| GR86 General Topics (2nd Gen 2022+ Toyota 86) General topics for the GR86 second-gen 86 |
#15 |
Sarcastic SOB
Cool stuff Tcoat. And you said building the plant, meaning setting up the assembly tooling? You don't have to say but I'm guessing some version of what is now known as Stellantis (which is so foreign to me I had to Google "Chrysler's new name").
I have read a bit regards to Toyota and their jidoka practice, where they pretty much have the engineers do the assembly by hand until they can intelligently compose their automation to work with humans. Regards to the hole in the wrong place, at one time pretty much all North American manufacturers would get the vehicle right thru assembly with the hole in the wrong place and keep the line moving continuously whereas at Toyota for example, the line would be stopped when the fault was discovered in order to prevent repetition of errors. Employees are actually ENCOURAGED to stop the line. In fact a line can realistically be stopped 1000x in a month (for very short duration probably almost always). Its just a button, and they use it to improve production, not just push it through to be corrected afterward wherever possible.
#16 | |
North American manufacturing started to with the Japanese methods back in the mid 90s. They were not quiet fast enough with adopting them though and that resulted in the big bail out in 2008. Since then the changes have made them pretty much identical even if they do use American terms for the methods. Yes line workers are permitted to stop the line for issues. But it is still the team of specialists that will show up and fix the issue. It will be done very quickly. Rest assured though that the reason for stopping the line had better be good! Every minute of downtime costs tens of thousands of dollar.
#17 | ||
Drives: 2014 Mazda CX-5
#18 | |
Yes rotation is the best and most plants do it. But it still only means knowing a half dozen of or so jobs out of a couple of hundred. As far as keeping them "engaged" goes that is more HR hype than reality. After doing the exact same task several hundred times a shift moving to another almost identical task and doing it several hundred times sort of losses meaning. Anybody that has ever done high rate assembly knows what I mean
#19 | |
Professional Mechanic
Drives: 2017 86 6MT Oceanic
This might not seem like much of a thing, until you've needed to use like 3 different tools to take one single thing off of a german car. |
#20 |
@ 37.16 you see the front ends of a GR86 and a BRZ in the same color. I think I just made up my mind which twin I'm going to order....at least for today.
#21 |
Love @26:03 the correct parts bin door for the badges open up for the assembler so he doesn't have to think which car gets which badge.
| The Following User Says Thank You to StE92ve For This Useful Post: | Tcoat (12-05-2021) |
#22 |
Drives: 2014 BRZ
Wow, I have got to say that is one of the best car manufacturing videos I've seen. The portion describing the differences in rear suspension between BRZ and GR86 was very good.
Thank you very much Dreamwonder. |
#23 | |
![]() I have family members that are members of UAW and a sister who worked an assembly line for Trane for 30 years. It's pretty much exactly as you describe.
Visit my Owner's Journal where I wax philosophic on all things FR-S Post your 86 or see others in front of a(n) (in)famous landmark. What fits in your 86? Show us the "Junk In Your Trunk". |
#24 | |
Drives: '23 BRZ Limited
#25 |
Drives: GR86 2022
Looks like previous gen rear subframe inserts will continue to work.
At 12:41ish |
#26 |
Drives: BRZ 2nd gen
You also get a good look at the full size spare in the BRZ. Potentially the AUDM build?
| The Following User Says Thank You to Grif For This Useful Post: | Spuds (12-05-2021) |
#27 |
The Dictater
Drives: '13 Red Scion FRS
| Excessive manufacturing JZ mounts | PolishFrs13 | Engine, Exhaust, Bolt-Ons | 1 | 05-08-2017 05:33 PM |
| BRZ vs FRS Manufacturing Rate | Stigmaru | BRZ First-Gen (2012+) — General Topics | 18 | 12-12-2016 03:53 PM |
| Excellent Video Review | Chad86 | FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum | 1 | 06-15-2014 06:24 AM |
| Manufacturing Date | Brndn704 | Scion FR-S / Toyota 86 GT86 General Forum | 7 | 07-30-2013 04:17 AM |
| Excellent Video and Review: FR-S Pilgrimage Road trip from Vancouver to Laguna Seca! | jsooke | FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum | 23 | 12-23-2012 03:04 PM |
