#71 |
Drives: 2018 BRZ 6MT
Stock #1
| The Following User Says Thank You to vin61k For This Useful Post: | villainous_frx (08-08-2023) |
#72 |
Drives: 2015 WRB BRZ
You the real MVP
#73 |
Off to the track!
Drives: '14 Lava 86, '13 WRB BRZ
Photo from DDT:
![]() Got bored over reading week, added all the PNs I could find to the first page. Parts slowly coming in for the 2022 season, nothing crazy. Replacement rear bumper, shift knob, and some other interior bits. Car should be going to the shop soon to have the trunk pulled out. Going into the winter there are no crazy plans for the car, but a custom axle back and some aero would be fun. |
| The Following 5 Users Say Thank You to villainous_frx For This Useful Post: | beltax90 (11-09-2021), Berserker (11-17-2021), DiscoQuinn (11-09-2021), RToyo86 (11-10-2021), Tcoat (11-09-2021) |
#74 |
Drives: 2017 BRZ
I miss DDT. I don't know why they covered over some of the layouts, as I liked the variety.
| The Following User Says Thank You to DiscoQuinn For This Useful Post: | villainous_frx (11-09-2021) |
#75 |
Drives: '15 BRZ RA
Nice!
#76 |
Drives: 2022 BRZ sport-tech
Sorry to hear about your accident but it's good to see the car being used the way it is.
Can i ask what was the reason behind the switch from Greddy x KW coilovers to the Ohlins?
Daijiro Katoh - Champion Forever!
Past: 92 EG w/JDM B18C, 00 EK w/JDM B18C, 04 600RR, 97 ITR #421, 10 Acura CSX-S, 17 BRZ Current: 22 BRZ, 00 S2K - #0220 |
#77 | ||
Off to the track!
![]() Quote:
After using both coilovers, the KWs had the locking collars strip after 2 height adjustments in the rear, and dont ride as well as the Ohlins. The build quality of the Ohlins is top notch and the out of the box the damper settings are perfect for the street imo. Each click has a slightly noticeable difference, where on the KWs to get a difference that was noticeable took 2-3 clicks. |
| The Following User Says Thank You to villainous_frx For This Useful Post: | Petah78 (11-18-2021) |
#78 |
Off to the track!
Picked up a TRD Sport Meter trim for the Blitz gauges. Not sure what I am going to put in the 3rd opening yet, AFR/coolant temp/voltage?
![]() Also got some cheap side skirts and a replacement rear bumper. "car is staying as it is" lasted about 5 weeks... lol. |
| The Following User Says Thank You to villainous_frx For This Useful Post: | RToyo86 (12-03-2021) |
#79 |
Drives: 17 Asphalt 86
| The Following User Says Thank You to RToyo86 For This Useful Post: | villainous_frx (12-03-2021) |
#80 | |
Off to the track!
. I also had the headunit out already to sell, and a replacement OEM on the way from a friend. I suppose that isn't needed anymore though... now the trouble is finding a single din so I can still have some tunes on the road.
#81 | |
I'm second guessing my decision since I don't need android auto, and I have the screen turned off on the oem unit 99% of the time anyways ![]() I definitely failed at BF sales. The exhaust was worth it, since I saved just over $100. But Its backordered til February. |
#82 |
Off to the track!
Traded the OEM trunk liner for some STI Style skirts that look like they'll fit with layered double sided tape. Also installed the Blitz gauges into the TRD meter trim.
#83 |
Off to the track!
Went to the US for the holidays and came back with an Autopower half cage/roll bar. Going to paint it white once the weather warms up. Also got a reverse lockout from Aliexpress for like $3. Metal + no logo, and wayyyy cheaper than the offerings from Raceseng/Perrin.
#84 |
Off to the track!
Over the weekend I picked up a JVC KD-X270BT headunit + Scosche wiring harness from Crappy Tire and set it up for install. The harness will be trimmed down and all excess wires will be capped off in a more permanent way once in the car. As for mounting, I am considering just stashing it in the glove box, as music volume can be controlled via phone using Bluetooth/AUX. This option is TBD.
| Beginner STX Build Whiteout FRS Build Thread | Hachi86Roku | Tracking / Autocross / HPDE / Drifting | 21 | 03-31-2020 07:52 PM |
| [B is for Build] BRZ resurrection build | im_topher | Member's Car Journals | 49 | 03-05-2018 09:41 AM |
| HKS stroker kit build going onto edelbrock SCd e85 FRS - build questions | Corradooo | Engine, Exhaust, Transmission | 2 | 11-25-2017 07:16 PM |
| Superpenguin's "Not Another Build Thread!" Build Thread | superpenguin | Member's Car Journals | 7 | 06-17-2015 04:00 PM |
| No build date on passenger side sticker, how to determine build date? | BBYZILA | Scion FR-S / Toyota 86 GT86 General Forum | 5 | 01-20-2015 10:14 PM |
