Old 11-20-2021, 07:07 PM   #81775
Boomerang
86
Boomerang's Avatar
needed to edge my lawn.
for the first year, the house came with a 'free' gas edger, there were a number of leaks in the tank somehow, it leaked gas faster than it used it. gave it to my sister.
second year, i thought i'd be smart and get an electric one.
that worked horrible. it only went into the ground about a 1/2", and required constant retouching. first time out, i started modifying it trying to get it to cut a deeper trench to hold shape longer...
so today, i made my own.
works great. just don't tell milwaukee when i warranty the weed trimmer later.
What could go wrong 😀
Watch your toes…
Boomerang is offline
Old 11-20-2021, 07:14 PM   #81776
Spuds
The Dictater
Spuds's Avatar
Drives: '13 Red Scion FRS
I just rotate my string trimmer head 90 degrees...
Spuds is offline
ScoobsMcGee (11-21-2021), Ultramaroon (11-20-2021)
Old 11-20-2021, 07:38 PM   #81777
It's not fission or fusion, so the number of atoms don't change, meaning you can produce the same amount of water from the hydrogen you originally pulled from water (assuming a supply of oxygen). If you are saying there are energy losses in a conversion loop then yes, you would be correct. You do not get as much energy out of the synthesis of water as you spent to split the hydrogen from the oxygen.
The number of atoms doesn't change the numbers of atoms due to the law of Conservation of Grammar.
Ultramaroon is offline
Spuds (11-20-2021), x808drifter (11-21-2021)
Old 11-20-2021, 07:56 PM   #81778
spcmafia
spcmafia's Avatar
Drives: 2018 Subaru BRZ
Oh man this video is just pure joy. What a magnificent FD Build. I was smiling as much as the guy, If not more, and I wasn’t even driving the car. Long live the Wankel!
spcmafia is offline
The Following User Says Thank You to spcmafia For This Useful Post:
spike021 (11-20-2021)
Old 11-20-2021, 08:34 PM   #81779
spike021
spike021's Avatar
update: apparently at target they sell either <=3ft or >=5.5ft fake trees in-store. Michaels, a "craft store" only sells pre-lit trees in-store. I'm.. very confused.
Instagram: @spike.grc
spike021 is offline
Old 11-20-2021, 09:12 PM   #81780
soundman98
ProCrastinationConsultant
soundman98's Avatar
i did try that first, blew through 3 batteries and half the trimmer head of string in the first 15 ft. i've got about 50ft that needs doing.
the saw blades are free off the construction sites(too dull to cut wood anymore), and they work better
soundman98 is offline
Spuds (11-20-2021)
Old 11-20-2021, 09:28 PM   #81781
And you will be ready to go in the event a zombie apocalypse ever comes about!
Tcoat is offline
soundman98 (11-20-2021), Spuds (11-20-2021)
Old 11-20-2021, 09:31 PM   #81782
Sapphireho
Famous Potatoes
Sapphireho's Avatar
Drives: '15 ultramarine
I thought you were jewish? I'm confused.
Sapphireho is offline
Old 11-20-2021, 09:38 PM   #81783
Sapphireho
Famous Potatoes
Sapphireho's Avatar
I got the Ryobi attachment. Works well.
Dadhawk (11-21-2021)
Old 11-20-2021, 10:01 PM   #81784
spike021
spike021's Avatar
was kinda raised both jewish/christian, complicated story.
regardless, we never did trees anyway but I was like what the hey I should see what the fun is about.
spike021 is offline
The Following User Says Thank You to spike021 For This Useful Post:
Sapphireho (11-21-2021)
Old 11-20-2021, 10:02 PM   #81785
spike021
spike021's Avatar
I bought a cheap set of christmas lights, also for the first time, at target + a smart plug (I actually can use it for other stuff but figure I can use it for the lights during the holidays). Of course I went to both Target/Michaels and totally forgot to get stuff to hook the lights onto on my balcony, ffs. So back to Michaels tomorrow, I guess. Trying to decide between tacks or outdoor command hooks. Anyone have recs? Basically non-permanent.
spike021 is offline
Old 11-20-2021, 11:12 PM   #81786
soundman98
soundman98's Avatar
ziptie all the things.
buy the bag of 1,000, black is uv-stable, white is indoor-use only.
once you start, there's a million other uses for them.
The Following 2 Users Say Thank You to soundman98 For This Useful Post:
spike021 (11-20-2021), Spuds (11-21-2021)
Old 11-20-2021, 11:17 PM   #81787
spike021
spike021's Avatar
Totally forgot about zipties, that's a solid idea.
spike021 is offline
Old 11-20-2021, 11:22 PM   #81788
soundman98
soundman98's Avatar
true story, i bought the string trimmer-only model the year before they came out with the quick-loc version that offers the capability...
i believe a Red Green Show quote works best here:
"if the women don't find you handsome, they should at least find you handy!"
