Old 10-07-2021, 04:46 PM   #351
ML
ML's Avatar
Drives: 13 White MT FR-S
do you know if the EPS will run with just the power and signal wires like a prius EPS?
Old 10-07-2021, 08:27 PM   #352
DIY
DIY's Avatar
Drives: BRZ, WRX
I know it will run in failsafe mode with a decent amount of constant assist.
There is a guy selling a cheap kit on ebay that allows you to add a dial to adjust the amount of assist but I'm not confident it will work after talking to another guy on Instagram who is running his through his Motec ECU.
Either way I will have a powerful enough ECU to control it.
Follow me on Instagram: @brzdiy
My Build Thread
DIY is offline   Reply With Quote
The Following 2 Users Say Thank You to DIY For This Useful Post:
ML (10-09-2021), RedReplicant (09-17-2022)
Old 10-09-2021, 05:31 AM   #353
DIY
DIY's Avatar
Drives: BRZ, WRX
More progress on the manifold, finished making the runners and tacked it all together for test fitting on the car.
It's been a challenge for sure but I'm very happy with the progress so far!
My Build Thread
The Following 10 Users Say Thank You to DIY For This Useful Post:
ACT86 (10-09-2021), Ash_89 (10-09-2021), Busybee (10-15-2021), Code Monkey (10-09-2021), DustinS (10-14-2021), Dzmitry (10-20-2021), flippy (10-29-2021), Irace86.2.0 (10-10-2021), Jdmjunkie (10-09-2021), RToyo86 (10-29-2021)
Old 10-15-2021, 09:13 PM   #354
Kiske
Kiske's Avatar
Drives: RX-7 / BRZ
What merge collector did you use?
Old 10-16-2021, 09:03 AM   #355
DIY
DIY's Avatar
Drives: BRZ, WRX
The collector and elbows are all Hypertune Hypex.
My Build Thread
The Following User Says Thank You to DIY For This Useful Post:
Kiske (10-16-2021)
Old 10-25-2021, 04:04 AM   #356
DIY
DIY's Avatar
Drives: BRZ, WRX
The turbo manifold is finished.
There are so many hours in this, such a small piece but so complex to fabricate. If I had my time again I may have just bought one but that is not in the spirit of this build.
Having never welded stainless steel before, this was probably not the best starting point and I was certainly outside my comfort zone. I have followed best practice throughout the fabrication, everything was back purged during welding, fit up was tight, some of my welds probably got a little hot but nothing too extreme. I am confident the manifold is going to hold up to many years of abuse even though it is never going to get featured on weldporn.
My Build Thread
The Following 12 Users Say Thank You to DIY For This Useful Post:
Ash_89 (10-26-2021), Boomerang (10-25-2021), Code Monkey (10-25-2021), DustinS (10-25-2021), Dzmitry (10-28-2021), flippy (10-29-2021), Irace86.2.0 (10-30-2021), Jdmjunkie (10-25-2021), NoHaveMSG (10-25-2021), RedReplicant (09-17-2022), RToyo86 (10-29-2021), TunaNoCrust (10-25-2021)
Old 10-27-2021, 04:00 AM   #357
DIY
DIY's Avatar
Drives: BRZ, WRX
I've started on the exhaust system, its SuperGT inspired side exit.
My Build Thread
The Following 11 Users Say Thank You to DIY For This Useful Post:
Busybee (11-15-2021), Code Monkey (10-27-2021), DustinS (11-06-2021), Dzmitry (10-28-2021), flippy (10-29-2021), Irace86.2.0 (10-30-2021), Jdmjunkie (10-27-2021), jflogerzi (10-28-2021), MotoX16 (10-27-2021), MrSkubi (10-28-2021), NoHaveMSG (10-29-2021)
Old 10-29-2021, 02:58 AM   #358
DIY
DIY's Avatar
Drives: BRZ, WRX
A video showing the exhaust. I will be adding more to it later, I just needed this bit done so I can start on the steering.
https://www.instagram.com/reel/CVmGa...dium=copy_link
My Build Thread
Old 10-29-2021, 09:18 AM   #359
all4spl
I'm not understanding the idea behind the exhaust.
all4spl is offline   Reply With Quote
Old 10-29-2021, 04:39 PM   #360
DIY
DIY's Avatar
Drives: BRZ, WRX
It will be something like this.
My Build Thread
The Following 6 Users Say Thank You to DIY For This Useful Post:
DustinS (11-06-2021), Dzmitry (11-01-2021), Jdmjunkie (10-30-2021), jflogerzi (10-30-2021), NoHaveMSG (10-29-2021), villainous_frx (10-30-2021)
Old 11-02-2021, 11:35 PM   #361
ozafar
Drives: 2015 Scion FRS Release Series 1.0
I assume the main reason you are doing the side exit is to have a uninterrupted flow for a proper rear diffuser?
ozafar is offline   Reply With Quote
Old 11-03-2021, 12:28 AM   #362
jflogerzi
jflogerzi's Avatar
Because racecar. Less fabrication and weight reduction.
Sent from my Pixel 5a using Tapatalk
2013 Series 10 FRS #553
Old 11-05-2021, 12:41 AM   #363
Irace86.2.0
Irace86.2.0's Avatar
Drives: Q5 + BRZ + M796
I added you to our k-swap owners thread
The Following 2 Users Say Thank You to Irace86.2.0 For This Useful Post:
DIY (11-05-2021), DustinS (11-06-2021)
Old 11-05-2021, 02:08 AM   #364
DIY
DIY's Avatar
Drives: BRZ, WRX
There is no space under the car for an exhaust and under the rules it must exit rearward of the midpoint of the wheelbase. So what I have come up with is the simplest, shortest exhaust system possible considering the constraints.
I could have run it inside the full length of the car but its extra weight and it gets hot here in Australia.
My Build Thread
