Old 10-08-2021, 06:50 PM   #15
Capt Spaulding
Persona Non Grata
Capt Spaulding's Avatar
Drives: '15 BRZ (WRB)
My great uncle owned a motorcycle shop selling Moto Guzzis and Norton. He wore Hushpuppies to work - I swear he did it so he could run the top of his shoe along the bottom of those Norton primary drive cases to catch the drips before they fell.
For me it depends on the vehicle. The rear main on my '06 F150 has been leaking for 4 years or so. I clean off the driveway avery month or so and top up the truck at the same time. I figure I'll get it fixed the next time it needs a clutch. I my wife's Camry or the BRZ started I might see things differently.
Slow is smooth, and smooth is fast
Capt Spaulding is offline   Reply With Quote
The Following 2 Users Say Thank You to Capt Spaulding For This Useful Post:
humfrz (10-08-2021), Ultramaroon (10-08-2021)
Old 10-08-2021, 11:13 PM   #16
Not at all! Except maybe @humfrz but we don't mind him. I know what you're saying. a leak is a leak. I agree. Mine is same age as yours with about same Km. No leaks. Completely clean. I also agree with @Grady. He is saying that it is not terrible.
It probably is the rear main seal but even when it starts dripping, as long as it's not low on oil, don't worry. The seal can be replaced when convenient.
Ultramaroon (10-09-2021)
Old 10-08-2021, 11:28 PM   #17
Originally Posted by Busshman View Post
Ok guys I don't know but I think you are making fun of me 😁 from the factory you have clean car with no leaks... It's 21 century no 19th or 20... And I think when something start leaking when it's oil or even water or gas you have to solve it and repair it... So when I see my car leaking iam worried, don't get me wrong... Maybe I should relax.. 😁
Ya, well, I'm sorta messen wich ya. -
I reckon you should get the leak fixed.
However, please understand that from my standpoint (I can't get under my car to see it) so, if it doesn't drip out onto the floor under my car (where I can see it when I move the car), the leak doesn't exist -
(now, maybe, I'm taking too much meds - )
Old 10-09-2021, 10:00 AM   #18
Busshman
Drives: Toyota Gt86
Thank you guys for replies, appreciate it.
Busshman is offline   Reply With Quote
Old 10-09-2021, 07:32 PM   #19
blsfrs
blsfrs's Avatar
Drives: 2013 frs base
You might want to check the pvc valve. Not for a leak. If it's not functioning correctly, you will get too much crankcase pressure and force oil out. My old Corolla actually pushed the rear main out. There was a steady stream of oil coming from the rear of the engine.
Old 10-09-2021, 07:49 PM   #20
A damn good point! Thank you.
blsfrs (10-10-2021)
Old 10-09-2021, 08:31 PM   #21
radroach
Drives: car
Possible a leak from the transmission. I remember some owners had trouble with trans fluid slipping past the seal and getting on the clutch.
Old 10-10-2021, 07:19 AM   #22
Busshman
Drives: Toyota Gt86
And how to i check if the pvc Valve is working correctly?
Old 10-10-2021, 12:46 PM   #23
bcj
Geo Tyrebighter Esq
bcj's Avatar
Drives: '13 scion fr-s
No, it's just ice-cream.
Ultramaroon (10-10-2021)
Old 10-10-2021, 02:47 PM   #24
blsfrs
blsfrs's Avatar
The old fashion way is to take it out and shake it. If it rattles it's good.
Old 10-10-2021, 07:42 PM   #25
FrickingReallySlow
Drives: 2015 FR-S
its so cheap if you take out the old one just put in a new one in. thing needs to be replaced 50k-60k anyways. I replaced mine recently and corrected my LTFT by 6%
FrickingReallySlow is offline   Reply With Quote
The Following User Says Thank You to FrickingReallySlow For This Useful Post:
blsfrs (10-10-2021)
Trans build for 400+- hp Boris_Petrov Engine, Exhaust, Transmission 32 10-07-2019 05:22 AM
intelligent trans Victorscp Scion FR-S / Toyota 86 GT86 General Forum 21 04-01-2019 11:07 AM
FA20 and Trans [OH] RavioliG Engine, Exhaust, Bolt-Ons 4 03-22-2018 11:53 AM
fs: Perrin trans mount and whiteline trans bushing RWD_FR-S Transmission and Driveline 1 01-02-2014 06:34 PM
AT trans whine? Anyone else? Hardrock4445 Engine, Exhaust, Transmission 1 05-30-2013 07:46 PM
