Old 11-23-2021, 07:34 PM   #1
ptabred
Drives: 2013 Subaru BRZ Limited Manual
Exclamation Smell of burning oil (I think) from tail pipe
Hey guys I just recently purchased a 2013 Subaru BRZ Limited manual transmission with around 61,000 kms. I had the car inspected by a mechanic shop when I bought it and they told me that the car's oil was low and that it could perhaps be leaking. I haven't noticed any leaks from the car and I had the oil changed at a shop a few days ago and they told me that the car was in perfect condition and there was no leakage of any kind. Today I drove over a really bad bump on the highway and when I got home I noticed a burning oil type smell coming from the exhaust. I couldn't smell it from the engine bay as it was coming from the back of the car. I will be monitoring the smell and oil levels to see if anything abnormal pops up. I was thinking maybe some oil was shook around the car and may have seeped through from somewhere as I went over the bump. I wasn't driving the car particularly hard either. This is the first time I have noticed the smell. Any thoughts as to what it could be?
ptabred is offline   Reply With Quote
The Following User Says Thank You to ptabred For This Useful Post:
humfrz (11-27-2021)
Old 11-23-2021, 07:50 PM   #2
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
Check the front timing cover. Very common that they leak from there, the valve cover, or the avacs solenoids on the timing cover. Also possible they spilt oil during the change and the header runs right under the engine.
Ultramaroon (11-25-2021)
Old 11-23-2021, 10:54 PM   #3
JohnH
Professional wrench
Drives: 2020 BRZ ST RS
welcome from another BC guy. Funny thing, my car was brand new out of the showroom, and I would sometimes smell a bit of oily/burning smell. I am a professional tech and I cannot find anything wrong with it, nor does it always happen. With my car I suspect it was just some sort of packing grease/oil on the exhaust. Some sort of corrosion inhibitor kind of thing. It doesn't do it anymore
2020 BRZ Sport Tech RS World Rally Blue
'18 TS Suspension, camber bolts, align.
Gruppe-S UEL header/overpipe
Wayne Rom Stg 2+ tune
225/45VR17 RT660s
JohnH is offline   Reply With Quote
The Following User Says Thank You to JohnH For This Useful Post:
Old 11-24-2021, 01:04 PM   #4
alex87f
Meow
alex87f's Avatar
Drives: GT86 (now sold)
Check the triangular plate at the back of the passenger-side head. Manual 86's tend to have a small drip there, which leaks right onto the header (or the overpipe?).
Rub your finger at the bottom of the plate, if there's oil clean it and re-test a couple of days later.
You can either purchase aftermarket plates with a gasket (should be about $100), or re-seal the existing plate with a heat- and oil-resistant sealant.
alex87f is offline   Reply With Quote
The Following User Says Thank You to alex87f For This Useful Post:
Old 11-24-2021, 05:30 PM   #5
ptabred
I checked out the cam plate cover and it looks clean. I also checked the timing cover and there didn't seem to be any oil residue around. I'm gonna monitor the oil levels and the smell and see if it happens again. I have no idea what it could be. I've never seen any oil spots underneath the car either.
Old 11-25-2021, 07:53 AM   #6
It is a strong possibility that they spilled a bit removing the filter or refilling. Just a couple of drops off the old filter or the end of a funnel can cause enough smoke to smell. The timing is right.
BrahmaBull1990 (11-26-2021), Ultramaroon (11-25-2021)
Old 11-25-2021, 09:48 AM   #7
soundman98
ProCrastinationConsultant
soundman98's Avatar
once is an anomaly, repeated times is a pattern. i wouldn't worry about it. this car is relatively easy to fill, but some of my previous vehicles, i've spilled oil while refilling, and it'll take a couple weeks to burn it off due to my limited drive times.
check the level from time to time, enjoy the car, sometimes watch behind teh car on hard launches for blue smoke. as long as nothing significant appears, i wouldn't worry about it.
Old 11-25-2021, 03:32 PM   #8
All good stuff. As long as there's oil on the dipstick, you're safe. As long as it's between the marks, you're golden.
BrahmaBull1990 (11-26-2021), soundman98 (11-25-2021), Tcoat (11-25-2021)
Old 11-27-2021, 12:57 AM   #9
Hell, back in the day, when people smoked in cars, we wouldn't notice a little oil burning off the engine - right @Tcoat?
Tcoat (11-27-2021), Ultramaroon (11-28-2021)
Old 11-27-2021, 11:16 AM   #10
You mean like yesterday?
humfrz (11-27-2021), Ultramaroon (11-28-2021)
Old 11-27-2021, 11:02 PM   #11
Exhale BEFORE you get in the car.
humfrz (11-28-2021), Tcoat (11-27-2021)
Old 11-28-2021, 02:45 AM   #12
You ain't no fun -
Old 11-28-2021, 04:49 AM   #13
Boomerang
86
Boomerang's Avatar
yep
humfrz (11-28-2021), Ultramaroon (11-28-2021)
Old 11-28-2021, 10:09 AM   #14
soundman98
soundman98's Avatar
Originally Posted by Boomerang View Post
yep
the backfires were a little more potent in that arrangement.
i can see how automotive regulations quickly moved the exhaust to behind the driver position.
The Following 3 Users Say Thank You to soundman98 For This Useful Post:
Boomerang (11-28-2021), humfrz (11-28-2021), Ultramaroon (11-28-2021)
diagnostic, leak, oil, question, subaru brz
86 air con burning smell crewchief Issues | Warranty | Recalls / TSB 36 10-21-2017 11:49 AM
'17 BRZ burning smell Zoh Issues | Warranty | Recalls / TSB 28 05-14-2017 11:09 PM
Burning smell Riftur Engine, Exhaust, Transmission 9 04-13-2016 01:50 AM
Burning smell Boofneenee Issues | Warranty | Recalls / TSB 6 09-30-2013 06:28 PM
Over pipe strong burning smell Sniper2606 Engine, Exhaust, Transmission 6 05-17-2013 12:40 AM
