Old 11-15-2021, 07:04 AM   #19335
dodj
Drives: Rallye Blue BRZ
Changed trans and diff fluids... a couple days ago.
Toyota WS ATF is pricey.
dodj is offline   Reply With Quote
Old 11-16-2021, 08:41 PM   #19336
dodj
Had the windshield changed.
Old 11-21-2021, 04:17 PM   #19337
2020BRZtS
2020BRZtS's Avatar
Drives: '20 BRZ tS (15/300) / '09 Scion tC
Installed STi axleback and wired up 4th brake light. Would show pics but my car is beyond dirty.
2020BRZtS is offline   Reply With Quote
Old 11-21-2021, 04:54 PM   #19338
soundman98
ProCrastinationConsultant
soundman98's Avatar
leaving things to my imagination isn't the best idea
Old 11-22-2021, 01:53 PM   #19339
BrahmaBull1990
Howdy
BrahmaBull1990's Avatar
Drives: 2020 BRZ PP
IAG short blocks just went on sale
There's a point at 7,000 RPM... where everything fades. The machine becomes weightless. Just disappears. And all that's left is a body moving through space and time. 7,000 RPM. That's where you meet it. You feel it coming. It creeps up on you, close in your ear. Asks you a question. The only question that matters. Who are you?
BrahmaBull1990 is offline   Reply With Quote
Old 11-23-2021, 01:54 PM   #19340
dpfarr
Drives: BRZ ts
I don’t know how to reset the little infographic on the bezel that says average speed, mpg, etc.
I wanted to do that to my BRZ today but couldn’t.
dpfarr is offline   Reply With Quote
Old 11-23-2021, 02:27 PM   #19341
JD001
JD001's Avatar
Drives: Subaru BRZ
Just press the thingy for a few seconds... Should "zero".. in case it doesn't then possibly you've bought a lemon!!
Old 11-23-2021, 04:42 PM   #19342
PenGun
Drives: Red 2019 Subaru BRZ
Lost another tire to our local pothole road. Getting a pair of 215/50/17s for the back to replace the bust one. A bit more air might help.
Gonna put in a claim on this one. The company that has the maintenance contract is not keeping up, and in BC we have a way to get compensated.
PenGun is offline   Reply With Quote
Old 11-29-2021, 06:49 PM   #19343
norcalpb
norcalpb's Avatar
Went in for an oil change and was told how messed up my suspension is.
I have Bilstein B6 struts, and they aren’t leaking, but there is play between the shaft and the body. Apparently struts have bushings inside of them?? TIL.
On my whiteline control arms, the back right eccentric bolt “tab” is starting to round off and has completely destroyed the notch that it sits up against.
Guess it’s new coils and control arm time!
Front struts lasted 90k, rear shocks are still in great condition after the same mileage.
Old 11-30-2021, 07:38 PM   #19344
BrahmaBull1990
Howdy
Drives: 2020 BRZ PP
Rather than starting another thread for a two second question, I thought I’d ask here:
If I am going from a Tomei UEL header to a Tomei EL header, do I need a retune?
TIA
Old 11-30-2021, 08:31 PM   #19345
norcalpb
norcalpb's Avatar
TIA
Depends, do you have ECUtek or OFT?
Old 11-30-2021, 08:38 PM   #19346
BrahmaBull1990
Howdy
Drives: 2020 BRZ PP
ECUtek. I called the shop that tuned my car with a Dynapack and they said “it would probably be okay,” but that didn’t instill confidence in me…the guy who I spoke with wasn’t the tuner, too.
Old 11-30-2021, 10:20 PM   #19347
Grady
Grady's Avatar
Drives: BRZ Yellow, Ranger, Evora, WCM S2K
It will be ok, It may not be maximized on HP.
Old 11-30-2021, 10:31 PM   #19348
magbrz
Drives: 2020 BRZ w/ PP
QuickJacks
I ordered my 5000TLX QuickJacks and the pinch weld blocks. My Christmas present to myself! My shop supports many hobbies, so I wanted something portable that can be stored out of the way.
Update 12/11/21
Jacks are up and running! Pardon the poor photo, I was as far back as I could get. I had to redo the fittings on the long hoses because my brain transposed the torque values. I also used Loctite 5452 on my second attempt. After that, no leaks!
magbrz is offline   Reply With Quote
