Old 09-26-2021, 04:12 PM   #155
coldstart
coldstart's Avatar
Originally Posted by Rzrs View Post
This is really great. Have you ever considered making one for where the head unit goes? I dream of being able to delete the head unit and add 3 gauges in its place.
2013 FRS
Header & Tune
coldstart is offline   Reply With Quote
Old 09-30-2021, 07:29 AM   #156
knapper
knapper's Avatar
Drives: '13 Scion FR-S - Whiteout
The importance of choosing the correct material...
Great thread! Don't know how I didn't see this before.
On the right, you will see the gas pedal spacer with the pedal limit spacer. Both broke eventually due to using PLA instead of ABS. So, that is one of the reasons you want to use ABS or PETG for this type of application. The bolts eventually started to spin inside the unit, and I had to pry it in half to remove it. Hell of of a lot cheaper than the Verus!
On the the left is a replica of the Perrin trunk handle done in PLU, works perfectly!
https://ibb.co/s9P66M1
Link to Pedal kit: https://www.thingiverse.com/thing:3650383
Trunk handle: https://www.thingiverse.com/thing:2781494
Current: 2013 Scion FRS - Whiteout
knapper is offline   Reply With Quote
Old 09-30-2021, 11:31 AM   #157
RayRay88
Drives: 2017 86 860 Special Edition
I wouldn't even go near something as critical as the pedal with ABS let alone PLA. There's a reason why most spacers are made of machined metal. Even carbon filled nylon will fatigue and fail over time. If those pieces break and jam underneath the brake pedal it can be very dangerous.
RayRay88 is offline   Reply With Quote
Old 10-01-2021, 07:24 AM   #158
knapper
knapper's Avatar
Technically, the only thing that "broke" was the attachment bolts spinning inside the unit after trying to retighten it again one day. Which could have been avoid using larger bolt heads or a metal insert. The pic of it broken in half is my using a flathead and a hammer to pry it loose.
Although I agree PLA is not a good choice, but when printed densely, it holds up well. This changes when the temperature changes, hence the recommendation to use PETG or ABS. Both of with would do better in higher temps and are significantly stronger.
You would be hard pressed to break or even bend slightly this piece at 75% infill ABS or PETG. Is metal stronger or better in the long term? Yes. Do I think ABS or PETG would hold up in most situations. 100%.
On that note, $170+ for a small piece of machined metal, is insane.
Old 10-01-2021, 08:08 AM   #159
Yoshoobaroo
TRACKBREAD
Yoshoobaroo's Avatar
Official FT86Club 3D printing thread!
Agreed. A gas pedal spacer is something I’d make out of PETG and not worry about. Unless you’re seeing interior temps over 150F it will be just fine.
Side note: if you’re looking for strength and stiffness, increase your number of perimeters and top/bottom layers instead of bumping the infill, I find that to work better with less material.
Old 10-01-2021, 10:46 AM   #160
RayRay88
It's not just overall strength of a part that determines feasibility of the material, you have to remember that PLA does not handle water or chemicals well. Over time, the stuff you drag into your footwell through your feet will end up on the PLA and it will degrade. I've seen PLA parts literally decompose when consistently exposed to the elements like that. I deal with additive manufacturing and advanced materials for a living in aerospace/medical/automotive.
It may be fine, even in the long run, but I'm just saying be cognizant of the risks associated. Especially in critical components.
Edit: You're in Canada too, lets see how many hot/cold heat cycles it handles this winter.
Old 10-01-2021, 02:32 PM   #161
knapper
knapper's Avatar
Oh 100%, the post was actually more so to show that PLA is a bad choice.
Luckily, I don't drive her in the winter, it's stored in relatively warm garage until spring.
Old 10-18-2021, 02:07 AM   #162
Rzrs
Drives: 2013 frs
I never considered it since I need my headunit to listen to music so i can't hear the creaky suspension and weird sounds the car isnt supposed to make.
Rzrs is offline   Reply With Quote
Old 11-22-2021, 06:39 PM   #163
alibaig99@gmail.com
Drives: Toyota 86 GTS 2013
Originally Posted by 86league View Post
Got one of the knock-off PZ435-10340-00 hinged center console arm rests from amazon a while back. After I got it, I came to the conclusion that I didn't want to drill a bunch of holes in my console, and it wasn't high enough for my liking.
