Old 11-25-2021, 09:08 PM   #169
Irace86.2.0
Irace86.2.0's Avatar
Drives: Q5 + BRZ + M796
I worked on the car a little.
I thought the whole bracket thing for the alternator extension terminal was a little weird. I have my own custom battery setup with a lightweight battery, so instead I decided to use the M8 threaded hole that was there, and I used a rivnut to mount the terminal. I enlarged the holes to use flange bolts instead of smaller head Allen bolts, but those would technically fit easier. I removed the red terminal cover and just used the grey one with a cut section on the side for the other wire.
I then worked on the starter wire. I stripped the plastic off like the instructions say. I had a piece of the cut harness on my used starter, so I cut a slit in it and used that with some heat shrink.
Lastly, I confirmed that the wideband O2 sensor harness will go through the firewall grommet that is for the sound tube. I just had to pull the grommet off and work it over the harness and then plug the grommet back in. I don’t know if the harness would reach through the shift boot to a downpipe bung in the engine bay, but this seems better.
The Following User Says Thank You to Irace86.2.0 For This Useful Post:
ML (11-26-2021)
Old 12-01-2021, 12:12 AM   #170
Irace86.2.0
I made a little progress after school. I used some rivnuts to find spots to mount the catch cans. From the looks of things, there should be plenty of room.
Old 12-01-2021, 12:33 AM   #171
Irace86.2.0
I worked on the AC lines and wiring loom. This shows the clearance and the wrapping I’ve done so far. Lots of stuff to still wrap to get a final product that is shielded from rubbing and looks good. The AC lines clear the JR Radiator Oil Cooler, but close, so I wrapped them, so nothing wears down. I also wrapped them, so they hopefully blend in against the dark background.
Old 12-01-2021, 10:11 AM   #172
captain awesome
Wears Pants
Drives: 14 FRS K24 swap - SOLD
Looks good. I considered covering my a/c lines, and now I'm reconsidering it again before getting the system charged. At least the part by the firewall.
captain awesome is offline   Reply With Quote
Old 12-01-2021, 10:21 AM   #173
ML
ML's Avatar
Drives: 13 White MT FR-S
wtf is an "a/c line"?
The Following User Says Thank You to ML For This Useful Post:
Irace86.2.0 (12-01-2021)
Old 12-01-2021, 11:27 AM   #174
captain awesome
Wears Pants
Can't tell if joking or not but just in case, it's air conditioning hard lines and hoses.
Old 12-01-2021, 11:41 AM   #175
hedtrip
hedtrip's Avatar
Drives: 2013 toyota 86
So whats the black block box next to your heater core?
hedtrip is offline   Reply With Quote
Old 12-01-2021, 12:09 PM   #176
ML
ML's Avatar
lol yes i was joking
captain awesome (12-01-2021)
Old 12-01-2021, 12:25 PM   #177
captain awesome
Wears Pants
I was laughing at it. Was a bit worried for a sec though.
Old 12-01-2021, 05:59 PM   #178
Irace86.2.0
It’s for a Defi boost gauge.
hedtrip (12-01-2021)
Old 12-01-2021, 09:44 PM   #179
Irace86.2.0
Finished wrapping the chassis harness. I plan to cover and wrap the engine harness too. I don’t know how much slack is available on the starter and alternator lines, so I didn’t wrap them into one cover or secure them. I’ll zip tie them after the engine is in place. The AC lines are complete. I mounted them before dropping the motor in. Hopefully there will be clearance. The oil cans are mounted too. Again, should be enough room.
After school I’m going to try to prep the transmission. Planning to grind down some surfaces to clear the starter. I’ll try to keep myself busy, but I want to wait until Friday to install the motor, which is when I get the Fumoto drain valve.
The Following 2 Users Say Thank You to Irace86.2.0 For This Useful Post:
Dadhawk (12-02-2021), ML (12-02-2021)
Old 12-02-2021, 08:34 AM   #180
ML
ML's Avatar
that tesa tape looks so much better
Old 12-02-2021, 09:11 AM   #181
captain awesome
Wears Pants
Is that harness wrap rated for weather? The Tesa tape I have is for interior purposes only but I would like to find something like it for the engine bay like yours. The stuff I ended up using works awesome but is really glossy, at least for now. Hoping it kinda hazes up a bit with some heat and miles.
As for the A/c lines clearance, I had mine installed before dropping the engine and trans in. They were high enough that I had no issues, just be cautious of hitting where they bolt into the firewall and you're golden.
The Following User Says Thank You to captain awesome For This Useful Post:
Irace86.2.0 (12-02-2021)
Old 12-02-2021, 10:25 AM   #182
DustinS
DustinS's Avatar
Drives: 2013 Ultramarine FR-S
They make a Tesa tape that isn't as "fuzzy" as the interior stuff. I used it quite a bit on my engine bay last time around. I'll see if I can find what I bought.
The Following 2 Users Say Thank You to DustinS For This Useful Post:
captain awesome (12-02-2021), ML (12-02-2021)
worst.build.ever.
KPower Industries K24 swap PulsarBeeerz Engine Swaps 1801 04-15-2025 11:54 AM
Irace86.2.0 Build Irace86.2.0 Member's Car Journals 195 03-25-2024 12:29 AM
Turbo or swap Fastend Forced Induction 35 06-11-2020 07:12 PM
Built Turbo K24 Swap? Calmwhiteguy Engine Swaps 31 02-13-2018 05:07 PM
IRACE86's Build Irace86 Member's Car Journals 25 01-10-2017 04:35 PM
