Old 11-09-2021, 09:41 AM   #71
dragoontwo
dragoontwo's Avatar
Drives: 22 BRZ limited
Opie, thanks for doing the needful. It will be interesting to see what comes of this.
Old 11-09-2021, 12:11 PM   #72
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
Originally Posted by Opie View Post
Lots of measuring and testing to be done before assembly...as I said, using the FA24 heads may end up being the answer...but I'm sure going to see if the FA20 heads are a possibility first.
Short block did not arrive as expected yesterday...still waiting
I'd still call using the FA24 heads a possible win when you consider what a K swap costs. If it all still works that is, which I believe it will. I would be over the moon happy if this thing does at least 220whp with bolt ons. I am not looking for big power.
Old 11-09-2021, 12:42 PM   #73
Irace86.2.0
Irace86.2.0's Avatar
Drives: Q5 + BRZ + M796
Are you familiar with interference testing? I’ve never done it, but the K crowd does for cams and high compression builds. Apparently you have to apply puddy to the piston head and then torque down the head and then remove and analyze, and then repeat. It is fairly laborious.
Old 11-09-2021, 01:16 PM   #74
Lantanafrs2
Drives: 2013 frs red
Per the tech docs, FA24 heads use the same size exhaust valves (diameter & length), intake valves are the same diameter, but the length it a few mm longer. I assume to open a little more and allow slightly more air into the cylinder.
Or allow a taller port
Lantanafrs2 is offline   Reply With Quote
The Following User Says Thank You to Lantanafrs2 For This Useful Post:
Opie (11-09-2021)
Old 11-09-2021, 01:18 PM   #75
Lantanafrs2
More commonly known as clay checking. I've done it and its time consuming but necessary when using different cams, pistons, valve sizes etc.
Irace86.2.0 (11-09-2021)
Old 11-09-2021, 02:41 PM   #76
Irace86.2.0
Unless something has been vetted already.
Old 11-09-2021, 03:53 PM   #77
Tatsu333
Drives: 2020 BRZ Sport Tech RS
That's overall good news for performance with the FA20 heads then!
If you *did* end up going with the FA24 long block option, once you figure out everything that's necessary, you could maybe put together and sell a kit for adapting everything to the FA20 intake manifold and ancillaries.
Based on the interest in this thread, I'm sure there'd be at least a few takers...
Tatsu333 is offline   Reply With Quote
The Following User Says Thank You to Tatsu333 For This Useful Post:
alphasaur (11-09-2021)
Old 11-09-2021, 04:08 PM   #78
Brz-123
Yes, please think about doing that. A package / kit
Sent from my SM-G781B using Tapatalk
Brz-123 is offline   Reply With Quote
Old 11-09-2021, 04:31 PM   #79
Opie
Opie's Avatar
Drives: 2020 GMC Canyon Denali Diesel
Never done it, but have heard of it. Also will be using a borescope to see what happens....
2020 GMC Canyon Denali Duramax, 2021 Forester Sport, 2000 Subaru Legacy B4 RSK 5MT (JDM Import) and random 86 chassis rebuilds....
Opie is offline   Reply With Quote
The Following User Says Thank You to Opie For This Useful Post:
Old 11-09-2021, 04:34 PM   #80
Opie
Opie's Avatar
In other parts of the world....Subaru sells long block assemblies that would make this a much easier decision...but in the US you can buy all the parts and build an engine, or buy a complete engine assembly including exhaust manifold, intake manifold & accessories....not a long block.
Old 11-09-2021, 04:55 PM   #81
Opie
Opie's Avatar
Score, both engines use the same timing chains!
On using the FA24 cylinder heads....finding other issues, different High pressure fuel pumps, & mounts. May not be interchangeable. Also will need to find a solution to additional water lines that feed the cooler....
The Following 3 Users Say Thank You to Opie For This Useful Post:
FrickingReallySlow (11-10-2021), Irace86.2.0 (11-09-2021), jflogerzi (11-10-2021)
Old 11-09-2021, 04:56 PM   #82
Tatsu333
Yikes. I'm guessing that's the same for Canada, and I'm guessing the complete assembly is P-R-I-C-E-Y! Likewise trying to piece together complete FA24 heads with cams, etc.
Makes working with the FA20 heads definitely seem like a better option.
EDIT (2): Found a listing on one dealer's parts website that said "Engine Assembly - Long Block" priced at $7,393.82 US. Contacted the dealer for more info, and they said it isn't available to order and won't be available period very shortly after the 2022's start heading off of dealer lots. Basically, they're only available to dealers in case of a DOA motor with a car they receive, or something along those lines, and once cars start getting into customer hands, the availability for even that will go away, and as Opie said, only short blocks will be available.
Regardless, that list price is more than the price of every supercharger kit on the market...LOL. Heck, the difference in price vs. the short block is about $5,500. I can definitely see a STRONG cost argument for sticking with the FA20 heads, even without all the other complications.
Yay...and ouch.
Last edited by Tatsu333; 11-10-2021 at 05:51 PM. Reason: Removed link for long block and updated info
Old 11-09-2021, 05:14 PM   #83
Opie
Opie's Avatar
May have just found something useful....the FA24DIT pistons are a flat top design...they are not domed like the FA20/24 N/A engines.....possibly a fix for 2 issues....FA20 N/A cylinder head clearance and not increasing compression ratio......
Goingnowherefast (11-09-2021)
Old 11-09-2021, 05:28 PM   #84
Tatsu333
Interesting... So, flat piston with just a minimal blending of the combustion chambers in the heads to allow for the bigger bore (removing the stepped profile). It'd be interesting to see how close to the factory 12.5:1 C/R you could achieve with a flat-topped piston.
Could work, but is there a performance (E.G. combustion control) reason for the pent-roof / domed profile of the FA20 and FA24 pistons, or is it just to increase compression? My guess from the fact that the peak of the dome on both pistons is offset to one side is that it also helps with combustion control, although that *could* just be due to the angles of the intake vs. exhaust valves.
EDIT: For those that aren't familiar with the idea of piston shape controlling cumbustion, here's an article that talks a bit about the concept of the offset dome being used to control combustion for both power and detonation resistance. It's talking about an even more complex design, the "Endyn Roller Wave" produced by the company, but explains the basic principle pretty well. http://www.theoldone.com/articles/rollerwave-intro/
Thinking further about it, if the dome is offset for combustion control and the valves have been moved further outward in the FA24 head, it's possible the FA24 piston's offset would be in the wrong place to work properly with the FA20 valve placement. That said, it probably wouldn't be that big a deal as long as the peak didn't end up too far inboard of the intake valves (which I think would cause the mixture to move the wrong way) and it would likely be the opposite - further outboard than the FA20 piston.
That could be another argument to go for a flat-topped piston, I guess...
Last edited by Tatsu333; 11-09-2021 at 06:25 PM. Reason: Added info on Roller Wave piston article and thoughts on piston peak location
Opie (11-10-2021)
FA20 vs FA24 Zata Engine, Exhaust, Transmission 15 06-01-2023 10:18 AM
FA24 In-Depth Look Kona61 GR86 General Topics (2nd Gen 2022+ Toyota 86) 36 10-11-2021 08:27 AM
Second Gen Swap? FA24 AutoNewb Engine Swaps 86 07-06-2021 10:55 AM
FA24 Mix n Match RiceCracker86 Engine, Exhaust, Transmission 1 04-18-2019 03:59 PM
Incoming... MisterSheep Off-Topic Lounge [WARNING: NO POLITICS] 19 04-02-2016 12:33 AM
