Drives: 2020 Subaru BRZ
Beehive valve springs
Has anyone used the beehive springs on their valve train. I'd like to know how well they work
Thanks |
#2 |
Drives: 2013 Subaru brz limited
I have them i don’t really feel a difference its more a security thing for the people that enjoys banging redline all day but if you “accidentally” end up redlining you’ll be okay from valve float issues but keep in mind the oil system will freak out i got them because its a must have since the engine was already apart.
#3 |
Drives: Crapcan
Beehives allow you to run more lift then a standard spring without getting coil bind. That is it.
#4 |
Drives: Toyota 86
Doing 8k rpm is easier than before.
Hesitation from 7.5k has gone.
#5 |
Drives: 2014 GT86
makinen: IIRC main issue that kept off higher redline from twins engines was limitations of oiling system.
| The Following User Says Thank You to churchx For This Useful Post: | x808drifter (10-09-2021) |
#6 |
LMGTFY
Drives: 13 FRS, 91 Miata
#7 |
This is for my track car. Redline will be 8500. This is a built engine with alot of oiling updates.
There is alot more to beehives than just higher lift. They have much better harmonic control allowing a softer spring to do the same job as heavier springs. Just wondered how well they worked in the fa20 |
#8 |
For those using the beehive springs. Does anyone have the PAC springs. If so. Do you have a part number
#9 |
Drives: 2014 GT86
Good luck with engine to last any meaningful mileage. AFAIK competent shops had problems getting FA20 reliably past 7800-7900, due mentioned oiling system limitations.
| The Following User Says Thank You to churchx For This Useful Post: | Turdinator (10-18-2021) |
| Valve Springs advice | SwiTchY86 | Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) | 12 | 03-06-2021 09:26 PM |
| J02 recall valve springs question | fitcious | Issues | Warranty | Recalls / TSB | 9 | 06-17-2020 02:22 AM |
| What does the J02 recall come with besides valve springs? | aznchris | Issues | Warranty | Recalls / TSB | 17 | 02-14-2020 09:22 AM |
| Valve springs: GSC vs Supertech | glorydays | Engine, Exhaust, Transmission | 15 | 01-27-2020 04:24 PM |
| Valve springs | Gunman | Off-Topic Lounge [WARNING: NO POLITICS] | 8 | 11-21-2018 02:49 PM |
