Go Back   Toyota GR86, 86, FR-S and Subaru BRZ Forum & Owners Community - FT86CLUB > 2nd Gens: GR86 and BRZ > BRZ Second-Gen (2022+) — General Topics
BRZ Second-Gen (2022+) — General Topics General topics for the second-gen BRZ
Old 11-09-2021, 11:33 AM   #15
weederr33
Airborne at your service
weederr33's Avatar
Drives: '17 BRZ Series.Yellow
Originally Posted by trippinbillies40 View Post
Uh oh.... You just lost all credibility on this forum. Despite all posted evidence to the contrary, S30 has let us all know that Brembos are a must to avoid brake fade.
Damn Mike, how am I supposed to trust you now?
After all these years I believed Mike. Now it was all a lie and it took 30 to let us know.
MS, CSCS, TSAC-F, CPT
Old 11-09-2021, 02:49 PM   #16
Dylans47
Drives: Scion FR-S
I actually thought there was drama around Mike after those comments! LOL I thought no wayyyyy. But sounds like some shade against S30 over here.
Dylans47 is offline   Reply With Quote
Old 11-09-2021, 02:56 PM   #17
trippinbillies40
trippinbillies40's Avatar
Drives: '22 WRB
In case it's lost in translation, Mike is correct. Stock brake calipers and rotors with better pads and fluid are perfectly fine for track days.
trippinbillies40 is offline   Reply With Quote
The Following User Says Thank You to trippinbillies40 For This Useful Post:
wheelspeed (11-19-2021)
Old 11-12-2021, 10:39 PM   #18
Strat_FRS
Drives: 2015 FRS for daily and track use
Add a set of GT3 air guides and open up the heatshield a bit for brake heavy tracks.
Strat_FRS is offline   Reply With Quote
The Following User Says Thank You to Strat_FRS For This Useful Post:
Old 11-14-2021, 06:57 AM   #19
s30series
Drives: 2015 BRZ Series.Blue
Originally Posted by Goingnowherefast View Post
Eh I'd argue it depends how fast you are and what track it is. I can still fade R10's during a time trial session and that's with PP brakes and ducting.
If you're doing HPDE1/2/3 you're probably fine with just pads and fluid on the normal brakes. Also worth noting the primary benefit of "brembo" style calipers is the quick ease of pad swapping. I'd suspect a performance package will become an option later in the cars life cycle.
But you're wrong. Stock brakes with RBF660 and good pads are better engineered and have better heat capacity that AP Racing kits. The forum members agree.
Heat capacity and clamping surface area don't mean what you think they do with BRZ brakes.
Also we (the forum members) don't believe you fade the Brembos with that setup. We need to see proof. Back to back 150mph to 0mph MAY fade the BRZ brakes, but I'm not sure of a track where you can do that in a BRZ
s30series is offline   Reply With Quote
Old 11-14-2021, 09:15 AM   #20
Ernest72
Main benefit of a BBK besides looks is, the ability to quickly swap out brake pads from street to track for the casual track guy.
Old 11-14-2021, 08:54 PM   #21
slimfit
Drives: ‘22 BRZ
Just to reiterate, we’re 100% sure that gen 1 kits will fit…right? Kinda hoping to do the CTS-V swap!
slimfit is offline   Reply With Quote
Old 11-17-2021, 10:56 AM   #22
OkieSnuffBox
Drives: '23 BRZ Limited
No. The main benefit is larger, typically cheaper pads that last longer as well as rotor rings that last longer. And since they are two-piece rotors, they don't transmit as much heat to the hub/bearings which helps bearing life.
If you do HPDE/TT often, in the long run a BBK will pay for itself in the longevity of the pads/rings.
Quick brake pad swaps are just a side benefit.
Old 11-17-2021, 02:22 PM   #23
s30series
What do the larger pads do? Isn't that just more unsprung weight?
Old 11-17-2021, 02:50 PM   #24
OkieSnuffBox
Why don't you tell us why a thicker pad would last longer than a thinner one?
And the reason they are typically cheaper is because BBK manufacturers tend to use far fewer backing plates sizes and outside dimensions, IE, the same pad shape can be used across multiple different calipers vs possibly having to develop a pad shape for one specific or very few specific pad shapes.
Here is a real world example for you:
1990-2005 Miata's have three possible brake configurations from the factory. 1.6, 1.8, Sport brakes. That means 6 different backing plates are needed.
On my 1990 Miata, I installed Wilwoods at all four corners, same caliper, different piston sizes. 1 backing plate.
Old 11-18-2021, 12:46 AM   #25
s30series
Your original post said larger pads. Did you mean thicker?
Old 11-18-2021, 09:39 PM   #26
Ernest72
Still think BBK is mostly bling. Most of the cars spend 90% on the street and 10% on the track. For that little track time you can buy rotors, track pads and fluid and swap them out for pretty cheap. Then swap back to street pad.
Not that there is anything wrong with bling. I have 4 pots 2pots on my BRZ and WRX. They work and look nice and cheaper than BBK. Plus I can keep my 17 x7 wheels for the BRZ and 17x7.5 for the WRX that are nice and light. But no track for these cars, just spirited weekend runs.
Old 11-19-2021, 12:12 AM   #27
Kona61
Kona61's Avatar
Drives: ‘22 CWP
Agreed for most cases. Unless you track more than I’d say 5-10 times a year, the several thousand dollar investment isn’t worth it, especially for inexperienced drivers
Kona61 is offline   Reply With Quote
Old 11-19-2021, 09:00 PM   #28
wheelspeed
Large Member
Drives: Ford Flex, ZX9R, FLHTCUi, DRZ400S
Growing up racing BMX and continuing a bicycling hobby all my life, and motorcycle hobbies- now at 51 years old I've been upgrading toys to save weight for so long that it's a mental thing that simply brings some joy into my life. I don't have kids, but it must be like buying something nice for your kids. You couldn't argue any financial sense but it brings you happiness. So, if someone makes some 2-piece rotors and nice calipers that save 20 pounds or so from the front wheels, I'll probably have to do that even if I never go on a track. :-) Hopefully I'd be able to wait until the warranty is almost out.
- Have fun!
wheelspeed is offline   Reply With Quote
Performance Pack Brembo Rear Brakes Chuckable Suspension | Chassis | Brakes -- Sponsored by 949 Racing 23 07-20-2023 03:55 PM
Performance pack brakes Jdmuscle Suspension | Chassis | Brakes -- Sponsored by 949 Racing 7 03-11-2019 06:05 PM
FS; Brembo Brakes Performance PCKG 900 miles brz/frs sokol Brakes, Suspension, Chassis 21 02-27-2019 02:15 AM
RB Performance Brakes BBK for Scion FR-S & Subaru BRZ RB Performance Brakes Brakes, Suspension, Chassis 9 06-04-2014 06:52 PM
