Old 08-14-2021, 12:08 PM   #5727
pogofx
Drives: 2018 BRZ Limited
So how Rich are you tunes, specifically soot build up?
I'm tuned on OFT with Shiv. Yes....I know EcuTek is probably with way to go...got it...and I plan on going that route this year. I already had the OFT and figured I give it a try with a plan to switch to EcuTek at some point. I initially had not planned on FI.
I have a lot a soot build up on the back of the car. On startup, sometimes with the moisture in the exhaust, it will spit some black soot out on ground, leaving something to clean up. Realizing that the rich tune is on the safe side, and I'm okay with that, but after about 10K miles, it just seems a little too much on the rich side based on the soot alone. With a white car its even more obvious. The car has run very well and I've had no issues and have driven several autocross's. The only hiccup it can encounter is if I inadvertently load the engine up by getting on the throttle at low rpm in too high of gear. I will occasionally get a hiccup or hesitation at 2.5K rpm. I avoid driving like this, bogging the engine, since it not good anyway, but sometimes it happens.
I did about 9 revisions on the tune with Shiv and mentioned how rich it seemed. In the end, he said everything looked about perfect. My Mazdaspeed 3 was pretty rich, but this has that beat. So tell me about your soot or lack there of.
pogofx is offline   Reply With Quote
Old 08-15-2021, 12:34 PM   #5728
Breadman
Breadman's Avatar
Drives: 2017 BRZ w/PP
So I ran into another issue, the jrsc pcv valve is too small to run on the raidum can. Is there another pcv that people use to replace it?
Old 08-15-2021, 01:43 PM   #5729
Brz866
Brz866's Avatar
Drives: Series Blue WRB JRSC C38 HBP Flex
I installed the radium catch can with the jrsc pcv valve and having no issues. Same diameter hoses for both but my kit is also about 4 years old. You can skip the jrsc valve if you install the wrx pcv valve instead.
Brz866 is offline   Reply With Quote
Old 08-15-2021, 02:07 PM   #5730
Breadman
Breadman's Avatar
The jrsc pcv valve even with the clamps just slide out of the 3/8" lines from the case. you must have different size lines or something
heres mine
Here is a little push with my finger
Old 08-15-2021, 03:20 PM   #5731
Breadman
Breadman's Avatar
I just measured and it is the same diameter as the OEM line so I guess ill get some worm clamps
Old 08-17-2021, 10:08 AM   #5732
vfrqqq
Ultra Senior Member
vfrqqq's Avatar
Drives: 2014 BRZ Premium, WRB
I used worm clamps and it appears to hold the over-pressure well. As it turns out, I only did this recently. Before I was using a Uline check valve that was discussed in another post I found on this forum long ago and in a Galaxy far, far away. I would say search on Uline PCV, but your results will likely be hit or miss. Anyway, if you find it and think you want to use it, I can report that it appears to have done the job well before I swapped over to the JR-provided check valve.
vfrqqq is offline   Reply With Quote
Old 08-17-2021, 03:03 PM   #5733
Lefafwa
Lefafwa's Avatar
Drives: 2016 BRZ
THANKS!
Originally Posted by PulsarBeeerz View Post
Thanks!!
2016 BRZ - JR Super Charger
JR Dual Oil cooler/Radiator
Torque Solutions Short Shifter
Lefafwa is offline   Reply With Quote
Old 10-07-2021, 08:56 PM   #5734
jkamelo
[jay-kuh-meh-low]
jkamelo's Avatar
Drives: 2016 FRS RS2.0 #293
I plan on getting this kit. How much power will I be leaving on the table if I go stock header + CARB tune instead of ACE header + custom tune?
If there's not a huge power difference, I'll just go stock header + CARB because I want to take the most reliable, proven, low-maintenance route possible. I also don't like the idea of making multiple visits to a local tuner to troubleshoot issues.
I'll only ever run pump gas (93 here in VA), BTW.
Shining the @CSG Mike bat signal!
jkamelo is offline   Reply With Quote
Old 10-08-2021, 12:47 AM   #5735
CSG Mike
CSG Mike's Avatar
I would guess 20-30whp and a good amount of torque
CSG Mike is online now   Reply With Quote
Old 10-08-2021, 12:56 AM   #5736
jkamelo
[jay-kuh-meh-low]
jkamelo's Avatar
Dang it that’s a lot. I don’t know man, tuning just makes me nervous. I’ll have to find someone in my area who I trust not to screw it up.
Old 10-08-2021, 01:48 AM   #5737
CSG Mike
CSG Mike's Avatar
Why not just get it done remote like the fast majority of the owners that are boosted?
Old 10-08-2021, 12:36 PM   #5738
PulsarBeeerz
Drives: JRSC BRZ SOLD
Just let Zach at CSG handle your tune. He's great to deal with and has done hundreds of JRSC FA20. He tuned my SC setup as well a bunch of others here. 100% would recommend.
PulsarBeeerz is offline   Reply With Quote
Old 10-08-2021, 01:05 PM   #5739
vfrqqq
Ultra Senior Member
vfrqqq's Avatar
+1 on that.
Old 10-08-2021, 03:07 PM   #5740
new2subaru
Weight Weenie
Drives: 15 FR-S
Why not just stay CARB legal? That's one of the major appeals to a supercharger.
Jackson Racing Rotrex Supercharger System Info and Discussion Jackson Racing Forced Induction 827 04-06-2020 04:56 PM
Jackson Racing Supercharger Press Release and Info CounterSpace Garage Forced Induction 110 01-03-2017 09:04 PM
jackson Racing engine oil cooler - modular to fit the Jackson Racing Supercharger! CSG Mike Forced Induction 24 04-27-2016 12:59 PM
Jackson Racing supercharger NoppyNop Forced Induction 241 06-26-2014 03:05 PM
Jackson Racing Supercharger Pre-Order Sale, $200 off! Xero-Limit Forced Induction 2 03-05-2014 04:14 PM
