Old 11-04-2021, 04:37 PM   #1
Opie
Opie's Avatar
Drives: 2020 GMC Canyon Denali Diesel
Likely the first FA2/4 hybrid incoming
Ordered a brand new FA24 short-block once the part numbers were published. It is due to arrive November 15th.
Plan is to build using the FA24 short-block with FA20 heads, similar to the EJ20/25 hybrid builds done on the older WRX's. This will be installed in my 2013 BRZ (using the 2015 wire harness, coils, sensors, etc) and run with an Ecutek tune.
Lots of unknowns with this...good news is the cylinder heads share the same oil and coolant passages and the head gaskets, when laid on top of one another are identical other than the bore size. The short block external size is identical to the FA20, The cylinder heads are very, very similar to one another (FA24 uses slightly different intake port sizes and shape and has a slightly longer intake valve length, and there are some changes to the oiling system on the FA24 that may require some other parts mingling between the two...
Currently on order:
FA24 Short-block
FA24 Engine Gasket set
FA20 Rocker cover gaskets (different than FA24 because it uses plastic rocker covers)
FA20 Intake Manifold gaskets
Expect to need, haven't ordered:
FA24 front timing cover/oil pump
FA24 Upper oil pan
FA24 Oil Baffle
FA24 Oil Pickup
FA24 Oil Pan (Very similar looking, but different part number)
Watch along and see what happens...if it all goes together, if it runs, what parts from each series are needed, what power can be wrangled out of it and more....
So far I've started tearing down the donor FA20 waiting for the FA24 parts to arrive....
2020 GMC Canyon Denali Duramax, 2021 Forester Sport, 2000 Subaru Legacy B4 RSK 5MT (JDM Import) and random 86 chassis rebuilds....
Opie is offline   Reply With Quote
The Following 46 Users Say Thank You to Opie For This Useful Post:
AgentBlue243 (11-04-2022), alphasaur (11-04-2021), bcj (11-06-2021), Boomerang (11-05-2021), boy_racer (12-05-2021), BrahmaBull1990 (11-04-2021), chaoskaze (01-09-2023), Code Monkey (11-04-2021), DarkSunrise (11-04-2021), endless_pain (11-08-2021), femaledog (11-05-2021), flippy (11-09-2021), gkubed (07-05-2022), Goingnowherefast (11-05-2021), Grateful Dave (12-02-2021), Irace86.2.0 (11-04-2021), JD001 (07-04-2022), Jdmjunkie (11-04-2021), jkamelo (01-10-2022), JSIdriver51 (11-04-2021), kevaughan (01-07-2022), Kiske (11-09-2021), Lonewolf (11-06-2021), ML (11-05-2021), MrSkubi (11-05-2021), new2subaru (11-06-2021), NoHaveMSG (11-04-2021), pope (11-04-2021), sato (11-09-2021), soundman98 (11-04-2021), Spankopotomous (11-04-2021), Spawn_Of_Creation (01-05-2022), Spuds (01-25-2022), Stonehorsw (11-10-2021), SuperTom (02-23-2022), surfwaxsmitty (06-19-2022), T-Steve (11-07-2021), Takumi788 (11-05-2021), tato.valverde (11-10-2021), Tatsu333 (11-07-2021), Teseo (12-16-2022), villainous_frx (11-05-2021), whataboutbob (07-05-2022), Xero-Limit (12-28-2021), Z06ZN6 (11-05-2021), ZDan (11-04-2021)
Old 11-04-2021, 04:57 PM   #2
Ashikabi
Ashikabi's Avatar
What's the purpose of using the FA20 heads? So we know that they flow better than the 24s?
Sent from my ONEPLUS A5010 using Tapatalk
Old 11-04-2021, 05:11 PM   #3
Irace86.2.0
Irace86.2.0's Avatar
Drives: Q5 + BRZ + M796
When I saw Hybrid I thought you connected an electric motor between the engine and transmission. This a Frankenstein like the K20/K24. Glad to see someone doing this swap so soon. I’m sure this thread will be super helpful for many people.
