Old 12-03-2021, 11:32 AM   #15
ZDan
ZDan's Avatar
Drives: '23 BRZ
Originally Posted by Dzmitry View Post
True, but I drive a little over an hour to and from work every day. I take the same exact route every time.
In 2018, so did I. Calculated mileage varied quite a bit even driving the same commute with the same driving style every day, roughly +/-2mpg. I think a lot of the up/down/up/down is due to not topping off to exactly the same fuel level every time, even though my topping-off method is exactly the same. There's just too much uppie/downie in it to try something different and expect the difference to fall outside the noise.
But the only comparison within those results that matters to me, is I'll take the fun and enjoyment aspect of the car for the loss of a couple mpg's over driving it like a granny just to save a couple bucks. So it's more of a personal comparison for me, more so than a true statistical one.
Of course you should drive it how you want to! Personally, commuting, it doesn't make much/any difference to me whether I'm short-shifting or not. If there's traffic I'll just try to minimize number of shifts...
Dzmitry (12-03-2021)
Old 12-03-2021, 11:35 AM   #16
Dzmitry
Dzmitry's Avatar
Drives: 2018 Subaru BRZ Limited with PP
Indeed, in traffic, I drive like any rational human should drive. I let all the fools cut me off only to get one car length ahead of me.
Dzmitry is offline   Reply With Quote
Old 12-05-2021, 12:05 AM   #17
Sasquachulator
Pavement Grey
If it matters, i just came back from a 450km (279mile) road trip.
according to the trip computer:
I did 6.3L/100km (about 37mpg)
Mostly 110km/h (68mph) and 120km/h (74mph) on the highway.
its pretty much -10C (14F) and 205/55/16 winter tires.
Not the most accurate relying the on trip computer but hell it cant be that far off.
And its alot better than i was expecting the highway MPG to be (i was expecting to be around 32-33mpg)
(best mpg i ever got was over 40 mpg in a honda fit and 37-38 in a scion iM)
the FA24 should best the EPA ratings easily as well.
Old 12-30-2021, 10:22 AM   #18
MajorGerth
Drives: 2022 BRZ 6M
I just did a couple hundred miles in my '22 with the manual, and I got 33.5 calculated by Fuelly. I think the computer read around 35 mpg. I was doing mostly 55-65 mph, and on long stretches I was switching between 5th and 6th gear to vary the RPM since I'm still in the break-in period.
MajorGerth is offline   Reply With Quote
Old 12-30-2021, 11:12 AM   #19
mazeroni
Drives: 2013 Scion FR-S Series 10
They did a highway loop MPG test at 70 mph in an automatic and they averaged 34 mpg. On summer fuel, maybe it would go up 1-2 MPG. The manual in that same scenario would likely get around 32 due to gearing. It doesn't seem like the car has drastically worse fuel economy than gen I. Improvements to parasitic loss and better front aero probably helps offset the bigger engine. Although I'd wager that if you are really getting on it, you might wind up consuming a tad more fuel just because HP isn't free. The bigger engine means you are dumping in more fuel.
mazeroni is offline   Reply With Quote
Old 12-30-2021, 01:46 PM   #20
Lelandjt
Drives: '04 STi, '12 Mazda 3 Hatch
Would you guess that the extra duckbill on the higher trim Toyota adds some aero drag?
Lelandjt is offline   Reply With Quote
Old 12-30-2021, 01:55 PM   #21
PLF69
Drives: 2020 M340i, 2022 BRZ
From the reviews they say its supposed to but I would be curious to know how much and from what speed ?
PLF69 is offline   Reply With Quote
Old 12-31-2021, 12:42 AM   #22
Lelandjt
It'd be funny if it's enough to make a slight difference in top end acceleration. Combined with the bigger wheels hurting acceleration out of a turn and maybe even lowering max corner speed, the lower trim might be measurably faster on a track.
I don't suspect any extra downforce at the very back of the car helps lap times.
Old 12-31-2021, 04:11 AM   #23
alex87f
Meow
alex87f's Avatar
Drives: GT86 (now sold)
On a track, PS4 vs. Primacy pretty much seals the deal in favor of the higher trim.
Side note: did anyone here ever really notice a difference in "butt dyno" between 91 & 93 on a stock gen. 1?
I've switched back & forth many times, and truly can't see a difference.
alex87f is offline   Reply With Quote
Old 12-31-2021, 10:29 AM   #24
mazeroni
Nope. When I've had to go 87 because of 91/93 not being available either where I was traveling in a rural area, or due to people panicking due to storms or whatever, I have never noticed anything.
If it is a super hot day and you are at the track, maybe 91 would net you a loss of a couple HP, assuming the car detects any pre-detonation. You could probably safely go full 87 if you are just cruising around at 2~4k.
For me, the cost difference between 91 and 93 is like $.30~$40 per gallon, or a few bucks each fill-up. So I just go 93.
Old 12-31-2021, 12:58 PM   #25
Lelandjt
Kind of on this topic: Driving between 7,000-11,000ft (mostly 9,000-10,000), temps of 45-75°F, and having 85, 87, 91 octane available. What would you use? On the one hand 85 makes a bigger bang. On the other if this engine computer is capable of adjusting everything to the edge of detonation maybe it can make more power on 91.
Old 12-31-2021, 01:23 PM   #26
dragoontwo
dragoontwo's Avatar
Drives: 22 BRZ limited
I have noticed when moving between 93 in TN and 91 in IA on my tuned 2020. I have also confirmed that the IAM was never 1 when on IA 91. as soon as back on 93 it went back to 1.
Old 12-31-2021, 01:41 PM   #27
mazeroni
If I'm reading correctly, 85 is the same as 87 at high altitudes. If that is all you have access to, it should be fine. I'm not aware of modern engines being damaged by using lower octane gas. They are smart enough and built well enough that it shouldn't damage anything.
But there are discussions about its impact on fuel economy negating the cost benefit.
Still, I feel like you would probably have to be revving the shit out of the car to maintain speeds going uphill or to pass people at those altitudes, and with so little torque already, I would always use the highest available.
Old 01-22-2022, 02:30 AM   #28
StormTrooper
StormTrooper's Avatar
Drives: Pavement MT GR86
That's not really true with modern engines. Engineering explained does a great video on this on YT.
I would not put anything under 91 in the 86 just to save a few bucks. It probably won't blow up but it'll definitely be pulling timing to save itself.
My first gen was usually around 28-30 mixed but idaho has a lot of open roads. My gs350 awd gets horrid ,damn near sti mileage no matter how easy I drive the thing.
GR86 MT premium
StormTrooper is offline   Reply With Quote
Canada: The GR86 Premium is $2000 more than the BRZ Sport Tech??? JDW2231 BRZ Second-Gen (2022+) — General Topics 49 01-20-2022 12:12 PM
2022 GR86 Premium MT & AT Comparo StE92ve GR86 General Topics (2nd Gen 2022+ Toyota 86) 121 12-08-2021 10:21 AM
GR86 PCD teppey GR86 General Topics (2nd Gen 2022+ Toyota 86) 23 07-29-2021 11:12 PM
GR86 In R7 of the Toyota Gazoo Racing GT Cup + GR86 coming to Grand Turismo Sport Blighty GR86 General Topics (2nd Gen 2022+ Toyota 86) 28 07-18-2021 03:38 PM
Subaru Premium BRZ 86 & Premium Proud of Boxer Catalog & Broshure keioffice Miscellaneous 0 03-14-2014 08:10 AM
