#81117 |
Site Moderator
Drives: ichi 86 Project
Ain't that the truth.
| The Following User Says Thank You to ichitaka05 For This Useful Post: | soundman98 (10-12-2021) |
#81118 |
ProCrastinationConsultant
Take up wood chopping. Or demolition. That helps more.
| The Following 3 Users Say Thank You to soundman98 For This Useful Post: |
#81119 |
Drives: Crapcan
Or take up knife making
| The Following User Says Thank You to NoHaveMSG For This Useful Post: | soundman98 (10-12-2021) |
#81120 |
imo, too much time to think. not enough time smashing things.
| The Following 2 Users Say Thank You to soundman98 For This Useful Post: | Captain Snooze (10-13-2021), Ultramaroon (10-13-2021) |
#81121 | |
Drives: 2017 BRZ
I need to find a place to set up shop. I really do.
| The Following 2 Users Say Thank You to cjd For This Useful Post: | Dadhawk (10-13-2021), soundman98 (10-13-2021) |
#81122 |
Drives: 2018 Subaru BRZ
I remember there was a time when someone pointed out my wheels/tires not being flush with the body of the car and said it would look a lot better. Got into my head so I got spacers, wheels.
Now I can't stop thinking about when someone, can't seem to remember who, said that my car has monster truck wheel gaps. So Im thinking about changing the suspension, but makes me a bit scared because CT doesn't have the best roads, and I don't necessarily NEED to lower the car, I don't track the vehicle. Is mostly spirited driving on back roads. But now I can't unsee those gaps......
| The Following 2 Users Say Thank You to spcmafia For This Useful Post: | Ultramaroon (10-13-2021), Wally86 (10-13-2021) |
#81123 | |
Drives: Crapcan
Don’t listen to those guys, they are assholes.
| The Following 4 Users Say Thank You to NoHaveMSG For This Useful Post: |
#81124 |
Drives: Nevermorange FRS
They’re almost as bad as they guys going around saying mean things like “you should turn it into a racecar!”
PRO86 | WTCC | STL
| The Following 4 Users Say Thank You to rice_classic For This Useful Post: |
#81125 | |
Found you. >.>
| The Following 3 Users Say Thank You to spcmafia For This Useful Post: |
#81126 |
On a side note, I have no idea where to start if I was to get coilovers? Which from what I understand can be adjusted to different settings?
#81127 |
Geo Tyrebighter Esq
Drives: '13 scion fr-s
Yes. You can set them higher for better clearance.
Uncouth deniers all.
"I gotta rock." -- Charley Brown |
#81128 |
The Dictater
Drives: '13 Red Scion FRS
#81129 |
Drives: Crapcan
There are a lot of reasonable options. ST Suspension is made by KW, there is also the Bilstien/RCE Yellow combo that is quite popular. A good start would be to call RCE and let them know what you want out of your car. They are great to talk to.
| The Following User Says Thank You to NoHaveMSG For This Useful Post: | spcmafia (10-13-2021) |
#81130 | |
Seems about right, this is from TEIN Flex Z. Front / Rear Spring Rates: 6kg/mm / 6kg/mm Recommended Drop: -1.4" / -1.6" Max Range: -2.3" to 0.0" / -3.4" to 0.2" Recommended Drop Range: -1.8" to -1.0" / -2.0" to -1.2"
| Language Rant Part Deux | MuseChaser | Off-Topic Lounge [WARNING: NO POLITICS] | 43 | 04-23-2017 07:55 PM |
| Random thoughts thread | MrVito | Off-Topic Lounge [WARNING: NO POLITICS] | 37188 | 02-25-2016 10:00 AM |
| Random Rubber Part | OoLong | BRZ First-Gen (2012+) — General Topics | 8 | 01-28-2014 10:31 AM |
| Crew Carshow : Part Deux 9/7/13 | saiyajinimports | Great Lakes | 0 | 08-17-2013 05:18 AM |
