin2 For This Useful Post:
whataboutbob (12-10-2021)
Old 12-10-2021, 12:42 AM   #14
ZDan
ZDan's Avatar
Drives: '23 BRZ
You are on the right track, research first, then commit...
WTB: RAYS 57CR Gold Clark20 Want-To-Buy Requests 0 02-14-2020 08:25 PM
FS:[IL/WI] RAYS Engineering 57CR 18x9.5 EDP | NEW IN BOX BanditKeith Wheels and Tires 2 01-24-2020 08:24 PM
Rays Gram Light 57CR - ALL NEW COLORS FT-86 SpeedFactory Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 27 04-05-2018 06:41 PM
RAYS Gram Light 57CR DesertLava Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 4 12-26-2017 12:55 PM
New Rays Gram Lights 57CR - ALL NEW COLORS FT-86 SpeedFactory Wheels and Tires 3 08-07-2017 10:45 AM
