Old 11-02-2021, 08:54 AM   #29
ZDan
ZDan's Avatar
Drives: '23 BRZ
Originally Posted by Bonburner View Post
damn you hit 275F?
I can't get it past 100C/212F with my engine sitting +4k rpm for 20 minutes runs
With just the Forester water/oil cooler? Hmmm... Where are you reading temperature from, and what sender and gauge (2013 so no factory gauge, right)? I'm going by the factory '17 oil temp gauge, which does jibe with ECUtek datalogging.
212F seems quite low even for constant 75mph on the highway! I'd expect at least 255F at the track with the factory Forester cooler based on reports I've seen, and some report oil temps at the track barely any lower vs. no cooler at all.
Old 11-02-2021, 11:33 AM   #30
Dzmitry
Dzmitry's Avatar
Drives: 2018 Subaru BRZ Limited with PP
Doesn't seem low for streets I would say. Initially I had thought he was completely stock. But with the forester cooler, it seems to do a nice job taking care of oil temps that aren't on the rise quickly. As I said earlier, I see no more than 225-230F when cruising at 3.5K+ RPM on a warm-hot day. It doesn't change much on the hottest days either, still don't see it tip above 230F. So I can see how the forester cooler would be able to upkeep with that as the coolant stays fairly steady with consistent airflow.
Dzmitry is offline   Reply With Quote
Old 11-02-2021, 04:11 PM   #31
Bonburner
6/22/12-2/6/24
Bonburner's Avatar
OEM oil temp data sent to the ECU, read by my torque app
https://www.ft86club.com/forums/show...00&postcount=2
and this is the location:
https://www.ft86club.com/forums/show...77&postcount=9
this was at buttonwillow when it was like 91°F outside
The Following 2 Users Say Thank You to Bonburner For This Useful Post:
Dzmitry (11-03-2021), ZDan (11-02-2021)
Old 11-03-2021, 09:37 AM   #32
Dzmitry
Dzmitry's Avatar
I've known for quite some time now that the Subaru oil cooler is what I wanted to get, I just don't know why I have been holding off so long... I think it's time to end the wait.
One quick question for you, as I've read on this topic a few times in the past. Which routing did you take, to the TB?
Old 11-04-2021, 01:13 AM   #33
Bonburner
6/22/12-2/6/24
Bonburner's Avatar
TB - much easier and shorter routing. Only issue was the different port sizes at the throttle body made for some annoying coolant leaks during testing
The Following User Says Thank You to Bonburner For This Useful Post:
Dzmitry (11-04-2021)
Old 11-04-2021, 07:33 AM   #34
Dzmitry
Dzmitry's Avatar
Gotcha, yes I've read about this and will purchase an adapter to not deal with the issue. Appreciate the info!
Old 12-02-2021, 10:16 PM   #35
jeepmor
Drives: 84 CJ7, 08 Duramax, 2014 FRS
Subbed for later.
I run the 0-40W Euro spec Mobil 1 since HKS supercharger kit stated higher viscosity oil was required for the kit. No issues, but I also don't have an oil temp gauge. Oil looks really good still during intervals, no technical analysis done. As for the tiny bit of fines that come out, they appear to be same or less than pre-boosted state.
jeepmor is offline   Reply With Quote
Thicker sway bars or leave OEM...? Aztec Suspension | Chassis | Brakes -- Sponsored by 949 Racing 20 09-07-2021 02:54 PM
Has anyone fitted a thicker OEM rear bar yet from another Subaru? ft_sjo Suspension | Chassis | Brakes -- Sponsored by 949 Racing 22 10-24-2016 07:05 PM
Lucas Oil Oil Stabilizer rev3la7ion BRZ First-Gen (2012+) — General Topics 8 06-10-2014 05:24 AM
thicker headgaskets Calum Forced Induction 17 02-15-2013 06:51 AM
Thicker oil for turbo? Synack Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 8 08-27-2012 02:58 AM
