#4313 | |
Drives: 2014 DMG BRZ
Edit: just checked - held it at -10 in/hg for a few minutes with a vacuum gauge and it's rock solid. I'm wondering if I bungled the intake mani gaskets, but that should show up on an intake manifold smoke test right? edit: probably the dumbest question ever - I have the dual radium catch cans with my edelbrock setup - are you guys running the stock PCV also? I'm running lines directly from the catch can from the breather port -> can, and the other hose goes to the intake manifold directly. Also wondering if this is causing the weird issues im having. edit 2: nvm, just realized the pcv is on the block. there is a bit of oil seepage, but I'm assuming that's normal. Last edited by bokehmon; 10-18-2021 at 04:55 PM. |
#4314 |
Drives: Red 2024 GR86 Trueno
Finally finished installing my Edelbrock and had it tuned. Gained over 120WHP from stock, VERY happy with the results, totally worth it.
The tuner kept the torque lower so I wouldn't snap any connecting rods. Tuning day at PerryTuned in Tiverton RI ![]() Results: ![]() Powerband: ![]() |
| The Following 5 Users Say Thank You to haohmaru For This Useful Post: | BrahmaBull1990 (10-20-2021), CallmeDave (04-25-2022), CSG Mike (10-18-2021), HlfpriceWngs (10-18-2021), Swolzee (10-18-2021) |
#4315 | |
The Stig's African Cousin
Drives: 2014 wrb brz
Instagram: brandonblt2
Build Thread: http://www.ft86club.com/forums/showt...86#post2219386 Flickr: brandonblt567 |
#4316 | |
edit: Just had em cleaned - they tested perfectly. Injector guy is just putting it all back together now. edit 2: anyone had to clean their direct injectors before? I'm wondering if that's the issue (or the seals going out) Last edited by bokehmon; 10-20-2021 at 08:41 PM. |
#4317 |
Drives: 2015 FR-S
#4318 |
#4319 |
Drives: Honda Insight
How difficult is changing injectors once the SC is in place?
Also, who all is tuned over 400whp+ on the E-force? I've seen countless stock internal sub 300 builds, and a handful of 300-350 tunes, but I think I've only seen 2 documented tunes of over 400 or even close to that. I'd love to get some more information on some of the builds around this power level. |
#4320 | |
Just pulled mine to test, took less than 30 min. |
#4321 | |
You can take some measures to keep the torque down to make things last longer, but it won't be forever. |
#4322 |
Drives: BRZ ts
What’s involved in building an FA20? I understand the rods are strong as ramen. I don’t think I’ve seen this platform get sleeves.
#4323 |
Drives: 2020 BRZ (Black)
It get's even easier on the passenger side if you get a new injector controller bracket. Everything on mine is exposed, and super easy to get to (also, I think it looks way better under the hood with the new bracket)
#4324 | |
They forget everything else. Heads, machining, studs, cooling, transmission, etc. |
| The Following User Says Thank You to CSG Mike For This Useful Post: | dpfarr (10-21-2021) |
#4325 |
Drives: '15 BRZ RA
Talk to engine builders who have experience with Subaru engines and they'll tell you how much more they love the EJ engines. The FA20 engine is more complicated with more parts, more screws, more gaskets and sealant. The FA20 engine is 55kg heavier compared to an EJ20 engine, which is an indicator of the increased complexity. Not an issue for the factory to assemble it with all the modern automation, but a more serious problem to hand assemble it with higher points of failure ...
| The Following User Says Thank You to nikitopo For This Useful Post: | dpfarr (10-21-2021) |
#4326 |
Drives: BRZ ts
Looked up some articles about creating solid fa20 fi platforms.
Seems like keeping it well under power threshold, our cars can be wringed out without issue. Divorcing the more more more theory from car modifying is something I haven’t suffered from greatly. I’ve always preferred the solidifying approach that I can do whatever all the way to the limit of the car and still drive the next day. Going to have to keep this not so deep in the back of my mind. |
| The Following User Says Thank You to dpfarr For This Useful Post: | nikitopo (10-21-2021) |
| Vortech Owner Thread & Setup Questions | reyruiz191 | Forced Induction | 340 | 05-17-2022 12:44 PM |
| Edelbrock E-Force Supercharger | itsibarra | Forced Induction | 938 | 07-31-2021 04:48 PM |
| Most annoyingly over-asked questions on FT86 forums | mit_peid | Off-Topic Lounge [WARNING: NO POLITICS] | 36 | 01-16-2014 02:48 PM |
| Brz Info/Specs (helpful info for questions asked often) | Gaen | BRZ First-Gen (2012+) — General Topics | 0 | 05-24-2012 10:09 PM |
