Old 10-22-2021, 02:09 AM   #23367
rbfr.s
rbfr.s's Avatar
Drives: 2014 FR-S
@jflogerzi buddy club CF race wheel! Should be in stock on 86 Speed.
Professional Car Breaker
rbfr.s is offline   Reply With Quote
The Following User Says Thank You to rbfr.s For This Useful Post:
Wally86 (10-22-2021)
Old 10-22-2021, 07:10 PM   #23368
Wally86
Be Kind
Wally86's Avatar
Drives: 2020 86
I really wanted bulbs I could replace for less than $1000 when they go out that didnt' require bumper removal and entire lighting assembly replacement so...
[Insert clever signature here]
IG | WhiskyBlog | Photography
Wally86 is offline   Reply With Quote
The Following 3 Users Say Thank You to Wally86 For This Useful Post:
NLSP (10-24-2021), NoHaveMSG (10-25-2021), rbfr.s (10-22-2021)
Old 10-24-2021, 04:57 AM   #23369
alex87f
Meow
alex87f's Avatar
Drives: GT86 (now sold)
What are these? I rather like them :-D
Also just curious, what did you sell the LEDs for?
alex87f is offline   Reply With Quote
Old 10-25-2021, 05:58 AM   #23370
Wally86
Be Kind
Wally86's Avatar
Drives: 2020 86
Vland makes the headlights.
I didn't sell the LEDs but they do sell for a mint. I just boxed them up. I don't like the idea of having to spend $1000 usd for a new headlight if one of the LEDs fails so going with these headlights that use $20 bulbs seems like a better idea to me. The light output isn't as good but it's not so drastically different than I'm bothered by it.
Old 10-25-2021, 02:35 PM   #23371
Decep
Drives: 2013 FR-S Series 10
I recently did STI engine mounts and mtec shifter springs. The mounts did tighten engine response up a smidge and did reduce oscillation when getting onto the throttle which is good, and i feel no difference in nvh.
The shifter springs totally change the feel of the shifter and made everything feel much tighter, great mod. I also have the perrin rear shifter bushing. Would adding the whiteline transmission insert be too much for a daily driver alongside the perrin bushing?
2013 FR-S 10 Series ~75k (SOLD)
RCE SS-1 Coilovers
Corsa Catback
Edelbrock Supercharger installed @ 50k
The Following User Says Thank You to Decep For This Useful Post:
Wally86 (10-25-2021)
Old 10-25-2021, 07:05 PM   #23372
FrickingReallySlow
Drives: 2015 FR-S
btw, did you notice any decrease in shift rattle after installing the perrin rear shifter bushing?
FrickingReallySlow is offline   Reply With Quote
Old 10-25-2021, 10:48 PM   #23373
Decep
I dont really have much shifter rattle before or after. Only time i get it really is when im in a lower gear, and i let off the throttle and coast at higher rpms.
Theres basically no downside to the perrin bushing imo.
RCE SS-1 Coilovers
Corsa Catback
The Following 2 Users Say Thank You to Decep For This Useful Post:
FrickingReallySlow (10-25-2021), Wally86 (10-26-2021)
Old 10-26-2021, 07:36 AM   #23374
StraightOuttaCanadaEh
Wes
Yes. It really does telegraph the vibration to the cabin. I'm actually planning to get rid of my insert and the bushing and just replace them both with an STI trans mount. Apparently that gives you the same benefits but without the associated NVH.
Then again, I have a 1 piece aluminum driveshaft currently, which does exacerbate the noise problem. Had to get rid of the diff bushings, it was getting to be too much and the driveshaft would vibrate as well.
Edit: forgot to add that I also have the Perrin engine mounts, which have a lot more NVH than the STI units from what I'm reading here
Instagram: @gt86ws
Old 10-26-2021, 10:02 AM   #23375
RToyo86
RToyo86's Avatar
Drives: 17 Asphalt 86
I did notice small NVH with the whiteline bushing insert via the trans. It's pretty miniscule but it is there at certain RPM. I notice it most around 2500.
Well worth the reduction in slop. STi mount seems like a solid alternative though the cost of the insert is good bang for buck.
Old 10-30-2021, 03:11 AM   #23376
Cedric
Cedric's Avatar
Drives: 2013 Scion FR-S 10 Series
WHAT DID YOU DO TO YOUR FRS TODAY?
Replaced my Sparco L360 with a Momo Montecarlo
The retainer plate for the horn button does not sit flush with the Splash hub, so I don’t have a horn, or a horn button and it’s quite annoying. I still like the look and feel of it regardless.
Cedric is offline   Reply With Quote
Old 10-30-2021, 08:39 AM   #23377
JD001
JD001's Avatar
Drives: Subaru BRZ
I am hoping that it's my eyes or my computer, but the wheel looks wonky...
The Following User Says Thank You to JD001 For This Useful Post:
Cedric (10-30-2021)
Old 10-30-2021, 12:30 PM   #23378
jflogerzi
jflogerzi's Avatar
If you want whine like a racecar then do it. If not skip the that combo and go for just one or the other but not both. It does break in and you get used to it. I have the same combo.
2013 Series 10 FRS #553
Old 10-30-2021, 02:17 PM   #23379
Cedric
Cedric's Avatar
It looks a little weird in the pic but I can assure you it’s fine hahaha
Sent from my iPhone using Tapatalk Pro
The Following User Says Thank You to Cedric For This Useful Post:
JD001 (10-30-2021)
Old 10-30-2021, 02:19 PM   #23380
RToyo86
RToyo86's Avatar
Key bling via AliExpress to cover up my dusty key.
