Old 10-05-2021, 04:39 PM   #1
OlThickness
Drives: 2013 Scion FRS 10 Series
Overfenders didn't come with hardware?
Hello all,
Basically, I just bought an Ebay overfender kit (I know, boo) and it didn't come with rivets or any hardware. I can't seem to find an answer to this question so I figured this would be a good place to ask. What kind of hardware do I need to mount these overfenders? Will any rivets work? Any other info I should know before beginning?
OlThickness is offline   Reply With Quote
Old 10-06-2021, 04:35 AM   #2
x808drifter
LMGTFY
x808drifter's Avatar
Drives: 13 FRS, 91 Miata
The Following 2 Users Say Thank You to x808drifter For This Useful Post:
NoHaveMSG (10-07-2021), Wally86 (10-06-2021)
Old 10-06-2021, 08:09 AM   #3
Wally86
Be Kind
Wally86's Avatar
Drives: 2020 86
Rivnuts (Threaded Rivet Nut) and stainless bolts seem to be what everyone does so it's removable and easier to work with.
This is one of those: if you have to ask, I hope your car is salvaged or a project car. Cutting fenders, seam sealing, creating new fender liners.... none of this is for the faint of heart. Good luck!
[Insert clever signature here]
IG | WhiskyBlog | Photography
Wally86 is offline   Reply With Quote
Old 10-06-2021, 08:32 AM   #4
RToyo86
RToyo86's Avatar
Drives: 17 Asphalt 86
Not only that, you should really know what you are doing when cutting up fenders. You need to cut and weld them up, and seal them properly so it doesn't rust.
The Following User Says Thank You to RToyo86 For This Useful Post:
Old 10-06-2021, 08:38 AM   #5
Wally86
Be Kind
Wally86's Avatar
Drives: 2020 86
Without context you never know. Maybe they TIG weld on the regular and this'll be an easy project for them but if they're asking about rivets, I have doubts.
Old 10-07-2021, 10:53 AM   #6
OlThickness
This is actually my daily. I'm a half-star youtube mechanic but i've got no doubts it will be done right. I've been doing a lot of research and learning about the project in prep, and in general just not a dummy but when it didn't come with hardware I wasn't sure. Regardless thank you, i'll be getting some rivnuts.
I've read there are alternative rust prevention methods to welding? Are they not as good as welding?
Old 10-07-2021, 11:22 AM   #7
Wally86
Be Kind
Wally86's Avatar
Drives: 2020 86
Cut, weld, POR15.
Since you're doing something crazy and looking for views on YT, why not mount the rivnuts to the overfender and drill holes in the fender and bolt it in from behind? Then you can bondo over the fiberglass spots for mounting and have a super clean look. Might be more of a pain for removal but it'd look slick. My .02
Old 10-07-2021, 01:17 PM   #8
VIP BRZ
VIP BRZ's Avatar
Drives: 2014 Subaru BRZ
The guy who did my car suggested we use regular rivets over rivnuts because they tend to shake loose, you have to go around a re-tighten them periodically
for a home garage job it'd just get a rivet gun and forget about all those rivnuts
Its honesty easy to drill out the rivets if you ever have to remove the kit
VIP BRZ is offline   Reply With Quote
The Following 2 Users Say Thank You to VIP BRZ For This Useful Post:
Dadhawk (10-07-2021), Wally86 (10-07-2021)
Old 10-07-2021, 01:23 PM   #9
Out of curiousity, pop rivets or solid rivets?
Old 10-07-2021, 02:49 PM   #10
VIP BRZ
VIP BRZ's Avatar
Just plain oll pop rivets, grab a hand tool at hardware freight. Much cheaper option as well.
The Following User Says Thank You to VIP BRZ For This Useful Post:
Old 10-07-2021, 04:20 PM   #11
Yoshoobaroo
TRACKBREAD
Yoshoobaroo's Avatar
Has your guy never heard of thread locker?
Old 10-07-2021, 04:39 PM   #12
Yea, definitely easy to drill out. Done it plenty of times. Solid rivets are a little more difficult but not too bad.
Old 10-07-2021, 05:28 PM   #13
VIP BRZ
VIP BRZ's Avatar
What's the point of having them being removable hardware if your just gonna lock them up?
Its probably easier to drill out rivet then it is to wedge loose 75 thread locked rivnuts
also like a said.. rivnuts cost like a $1 a piece + all that thread lock
rivets are like 100 for $10
Old 10-07-2021, 06:04 PM   #14
Yoshoobaroo
TRACKBREAD
Thread locker prevents the screws from backing out, but they still come out easily with a screwdriver. Every single important bolt on your car is thread locked. You just apply a drop of blue loctite to the threads and you’re good.
Rivnuts are cheap, literally $0.28 a piece:
https://www.mcmaster.com/95105A127
If I was cutting my fenders up I would sure want to be able to get back in there to check on rust.
The Following 2 Users Say Thank You to Yoshoobaroo For This Useful Post:
NoHaveMSG (10-08-2021), x808drifter (10-09-2021)
overfenders, widebody
Front widebody/overfenders only DanFRSh*tbox Cosmetic Modification (Interior/Exterior/Lighting) 5 08-23-2019 08:45 PM
Molding rocket bunny overfenders Raves614 Cosmetic Modification (Interior/Exterior/Lighting) 3 12-05-2015 12:28 AM
WTB: Rocket Bunny Overfenders Brndn704 Want-To-Buy Requests 1 09-17-2015 02:04 PM
Chargespeed overfenders / widebody Khorne Cosmetic Modification (Interior/Exterior/Lighting) 9 10-15-2014 02:29 PM
Origin Labo Overfenders ZC6BRZ Cosmetic Modification (Interior/Exterior/Lighting) 3 01-26-2013 10:37 PM