The Following 4 Users Say Thank You to Irace86.2.0 For This Useful Post:
Dzmitry (11-09-2021), Opie (11-05-2021), Rustyoid (04-21-2022), sato (11-09-2021)
Old 11-04-2021, 05:55 PM   #4
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
Didn't realize the short block part numbers where available. I will be watching this intently. Curious if the 2.4 piston clears the cylinder head and what the CR would be. There looks to be plenty of room to mill them if need be.
Old 11-04-2021, 06:42 PM   #5
FrickingReallySlow
Drives: 2015 FR-S
subbed! living vicariously through all you trailblazers!
Biggest question I think is the timing cover! better hope no holes were changed on the upper oil pan/heads
FrickingReallySlow is offline   Reply With Quote
Old 11-04-2021, 06:43 PM   #6
Swift
I just Drive.
Swift's Avatar
Drives: in the womb still
Unless you know one head flows more than the other there is no point unless chamber artificially raises compression? Just flow the K24 versus k20 heads before you get carried away.
-Waiting patiently for the right FT-86...
-92' Acura Legend 5spd coupe twin turbo project
Swift is offline   Reply With Quote
Old 11-04-2021, 06:59 PM   #7
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
Yeah I agree about the timing cover. I was kind of surprised to see the upper oil pan/pickup change.
Old 11-04-2021, 07:10 PM   #8
Opie
Opie's Avatar
Per the service manual, all the mounting holes, etc are in the same place. Will know for sure once it arrives.
The Following User Says Thank You to Opie For This Useful Post:
Old 11-04-2021, 07:11 PM   #9
FrickingReallySlow
Drives: 2015 FR-S
Don't think this is for flow reasons. Its a cheaper alternative to get a "built" block for FA20 but also gain 400cc. if successful you get to use the same cam sensors /vvt /engine harness and FA20 ECU that is already supported for tuning. I wonder if the wrx STI FA24 short block might even fit in here
It could become a good upgrade for Gen1 instead of getting like a crawford / IAG built block
Also his FA20 heads are probably free haha... so many blown FA20s
The Following 7 Users Say Thank You to FrickingReallySlow For This Useful Post:
endless_pain (11-08-2021), Goingnowherefast (11-05-2021), NoHaveMSG (11-04-2021), Opie (11-04-2021), rice_classic (11-10-2021), Spankopotomous (11-04-2021), Takumi788 (11-05-2021)
Old 11-04-2021, 07:12 PM   #10
Opie
Opie's Avatar
Had them available, cost savings and compatibility with the '13-'16 harnesses, OCV triggers, etc.
Old 11-04-2021, 07:26 PM   #11
Ashikabi
Ashikabi's Avatar
That makes sense
Old 11-04-2021, 08:20 PM   #12
jflogerzi
jflogerzi's Avatar
Subbed!!
2013 Series 10 FRS #553
Old 11-04-2021, 09:52 PM   #13
FR-S2GT86
Master Collaborator
FR-S2GT86's Avatar
I shall dub this build.....
Franken-Opie
Good luck!
My pubes are shaped like the number 86. There for I’m car. Derp
Count to muffens and call again.
I’m 40. So....... say hi to your sisters or daughters.
FR-S2GT86 is offline   Reply With Quote
The Following User Says Thank You to FR-S2GT86 For This Useful Post:
Old 11-04-2021, 11:58 PM   #14
BrahmaBull1990
Howdy
BrahmaBull1990's Avatar
Drives: 2020 BRZ PP
Yesss!
There's a point at 7,000 RPM... where everything fades. The machine becomes weightless. Just disappears. And all that's left is a body moving through space and time. 7,000 RPM. That's where you meet it. You feel it coming. It creeps up on you, close in your ear. Asks you a question. The only question that matters. Who are you?
BrahmaBull1990 is offline   Reply With Quote
FA20 vs FA24 Zata Engine, Exhaust, Transmission 15 06-01-2023 10:18 AM
FA24 In-Depth Look Kona61 GR86 General Topics (2nd Gen 2022+ Toyota 86) 36 10-11-2021 08:27 AM
Second Gen Swap? FA24 AutoNewb Engine Swaps 86 07-06-2021 10:55 AM
FA24 Mix n Match RiceCracker86 Engine, Exhaust, Transmission 1 04-18-2019 03:59 PM
Incoming... MisterSheep Off-Topic Lounge [WARNING: NO POLITICS] 19 04-02-2016 12:33 AM
