Cosmetic Modification (Interior/Exterior/Lighting) Discussions about cosmetic mods. |
Drives: BRZ limited
Sti molded stripe install
Hi guys,
Just wanted to ask what the best way is to install the molded sti red molded stripe on the bumper. Will the original tape stick strong enough or should I use something with it together. Thanks Sent from my iPhone using Tapatalk |
#2 |
Drives: '20 BRZ tS (15/300) / '09 Scion tC
It should hold up if you start with a clean surface stripped of dirt and wax. You will get the best results if you take your time and don't rush it.
The Following User Says Thank You to 2020BRZtS For This Useful Post: | Busybee (10-22-2021) |
#3 | |
Drives: BRZ limited
Did not have time to install and the temperature outside has dropped. I don’t know wether the tape on the piece is less or more stronger than the 3M. Will the outside temperature have a dramatic effect. Should a heat gun help? Sent from my iPhone using Tapatalk |
#4 |
Drives: 2015 Subaru BRZ Series.Blue #709
Should work on it when the outside temperature is perfect. The best result is to have the vehicle in the sun, and you will have a dramatic effect if it's too cold. Heat gun should help, but you would have to take your time heating the bumper a bit and slowly peeling the tape as you go. The tape should hold if you bought the part from the local/online OEM dealers.
The Following User Says Thank You to ZC6_STi For This Useful Post: | Busybee (10-31-2021) |
Molded fiberglass enclosures | Cwayland51 | Electronics | Audio | NAV | Infotainment | 0 | 09-06-2016 01:19 PM |
BRZ rocket bunny with molded fenders | calis5nest | Cosmetic Modification (Interior/Exterior/Lighting) | 72 | 01-07-2016 02:20 PM |
Trunk sub box molded to fit (plexi or wood) | Matey | Electronics | Audio | NAV | Infotainment | 14 | 06-11-2015 11:47 AM |
FS GA: OEM Molded Mudguards | 86TruenoFRS | Exterior Parts (Aero, Lighting, Etc.) | 11 | 01-09-2014 06:53 PM |
Molded Decklid/ Spoiler | TurtleFactory | Scion FR-S / Toyota 86 GT86 General Forum | 13 | 03-04-2013 05:40 PM |