I ended up making 3D printed spacer that the arm rest screws into, and then the spacer fits into the console and is held in place by a couple of "tabs" front and back and some guides on the sides. It adds about 1" to the overall height and I'm fairly happy with it at this point. Big pluses to me are that it just lifts out so if I want to take it out for track events I can, and now I don't feel like I have to lean to the passenger side to get my arm down on the arm rest.
Previous iterations I tried just using double sided tape to stick it to the console and didn't have the locating tabs/guides. I always ended up banging into it when I'm trying to load stuff into the back seat, or even bumping it getting in and I would knock the tape loose.
The back locating tab is sized so that the cupholders are still useable.
Printed in ABS and had some issues with it wanting to peel off the print bed. You may notice some slots along the length. That was an attempt to give the ABS somewhere to relieve the thermal contraction vs. pulling off the print bed. It seemed to help, but didn't 100% eliminate it.
Had to print in 2 pieces because of the size. Have a "tab" that slides into the other part and then they are screwed together from the top.
It could be improved I'm sure, the compound curvature of the console and the armrest made this task a little beyond my CAD skills. The model is kind of a house of cards. I tried to make it parametric so you could change the height of the spacer, but seems like changing the height now breaks a lot of stuff and you have to manually edit things to fix them every time the height is changed.
Here's some images of the CAD:
And the finished product mounted to the arm-rest.
This pic makes the PVC "leather" look way darker than the seats, but it doesn't seem to be anywhere near that noticeable just looking at it. Hey, for $40 vs the $160 for the OEM, good enough for me.
STL, STEP, and the Fusion 360 parts are avail on thingiverse.com/thing:4840911
Hey Mate, could you design this for RDH cars?
alibaig99@gmail.com is offline   Reply With Quote
Old 11-22-2021, 07:21 PM   #164
Yoshoobaroo
TRACKBREAD
You can just mirror the parts in your slicer
Old 11-30-2021, 05:31 AM   #165
dexterchock
Drives: Toyota 86
I 3d printed the trd aero turbulator. https://www.thingiverse.com/thing:5150964
but i couldn't get curvature of the bumper right, so if you guys print it, remember print it with flexible material ( the trd is also made out of rubber material). https://cdn.thingiverse.com/assets/3...y_IMG_6011.JPG
dexterchock is offline   Reply With Quote
Old 11-30-2021, 07:32 AM   #166
Takumi788
JHerbert Racing
Takumi788's Avatar
Drives: 2013 Scion FRS
Just picked up a 3d printer that was on black Friday sale. As an R&D design engineer this purchase was long overdue. Now that I have the printing portion dialed in I am going to start working on an AIM Solo 2 holder that mounts to the radio block off panel. Then a traction control button re-location bracket. I am sure more track oriented things will follow.
- #813 2013 Scion FRS Build Thread
- JHerbert Racing Website
Takumi788 is offline   Reply With Quote
Old 11-30-2021, 07:42 AM   #167
Which one did you get? I'm thinking of getting a new one, We have a small format (120mm) one in the house but it belongs to my son although I can use it. I'm thinking of getting a 500mm one to allow bigger prints. That seems to be about the largest size you can get for a reasonable price.
Old 11-30-2021, 08:38 AM   #168
Takumi788
JHerbert Racing
Takumi788's Avatar
I got a Creality CR10S for a steal. 300 x 300 x 400 build volume. You can get the "S4" version if you want a larger build volume. I highly recommend Creality for home use. It has been great. Especially with the .8mm nozzle. Once I get my FRS to my new house I will start designing some stuff and things. I have a few ideas for aero as well.
Official DTM Autobody Services Thread for FT86Club! DTMAUTOBODY Southern California 9 12-31-2013 02:09 PM
Official FT86Club Chatroom? wrxgoose Site Announcements / Questions / Issues 13 09-15-2012 05:26 PM
Official FT86Club decal idea? Hanzo Scion FR-S / Toyota 86 GT86 General Forum 71 06-21-2012 08:09 PM
