Old 10-15-2021, 01:02 PM   #1499
wbradley
Sarcastic SOB
wbradley's Avatar
Thanks to the high vaccination rates (82.3% double vaxxed and increasing in Toronto) they will slowly begin to lift more restrictions in Ontario. Restaurants, recreational facilities, personal services are all at partial capacity while they already opened sports venues full capacity. So, the push is to allow business the ability to sustain on an equal level asap.
I downloaded my vaccination passport QR code today and (fingers crossed) it looks like things are OK here so far despite the fall and schools opening.
Without vaccination mandates, EVERYONE would be restricted. Thankfully we have a choice not to be.
wbradley is offline
Old 10-15-2021, 01:03 PM   #1500
p1l0t
p1l0t's Avatar
I've never had a job ask me if I have had the polio vaccine before...
p1l0t is offline
Old 10-15-2021, 01:04 PM   #1501
Originally Posted by 86TOYO2k17 View Post
because what cant be sped up is time itself. you can solve the equation faster, but testing still takes time
It depends on what you are testing for.
Yes, you are correct, you can't determine long term effects until the long term has passed, just as 9 women can't have a baby in one month.
However, if your goal is to do broad testing for reactions and short term effects, plus efficacy, you can speed that up by volume of testing, which we are well past at this point with the COVID vaccines.
So then it sounds like we are down to when is long term testing enough? One year, two years, twenty years? Every vaccine ever created could now have long term effects we are not aware of, if that amount of time hasn't passed.
The first COVID-19 trials started in March, 2020 so we are past the one year point.
Dadhawk is offline
Old 10-15-2021, 01:05 PM   #1502
p1l0t
p1l0t's Avatar
Nor a restaurant or movie theatre...
p1l0t is offline
Old 10-15-2021, 01:12 PM   #1503
MyHybridBurnsGasAndTires
Drives: what
yeah that's a great example of why vaccines mandates are great and have effectively stopped polio across almost the entire planet
you might have a point if there wasnt an ongoing pandemic
MyHybridBurnsGasAndTires is offline
The Following 2 Users Say Thank You to MyHybridBurnsGasAndTires For This Useful Post:
Dadhawk (10-15-2021), wbradley (10-15-2021)
Old 10-15-2021, 01:12 PM   #1504
Spuds
The Dictater
Spuds's Avatar
Drives: '13 Red Scion FRS
Did you go to school at some point?
Spuds is offline
humfrz (10-16-2021), spike021 (10-15-2021)
Old 10-15-2021, 01:14 PM   #1505
Drives: what
Reading between the lines of your argument (or at least attempting to), it sounds to me like you are suggesting we should wait two more years because we made that same mistake before. If that is not the case, why is this important to you?
his current debate tactic is concern trolling using argument from ignorance fallacy over and over in an effort to once again muddy the waters. there's nothing more to it.
Old 10-15-2021, 01:14 PM   #1506
p1l0t
p1l0t's Avatar
Still is that the new way forward? To have our medical records ready for any ol stranger to review before entry?
p1l0t is offline
Old 10-15-2021, 01:20 PM   #1507
86TOYO2k17
Drives: 2017 toyota 86
I don't believe any COVID-19 mandates took effect before the first FDA approval.
Frankly, I don't care how long after approval a vaccine was mandated which is why I haven't bothered to look it up beyond pointing out that they were historically mandated well before there was anyone competent enough to approve it. You seem to be taking the concept of precedence a bit too literally here.
I believe the precedence argument is intended as a historical lesson. There was a terrible disease causing significant problems, an inoculation method was discovered to prevent/slow/reduce risk of the disease, and the leadership mandated that a group of people must be inoculated. It is told as a success story because the mandate worked, and we can see the data showing that.
Your argument is confusing success of the method with some arbitrary temporal information. Let's use your example, Polio. The vaccine was made, tested, and approved. How many more children died in the next two years because people did not voluntarily get them vaccinated? The vaccine didn't change in those two years, or even between trials and approval. It was just as safe and effective the day the final round of trials started as when it was mandated years later. The trials of that vaccine, not the years following, proved that the vaccine was safe and effective, and the approval verified that the appropriate trials were performed.
my suggestion is that if you are going to argue for mandates by drawing a comparisons to other mandates in the past the comparison should be and equivalency.
I even stated previously my argument in this specific discussion/counter argument to his post/point wasn't an argument for or against mandates, it was about what would be or wouldn't be a valid comparable or equivalent comparisons for justification.
More specifically the hypocrisy of his final statement, where he was essentially doing the very same thing he was shaming others for doing.
Its like saying the government has declared marshal law before so it justifies using marshal law now for XYZ when XYZ is completely different scenario then the previous instances of it being declared in response to ABC.
Does it mean it shouldn't be declared for XYZ? No it very well could be warranted but it is NOT warranted solely based on it being used for ABC in the past.
86TOYO2k17 is offline
Old 10-15-2021, 01:22 PM   #1508
86TOYO2k17
you clearly cant follow along with the conversation. you still think it is an anti mandate or anti vax argument. when it is clearly not... if you where able to read and comprehend what was said and stated this would be clear.
The Following User Says Thank You to 86TOYO2k17 For This Useful Post:
p1l0t (10-15-2021)
Old 10-15-2021, 01:27 PM   #1509
Because you aren't old enough most likely, since it's almost not existent at this point.
I have had jobs ask about other vaccines, and asked for vaccine records.
Dadhawk is offline
Spuds (10-15-2021)
Old 10-15-2021, 01:30 PM   #1510
wbradley
Sarcastic SOB
wbradley's Avatar
Vaccine passports, we have been assured, provide zero information other than your identification for verification and your vaccine status (which vaccines, when administered).
Apparently Pilot would object to registering children for day school. Pre pandemic, at least as far back as 19 or 20 years ago it was required for my first child, as well as for my second. Their vaccination cards were provided from the pediatrician.
That's how we manage to eradicate infectious diseases.
It seems to me most all libertariams and anti-vaxxers like to replace the word "eradicate" with "tolerate", which I find unacceptable in this context.
wbradley is offline
Old 10-15-2021, 01:35 PM   #1511
Hoahao
Drives: 2014 Monogram Hot Lava
8 prominent doctors & scientists engage in a remarkable exchange
It's all about gearing and steering.
Hoahao is offline
The Following 2 Users Say Thank You to Hoahao For This Useful Post:
Atropine (10-15-2021), p1l0t (10-15-2021)
Old 10-15-2021, 01:45 PM   #1512
Drives: what
yes, your entire medical history will need to be shown. everything. you will even have to show your tiny little balls to the ticket taker at the movie theater to get in.
beau cave keeners club, bradcuckedbymonkeys, come and make me, crybabylantanafrs, leeroy jenkins!!, noah get the boat, o'doyle rules!, peer reviewed thread, pew pew, rawdoggers4trump, shut the fuck up, socialist losers, spikesasimp, this is a wendy's, tylercuckedlieberman, voteforpedro, waaaantanafrs2, waahbradleywaah, waahwaahbradley, waahwaahvteckickedinyo
Dating during Covid Impureclient Off-Topic Lounge [WARNING: NO POLITICS] 143 08-22-2023 12:33 PM
Covid 19 origin(s) Lantanafrs2 Off-Topic Lounge [WARNING: NO POLITICS] 280 08-29-2021 12:38 AM
Covid Lockdown Activities Boomerang Off-Topic Lounge [WARNING: NO POLITICS] 1471 09-29-2020 03:38 PM
