Old 09-29-2021, 11:35 PM   #2535
949 Racing
FT86Club Official Vendor
949 Racing's Avatar
Drives: Miata, GT350, FR-S
From Laguna Seca last weekend. Our project car "Blub".
18x10 +35 offset. No spacers rear, 5mm spacer front.
-5° front and -3.5° rear camber. No roll.
265/35/18 Goodyear SC3R
949 Racing is offline   Reply With Quote
The Following 6 Users Say Thank You to 949 Racing For This Useful Post:
ACT86 (09-30-2021), adrianj73 (10-15-2021), jflogerzi (12-01-2021), RedReplicant (12-13-2021), SCFD (12-01-2021), SP86 (11-27-2021)
Old 11-24-2021, 12:16 AM   #2536
CkOne
Drives: FR-S RS 1.0 #1037/1500
Has anyone had any issues with rubbing against the parking brake line in the rear? Is there anyway to relocate the line? I’m trying to avoid running spacers so I don’t have to add more negative camber
CkOne is offline   Reply With Quote
Old 11-30-2021, 05:02 PM   #2537
APEX Race Parts
APEX Race Parts's Avatar
Drives: Launch-Year Whiteout FR-S
Do you have aftermarket rear control arms? With the stock arms, you can see in the photo below that the Ebrake cable goes through at bracket to help keep it from rubbing.
https://static.ed.edmunds-media.com/..._toelink_a.jpg
On many aftermarket control arms, the bracket is removed and the cable can get in the way when running wider fitments. Most people will simply use a few zipties placed strategically to solve the issue. Just be sure to not make them too tight and the cable still need to be able to move on the inside.
-Ian
APEX Race Parts is offline   Reply With Quote
Old 03-26-2022, 12:49 PM   #2538
Newbee
After going through the 182 pages I’ve learned a lot!!!
I am currently on stock suspension with no modifications on my 13 BRZ.
Just bought some Option Labs R716 18x9.5 +35 offset.
Looking to run them on 255/35/18 Firehawks Indy 500
Will these fit on stock suspension? After reading I know 38 offset will rub strut, but hopeful I’ll be ok with 35 offset
Newbee is offline   Reply With Quote
Old 03-29-2022, 01:39 PM   #2539
APEX Race Parts
That fitment will be pretty aggressive on the fender side. For reference we offer an 18x9.5" ET40 (5mm less poke) and with a 255/35-18, we recommend a minimum of -2 degrees camber front and rear. With a track oriented tire that runs extra wide closer to -3 degrees front and -2.5 rear are needed. With an ET35 offset, the needed camber will be a bit higher. This fitment will be tricky without adding coilovers, front camber plates, and adjustable rear arms to dial in the right alignment specs.
-Ian
The Following User Says Thank You to APEX Race Parts For This Useful Post:
Tatsu333 (03-02-2024)
Old 04-01-2022, 12:05 AM   #2540
Newbee
-Ian
Thanks Ian appreciate the info!!!
Old 04-02-2022, 10:36 PM   #2541
colinshark
Drives: Some RX-7s
I just did mine!
265/35/18 A052
Titan 7 T-S5 18x9.5 +40
Tarmac 2 Clubsport, camber maxed out in the slotted hole
Subaru conical washers
Pedders offset front strut top mounts
No other changes from OEM. Slightly rubs sometimes and throws rocks all over the place. I love it.
