Old 12-09-2021, 10:06 AM   #197
Irace86.2.0
Irace86.2.0's Avatar
Drives: Q5 + BRZ + M796
Originally Posted by Ebush View Post
I cut that fuel hard well, but I actually capped it so that nothing gets in or out. Didn’t realize it was just some sort of vent. I’ve ran a few tanks of gas through the car so far and haven’t had any issues.
Yeah, it is the EVAP purge that would normally draw fuel vapors from the charcoal canister to the intake manifold when the solenoid opens, and I believe it opens when it gets a signal that pressure has reached a certain threshold or when a certain period has elapsed. I know people have vented them to atmosphere and capped them with no smell or issues. If your car sits for a long time between refueling then there is probably more risk of having a pressurized gas cap. Moisture probably can’t get in because there are two charcoal canisters, which is also why smells don’t get out.
Like I said, I attached a rubber hose and vented it to atmosphere.
The other thing I did was cut the hard line on the pulled fuel line and created a piece that can stick down into a gas jug. I need to empty and dispose of the E85 that’s been sitting in the gas tank. Once everything is hooked up, I should be able to turn on the accessories to activate the pump and clear out the gas, and then I can use the Kpower plug to cap that line. Probably a cleaner and simpler method than trying to use the existing line in the engine bay.
The Following 2 Users Say Thank You to Irace86.2.0 For This Useful Post:
captain awesome (12-09-2021), Ebush (12-09-2021)
Old 12-09-2021, 10:32 AM   #198
captain awesome
Wears Pants
Drives: 14 FRS K24 swap - SOLD
I'm almost on E so it may be time to pull the tanks and remove all of that as well.
captain awesome is offline   Reply With Quote
Old 12-09-2021, 12:22 PM   #199
Irace86.2.0
I will leave it. Less weight would be nice, but it isn’t worth the effort, and the charcoal canisters should absorb most of the emissions and odors.
Old 12-09-2021, 12:39 PM   #200
captain awesome
Wears Pants
If it's venting to atmosphere how is there any emissions or odors getting into it?
Old 12-09-2021, 02:47 PM   #201
Irace86.2.0
Not into it. Out of it. Dirt and moisture/water vapor can get into it.
Unless I am confused, the EVAP system purges gases from the gas tank. Evaporating gas would normally vent to atmosphere, which isn’t good, but just creating a closed system with an air-tight gas cap would cause pressure to build, especially in the heat, so that isn’t good either. This could be bad for seals, and it could cause pressure to rapidly escape when the gas cap is removed. The EVAP system filters and purges the pressure to the intake manifold to be burned.
I think if you remove everything and cap the system then that means you should burb the system or leave the gas cap off during storage for a long time, but regular and frequent fill-ups should relieve the pressure. If it is vented without the charcoal system then there may be odors and more emissions and potentially more opportunity for moisture and dirt to get in the tank. I don’t know how much of a risk there is in either way. I figured I would vent, but leave the particulates.
Old 12-09-2021, 03:05 PM   #202
captain awesome
Wears Pants
I think you are right. Honestly dropping the tanks doesn't sound like fun anyway.
The Following User Says Thank You to captain awesome For This Useful Post:
Irace86.2.0 (12-09-2021)
Old 12-10-2021, 12:43 AM   #203
Irace86.2.0
I finished the driver's side of the engine bay, besides a few details that will need to wait until the rest is complete. For instance, I hooked up the vacuum lines, but I need to finish the BOV/IC pipes before I can route the line. Stuff like that.
The clearance on the intake and TB is fine. I should be able to fabricate a 3'' IC pipe that will clear the hood and route around everything.
Speaking of clearance, the hood and TB do touch the hood insulation pad. Hopefully it isn't a problem.
The Following 4 Users Say Thank You to Irace86.2.0 For This Useful Post:
Dadhawk (12-10-2021), DustinS (12-10-2021), kask2_6.0 (12-11-2021), ML (12-10-2021)
Old 12-10-2021, 08:53 AM   #204
spcmafia
spcmafia's Avatar
Drives: 2018 Subaru BRZ
That top cover is a thing of beauty.
spcmafia is offline   Reply With Quote
The Following User Says Thank You to spcmafia For This Useful Post:
Irace86.2.0 (12-10-2021)
Old 12-11-2021, 12:21 AM   #205
Irace86.2.0
Why didn't anyone tell me I'm an idiot? I can't flip the wastegate down. If I do there then it won't work well. It needs to be 90 degrees at worst, but preferentially, it needs to go in the same direction as exhaust flow, and it must not go against the flow, so I'll have to play with things to see what I am going to do.
Old 12-11-2021, 03:19 AM   #206
Brz-123
Hello, you are a clever idiot.
You are learning a lot of things by trail blazing. Keep it going. All the best!
Sent from my SM-G781B using Tapatalk
Brz-123 is offline   Reply With Quote
The Following User Says Thank You to Brz-123 For This Useful Post:
Irace86.2.0 (12-11-2021)
Old 12-11-2021, 11:27 PM   #207
brzlegend
Drives: brz
Pretty sure alot of people have.
Looks nice by the way.
brzlegend is offline   Reply With Quote
The Following User Says Thank You to brzlegend For This Useful Post:
Irace86.2.0 (12-12-2021)
Old 12-12-2021, 04:54 PM   #208
brzlegend
Drives: brz
Yes you can flip the waistegate down. During boost you will always have a
higher pressure pre turbo than post turbo. The waistegate will control it, might need a little lighter spring than an in flow wastegate for the same boost level.
Old 12-12-2021, 05:00 PM   #209
Irace86.2.0
Old 12-12-2021, 05:57 PM   #210
brzlegend
Drives: brz
Glad I dont use precision waistegates.
Like I said it works and your turbo is way to small to worry about wastegate placement. Small turbos work off pressure, large turbos go towards the velocity side of things.
If you really want to rack your brain study compound turbos where they drop engine backpressure by adding a big turbo after the small one exhaust wise, at the same boost.
I won't interupt anymore, as the saying goes.
https://www.suprastore.com/etstosumksit.html
worst.build.ever.
KPower Industries K24 swap PulsarBeeerz Engine Swaps 1801 04-15-2025 11:54 AM
Irace86.2.0 Build Irace86.2.0 Member's Car Journals 195 03-25-2024 12:29 AM
Turbo or swap Fastend Forced Induction 35 06-11-2020 07:12 PM
Built Turbo K24 Swap? Calmwhiteguy Engine Swaps 31 02-13-2018 05:07 PM
IRACE86's Build Irace86 Member's Car Journals 25 01-10-2017 04:35 PM
