Old 10-14-2021, 11:41 AM   #81159
spike021
spike021's Avatar
Another thing is that you being in CA, don't know how far, if you already own ECUTEK, why not schedule an apt with CSG?
Yeah been there done that with him via TRL and it's a long story that some of the guys here have heard basically ad nauseum but I refuse to give them anymore of my money.
Instagram: @spike.grc
spike021 is offline
Old 10-14-2021, 12:04 PM   #81160
spcmafia
spcmafia's Avatar
Drives: 2018 Subaru BRZ
Hey Im relatively new on this forum lol, so I don't know the whole backstory.
spcmafia is offline
The Following User Says Thank You to spcmafia For This Useful Post:
spike021 (10-14-2021)
Old 10-14-2021, 12:28 PM   #81161
spike021
spike021's Avatar
Haha no worries.
I guess the tl;dr is I had TRL/Zach do the tune via CSG 2 years ago. About a month in had bad misfires. Had two different shops check spark plugs, cylinders, leak test, etc. Nobody could figure out the issue. Had TRL remove headers, "flash back to stock". Issue kept happening for a few more months. Had another local shop attempt checking the tune again and re-flashing the stock tune or whatever from Ecutek and since then no problems.
TRL/Zach refused to help at all, blamed me, said I brought in a car with problems already for the tune (I'm not that dumb), said I was using a used/old DT Flex Fuel kit (I got it brand new from Mike @ CSG but nobody believed me even with proof).
It got super heated in the forum "review" thread for a couple of months in late 2019.
Anyway if you want more details you can PM me lol.
spike021 is offline
Old 10-14-2021, 12:43 PM   #81162
spcmafia
spcmafia's Avatar
Haha no worries.
Gotcha, well that sucks. I always heard such good things from them and thought about getting the Bluetooth tune set up. I m just to scared to mess with OFT and other parameters I'm not familiar at all with.
spcmafia is offline
Old 10-14-2021, 02:13 PM   #81163
Spuds
The Dictater
Spuds's Avatar
Drives: '13 Red Scion FRS
My mantra when getting started: "It's just another machine".
It might also help to be responsible for multimillion-dollar equipment at work every day...
Spuds is offline
The Following User Says Thank You to Spuds For This Useful Post:
soundman98 (10-15-2021)
Old 10-14-2021, 03:19 PM   #81164
spcmafia
spcmafia's Avatar
I mean yeah, is just another tablet, but when it comes to mess with parameters that affect fuel and what not, things can go wrong really quick. I'm going to give it a try, but as a you know, Im going to be doing a lot of research.
spcmafia is offline
Spuds (10-14-2021)
Old 10-14-2021, 03:27 PM   #81165
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
Flashing back is fairly simple if you screw up, it is a good idea to keep the previous tune and current tune on the oft so you can revert if necessary. I usually log immediately to make sure things look normalish. I have messed up and made a negative value a positive before or mistyped a field. It rears it's head quick via messed up fuel trim or dropping IAM. Modern ECU's are pretty damn good at compensating so it is not likely to cause harm if you notice it in a reasonable amount of time.
NoHaveMSG is offline
The Following 3 Users Say Thank You to NoHaveMSG For This Useful Post:
soundman98 (10-15-2021), spcmafia (10-14-2021), Spuds (10-14-2021)
Old 10-14-2021, 03:52 PM   #81166
Spuds
The Dictater
Spuds's Avatar
By "machine", I meant the car lol.
That's the ticket!
Spuds is offline
Old 10-14-2021, 04:45 PM   #81167
Kaotic Lazagna
Drives: GR Corolla
Does random feelings apply to random thoughts? Been feeling very nostalgic since yesterday. Not really sure why.
Kaotic Lazagna is offline
The Following User Says Thank You to Kaotic Lazagna For This Useful Post:
Old 10-14-2021, 06:19 PM   #81168
spcmafia
spcmafia's Avatar
When people talk about logging pulls from third gear. Does that mean from a full stop, or, under 2500RPM shift 1st and 2nd and then from 2500RPM in 3rd, redline?
spcmafia is offline
Old 10-14-2021, 06:32 PM   #81169
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
Usually I do 2500-3k to redline 3rd gear full throttle.
Spuds (10-14-2021)
Old 10-14-2021, 07:40 PM   #81170
Spuds
The Dictater
Spuds's Avatar
A somewhat level highway on-ramp at 1am is your friend.
Also, you'll get good answers in the technical topics too.
Spuds is offline
Old 10-14-2021, 09:15 PM   #81171
Kiske
Kiske's Avatar
Drives: RX-7 / BRZ
I have heard great things about him. The only issue I'd be concerned with (which I guess is still the case if I try OFT) is that if I have issues again like the last time then the tuner won't be local and if I bring a car to a shop to get it checked out they won't know what the tune changed. .
Flash the car back to stock and get it running right first. The basic bolt-on's in your build thread aren't going to prevent the stock rom from working. That removes any doubt that it is tune related. Pop some pump gas back in it and start there. Then contact James. Depending on if CGS's file is locked or not, he may even be able to take a look at it.
FWIW if the car ran right and then all then 1 month later had issues without a tune being changed or updated then it is likely not software. Spark, fuel and air...
Used DTC's to know where to start looking. Check the plug and coil. Have spark? Great time to look at air and fuel. Check AFR to see if you have an issue in that department. If fuel, start and the injector and work back to the tank. If air, start and the intake and work towards the engine.
James doesn't do locked ecu tunes. So anyone with ecutec and a laptop can look at the files and correct things if needed be it local or not... if your the learning type you can even give it a go. A large process of me understanding this platform was watching his revisions and seeing what he changed in the updates between the 13+ files we did making my first one purr.
Looking at data is a valuable skill in determining where to start a diagnosis, something ecutek offers by the truck load. Go to the library if you have to and get some free books on ecu tuning.
Kiske is offline
Old 10-14-2021, 10:26 PM   #81172
Yup. In scope.
Ultramaroon is offline
The Following 5 Users Say Thank You to Ultramaroon For This Useful Post:
bcj (10-15-2021), Kaotic Lazagna (10-15-2021), NoHaveMSG (10-15-2021), soundman98 (10-15-2021), Spuds (10-15-2021)
