Old 10-11-2021, 06:20 AM   #1
oBradyG
Drives: 2020 Subaru BRZ AT
Stg 2 tune feels stock
So I first flashed to the base stg 2 v4.03 tune and I felt the power upgrade.. but I missed cold starts, so I edited the tune file to get cold starts back by editing the Ignition Timing Post start, MAF Correction After Start (Neutral) and (Ingear), and idle speed target A-F, and when I reflashed I noticed it didn’t have the low throttle response like it normally does after reflashing, and I can definitely feel the power is gone? Did I do something wrong to lose the power? It just feels like it’s stock with no tune
oBradyG is offline   Reply With Quote
Old 10-11-2021, 08:05 AM   #2
Thetafour
Drives: 2017 CWP BRZ
Re for the flash as intended by the tunee, pull your batteryz drive 100km and report back?
Sent from my SM-G970W using Tapatalk
Thetafour is offline   Reply With Quote
Old 10-11-2021, 10:26 AM   #3
Espi
Espi's Avatar
Drives: 17 BRZ
I flashed from stg1 to stg2 recently and it took a good week for stg2 to settle. Flash, turn off and idle for 60 sec. then go for a drive. It will take a few drive cycles for the ecu to learn everything. You’ll feel the power come back after about 20 drive cycles.
Espi is offline   Reply With Quote
Old 10-11-2021, 11:47 AM   #4
DarkSunrise
DarkSunrise's Avatar
After reflashing, the throttle will feel sluggish for a while. To speed up the throttle position learning process, try the following. Put the car into accessory mode, press the throttle pedal to the floor 20 times, turn off the car. Do this twice. Then start the car and your throttle response should be normal.
2022 BRZ Build
2013 FR-S Build
How to run E85 on stock 86 BRZ FRS with OFT tune steve99 Software Tuning 741 06-27-2022 05:06 PM
Taking car back to stock - can I use the upgraded MAP sensor with stock ECU tune? Foobar Software Tuning 17 07-01-2019 10:26 AM
Looking for logs of stock tune/stock exhaust... Tor Software Tuning 10 03-13-2018 08:51 AM
OFT E85 Tune on Stock FR-S RedFRS4me Software Tuning 12 08-25-2014 10:04 PM
91 vs 93 without tune and all stock MurderRider Scion FR-S / Toyota 86 GT86 General Forum 23 07-27-2014 08:10 PM
