Old 10-13-2021, 12:08 AM   #1
hachigoku
Drives: BRZ, E90 M3
P0303 - Engine Struggling and Rumbling
Hi! Need some help with a returning P0303.
Some historical events -
My 13 BRZ (2015 FA20 swapped) threw a P0303 last month and I took action by replacing the spark plugs and the coil. Both plugs and the coil are OEM from a Subaru parts center. Did the job and reset the code. Everything was great, I even got an MPG improvement. Drove 300 miles and still great.
Today -
Went to Laguna Seca to do a track day and my first two sessions went well. During my third session, the car started to have a distinct rumbling exhaust note, power loss, and blinking CEL. Pulled into the paddock, turned off the car, and checked for the code. Code was P0303. I decided to pack up and leave. I cleared the code before leaving.
On the way back home, the symptoms came back and it struggling. At times the issues were intermittent, it was struggling/bogging and then things feel fine for a very short time, within seconds. Then goes back to the struggling, bogging, power loss, blinking CEL, and rumbling exhaust note.
I'm starting to think that cylinder 3's injector is bad. Not totally sure though and I don't want to start chasing a problem blindly. I did some data logging on my OFT v2, but I have no clue how to read it.
Here is my data log:
https://drive.google.com/file/d/1jPV...ew?usp=sharing
Relevant aftermarket parts for the P0303.
JDL Catted UEL
Stage 2 OFT OTS Tune
Tanabe Over Pipe
Tanabe Front Pipe
GReddy SP Elite Cat Back
Would love to get some insight from my fellow 86 owners.
hachigoku is offline   Reply With Quote
Old 10-17-2021, 04:20 PM   #2
kev0
Drives: '14
https://datazap.me/u/kev0/hachigoku?...ta=3-4-6-10-11
In the future, upload your .csv files onto Datazap for better readibility
kev0 is offline   Reply With Quote
Old 10-17-2021, 11:58 PM   #3
hachigoku
Drives: BRZ, E90 M3
Oh this awesome, thank you!
Old 10-19-2021, 01:24 AM   #4
I'd suggest you replace/swap the #3 coil (again). Maybe your track adventure did it in -
Old 10-19-2021, 01:56 AM   #5
hachigoku
Drives: BRZ, E90 M3
Resolved it. Coil died. Swapped it and I'm back on. I think I'm going to get some upgraded coils for the next track day.
Old 10-23-2021, 04:24 PM   #6
jflogerzi
jflogerzi's Avatar
Do you have the new style coils or old style? I keep killing the front passenger side one on track at the very tippy top of 4th I will throw the P0301 code. Hood vents could help as its heat that's kills the coils. Also I would take the part back to the dealer and get a new one. Might have been defective.
2013 Series 10 FRS #553
Old 10-23-2021, 05:10 PM   #7
Opie
Opie's Avatar
Drives: 2023 Toyota GR 86 Cup
Swap to the upgraded engine harness and 2015+ coils....you'll never have the issue again.
2023 GR Cup Car
Opie is offline   Reply With Quote
Old 10-24-2021, 01:39 AM   #8
jflogerzi
jflogerzi's Avatar
Yea I know
Old 10-24-2021, 03:53 PM   #9
hachigoku
Drives: BRZ, E90 M3
I have the new style. The Racer's Line moved over the harness from the 2015 engine into my 2013.
Old 10-25-2021, 08:04 PM   #10
Opie
Opie's Avatar
Sounds like something in the harness is shorting the coils...possibly a loose pin in once of the connectors...or a cut in a wire.
2023 GR Cup Car
Old 10-25-2021, 09:09 PM   #11
hachigoku
Drives: BRZ, E90 M3
Not sure, but I think failure is caused by the coil itself. Its the cheapo Autozone coil I used. Which is a Duralast brand. Will be buying OEM and seeing if that fails on the next HPDE day.
Old 10-25-2021, 09:30 PM   #12
Opie
Opie's Avatar
Oh yeah, I wouldn't trust an aftermarket
2023 GR Cup Car
Long cranks and engine struggling to start. Please help! pakunodafie Engine, Exhaust, Transmission 17 09-08-2021 02:32 PM
2014 BRZ P0303 Even After Replacing Spark Plugs and Coilpack lc300 Issues | Warranty | Recalls / TSB 4 07-27-2019 06:18 PM
CEL, TCL, P0300, P0301, P0303 drz400dude Engine, Exhaust, Transmission 1 03-13-2018 04:20 AM
FRS struggling to start (video) FRStevan Issues | Warranty | Recalls / TSB 12 06-10-2017 02:48 AM
is anyone else struggling with this ddr6 Great Lakes 12 01-01-2012 02:59 PM
