Old 12-30-2020, 02:53 PM   #813
RFB
RFB's Avatar
Drives: FRS
Originally Posted by RFB View Post
My discs wore out before the track pads did, but the pads are good for many more track days. (and I used them full blast all out always) !
The street pads are quiet on new discs with light dusting on the street.
Heavy dusting when tracking, with no rust in the dust or on the wheels when left on for a length of time.
Dust cleans easily compared to RR race pads.
The pads do not give the ultimate braking power of BP 20's.
They do fade on the track when pushed, compared to the track pads.
They can be tracked but from the large amount of dust they wont last long.
I will report on how long they are usable at the track after they wear (cheaper to replace pads).
Further to -
2 track days and day to day (Hard) driving, 50 percent pad wear. Most of that wear was the 2 track days.
No noise after hard use on track until day to day driving removes the track layer on the discs.
After the pad taper wore off to full pad contact squeaks returned randomly, sometimes when cold, wet , sometimes when warm, but only at the very last tiny bit of light brake application (bumper to bumper slow driving). No squeaks when used hard.
This is with the competition lightweight stage 2,3 lightweight discs.
RFB is offline
Old 12-30-2020, 09:20 PM   #814
jflogerzi
jflogerzi's Avatar
I have a full set of bp-20s that have a lot of life left. I moved to carbotech pads. They are for the sport fronts and rear bbk. Msg me if interested
2013 Series 10 FRS #553
jflogerzi is offline
Old 12-31-2020, 02:01 AM   #815
Anthonyc777
Drives: White Toyota 86
Originally Posted by jflogerzi View Post
I have the sports both front and rear. I can provide some measurements if need be
I already have the sports as well, just trying to find a comprehensive list of what wheels fit the RR kit is a bit challenging. I was wondering/hoping the PP brembos are relatively close so that we could use their fitment thread as a basis point.
Anthonyc777 is offline
Old 01-16-2021, 05:47 PM   #816
Anthonyc777
Just bumping this thread with a glamour shot
The Following User Says Thank You to Anthonyc777 For This Useful Post:
jflogerzi (01-18-2021)
Old 01-18-2021, 10:19 PM   #817
jflogerzi
jflogerzi's Avatar
Super clean
Old 01-27-2021, 01:54 PM   #818
Anthonyc777
New Konig Hexaform 17x9 +40 clears the Sport Calipers! It clears them by a little over half an inch and with the sport calipers already being on the wider side these wheels should clear the other RR Racing BBKs.
The Following 3 Users Say Thank You to Anthonyc777 For This Useful Post:
jflogerzi (03-30-2021), kevaughan (10-16-2021), Rosticles (02-01-2021)
Old 05-19-2021, 06:19 PM   #819
jflogerzi
jflogerzi's Avatar
Adding 2 things:
On the Sport BBK and rear BBK if you break one of the tiny black bleeder screws, the WW replacement part is Wilwood Disc Brakes 220-6069 - Wilwood Brake Bleeder Screws.
Also Apex ARC-8 17x9 ET35 clears Sports with miles of room
The Following User Says Thank You to jflogerzi For This Useful Post:
Takumi788 (05-20-2021)
Old 10-11-2021, 09:41 PM   #820
Rafi@RR-racing
Rafi@RR-racing's Avatar
Drives: Toyota GT86
Bumping this thread to the top.
My name is Justin and I have been working with RR Racing. Rafi has been really busy in the shop with a lot of new developments so this account has been pretty quiet. Our company has grown widely into the Lexus and Porsche space but these FT86 brake kits have been part of the backbone of this company until this day.
If you have any questions or have been considering an upgrade please don't hesitate to message me.
Rafi@RR-racing is offline
The Following 5 Users Say Thank You to Rafi@RR-racing For This Useful Post:
blsfrs (10-12-2021), DAEMANO (11-02-2021), fryfun (10-12-2021), kevaughan (10-16-2021), Takumi788 (10-15-2021)
Old 11-02-2021, 03:40 PM   #821
Strat_FRS
Drives: 2015 FRS for daily and track use
Hi Justin, we have a Tuner4 class time attack FRS and the stock brakes are actually not too bad with no added downforce and no forced induction as we only do 3 hot laps. We run GT3 air guides in the front and HP+ pads all around.
Your sport kit for the front looks to be a good match for our setup and improve brake modulation, reduce weight and improve overall performance. How will the brake bias be maintained and what pads do you recommend on the front to match our HP+ pads in the rear on OEM rear calipers?
Strat_FRS is offline
Old 11-02-2021, 04:25 PM   #822
Rafi@RR-racing
Drives: Toyota GT86
With HP+ in the rear, you can go with Wilwood BP20 up front with our kit. HP+ is not that high friction pad -- I am surprised that it is enough for your speed.
We would recommend our Stage 2 or Stage 4 kit for the front with our Sport Performance kit in the rear for the best bias (see the chart -- the most right column). You can run either BP20 or BP30 pads for front and rear. This setup was originally designed for Phil Grabow's Element Tuning Time Attack FRS (over 500 hp), but he had our Stage 4 rear kit that we no longer sell (but the Sport Performance has bias very close to our Stage 4 as you can see from the chart).
Old 11-02-2021, 05:03 PM   #823
Strat_FRS
Thanks for the insight. The cooling ducts really help up front - we have done this on a lot of cars - greatly extended the performance of OE components with cooling which from the factory is not adequate.
Which kit and what pads are used in the RRR Front/OE Rear setup (the 4th from both the right and left)?
Old 11-02-2021, 05:07 PM   #824
Rafi@RR-racing
Drives: Toyota GT86
The pads are not important as the bias will be the same ratio with matching pads. Our Stage 2 and Sport Performance front kits will have the same front/rear bias.
Old 11-02-2021, 05:24 PM   #825
Strat_FRS
Between the sport and stg2 which do you recommend and why? The price is relatively close.
Old 11-02-2021, 05:37 PM   #826
Rafi@RR-racing
Drives: Toyota GT86
If Stage 2 fits, then I recommend Stage 2. It has 6 pods vs 4 pods of Sport Performance, and Stage 2 allows for thicker race pads.
big brake kit, competition, track
AP Racing brake systems in development track_warrior Suspension | Chassis | Brakes -- Sponsored by 949 Racing 872 09-17-2017 07:43 PM
Megan Racing Coilovers - Street / Track / EZ STREET - Starting at $699 Shipped GuerillaRacing Brakes, Suspension, Chassis 149 05-12-2015 05:53 PM
AP Racing Factory Big Brake Kit, NOT Competition Lonergt Suspension | Chassis | Brakes -- Sponsored by 949 Racing 0 08-25-2013 04:51 PM
Official street racing thread. All street racing goes here! bkblitzed Off-Topic Lounge [WARNING: NO POLITICS] 8 07-19-2013 11:31 AM
Essex/AP Racing Competition Brake System in Development JRitt Brakes, Suspension, Chassis 1 06-14-2012 01:32 PM