colinshark is offline   Reply With Quote
The Following 7 Users Say Thank You to colinshark For This Useful Post:
ACT86 (04-03-2022), brandonblt2 (09-25-2022), JD001 (03-03-2024), kevaughan (06-19-2024), PulsarBeeerz (04-03-2022), SuperTom (04-02-2022), Tatsu333 (09-24-2022)
Old 09-22-2022, 11:42 PM   #2542
scottryan
Financial Distress
scottryan's Avatar
Drives: 2017 GT86 325WHP
18x9.5 +40 on 275/40/18 Nitto NT01
Ask me anything, here's the specs:
- Volk TE37SL 18x9.5 +40
- Rays Closed-End Lug Nuts
- Nitto NT01 275/40/18 R
- Nitto NT05 265/35/18 F
- HKS Hypermax GTIV Coilovers
Front: No modifications, zero rub, full lock, all bumps
Rear: Pulled rear fenders, trimmed rear bumper inside and inner bumper clip, doesn't rub daily driving unless going over train tracks or a nasty bump, it will graze the rear bumper. Clears the fender 150%
scottryan is offline   Reply With Quote
The Following 6 Users Say Thank You to scottryan For This Useful Post:
ACT86 (09-23-2022), CkOne (10-13-2022), JD001 (10-25-2023), kevaughan (06-19-2024), Tatsu333 (03-02-2024), Teseo (02-14-2025)
Old 09-24-2022, 11:49 PM   #2543
MdNt.exe
MdNt.exe's Avatar
Drives: 12'250,16'bmw S1Krr,16' 636,16BRZ
this looks great. Do you have any close up pics of the areas you trimmed in the rear?
MdNt.exe is offline   Reply With Quote
Old 11-28-2022, 12:50 PM   #2544
scottryan
Financial Distress
scottryan's Avatar
Thanks man! Car is in storage an hour away from me now. I'll get pics next year in the spring and do an update if I remember to haha
Old 01-15-2024, 05:50 PM   #2545
Simok
Drives: 2013 FRS
Looks amazing. Make me feel better that my te37sl 18x9.5 +40s, with 255/35/18 all around will work hopefully without rolling or pulling the fenders. So the only suspension mods your running are coilovers? No lcas or anything?
Simok is offline   Reply With Quote
Old 01-16-2024, 09:51 AM   #2546
Tokay444
Not as meaty as some of you boys…
245/40/17 RE-71RS on Titan 7 17x9 +37 with extended studs and titanium lug nuts. Tarmac 2 and TRD sway bars.
The Following 5 Users Say Thank You to Tokay444 For This Useful Post:
JD001 (03-03-2024), Racecomp Engineering (01-17-2024), RToyo86 (01-16-2024), Tatsu333 (03-02-2024), Teseo (02-14-2025)
Old 01-16-2024, 12:35 PM   #2547
RToyo86
RToyo86's Avatar
Drives: 17 Asphalt 86
17x9 +35 RPF1
RCE yellow+Bilstein B6/ pedders strut Mount
245/40R17 RS4
Roughly -2°F/-2°R camber
Tires fit wide for 245s
No rubbing issues, fitment pretty much perfect without running excessive camber for mostly street use.
The Following 3 Users Say Thank You to RToyo86 For This Useful Post:
Racecomp Engineering (01-17-2024), Tatsu333 (03-02-2024), Teseo (02-14-2025)
Old 03-02-2024, 12:38 AM   #2548
Kiyora
Kiyora's Avatar
Drives: 2013 Subaru BRZ / 2013 Scion FRS
Exclamation
hello so I'm experiencing a slight problem, I finally upgraded my wheels and am now there is slight rub whenever I hit a small bump in the road.
Currently running 18x9.5 5x100 255/35 and I'm on Tien coils. And no I don't have my fenders rolled. Any thoughts on what might fix this?
Kiyora is offline   Reply With Quote
Winter Tire Review Thread (Please contribute) pastuch Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 344 03-13-2024 06:49 PM
Wheel Directory: Forgestar F14 18x8.5 +38/18x9.5 +38 ScionFR-S Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 97 09-09-2015 07:32 PM
Meaty rubber on flush spoke rims? red_comet Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 16 06-14-2013 01:21 PM
Official wheel/tire fitment thread needed empower-auto Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 4 06-22-2012 02:40 AM
The Wheel and Tire Fitting Thread EvoFanatic Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 2 03-15-2012 04:05 PM
