Old 10-02-2021, 07:44 AM   #281
JD001
JD001's Avatar
Drives: Subaru BRZ
Originally Posted by Opie View Post
Good thing I had enough spare parts to put the left front back together to roll it off the trailer...
Good stuff! Neighbours okay with the little 'cottage industry' next door?
Old 10-03-2021, 08:53 AM   #282
Opie
Opie's Avatar
Drives: 2020 GMC Canyon Denali Diesel
I'll probably get a letter from the HOA....all "car work" is supposed to take place in the garage. Got it done in under 2 hours...in the middle of the day when most people were at work
2020 GMC Canyon Denali Duramax, 2021 Forester Sport, 2000 Subaru Legacy B4 RSK 5MT (JDM Import) and random 86 chassis rebuilds....
Opie is offline   Reply With Quote
The Following 2 Users Say Thank You to Opie For This Useful Post:
JD001 (10-03-2021), soundman98 (10-03-2021)
Old 10-04-2021, 04:21 PM   #283
Opie
Opie's Avatar
Boy, it's been a busy couple of days...
Last Wednesday - finally got the 245/40R17 Hankook Ventus RS-4's mounted on the 17"x9" Gold Enkei RPF1's for #15 and dropped them off at @Dave-ROR's, Dave had installed the AP Racing Sprint kit and ARP front extended lug studs on #15 but was having a bear with the rear due to corrosion, also the MCS coilovers with Raceseng CasCam plates resulted in an unexpected issue...more on these later.
Thursday drove from Tampa, FL to Huntsvile, AL to pick up a donor car (#17)/engine for #16. Left at 5:00am, made it to Huntsville, then made it back to Warner Robbins, GA at 10:00pm before having to stop and sleep.
Friday morning left at 5:30am and made it back home by 11:30am...spent 2 hours putting a left front suspension back on #17 to get it off the trailer (see a few posts back).
Saturday went back over to Dave-Ror's to help get the rear hubs apart and install those ARP's...ending up destroying the rear hubs getting them out (due to the rust), cleaned everything up, installed a brand new set of Subaru OEM rear hubs with the newly installed ARP studs, installed braided brake lines, Ferodo DS2500 pads all around and flushed and bled the brake system with AP Racing Radi-Cal R2 fluid. Ended up reinstalling the stock struts/springs (hopefully Dave will chime in on the MCS/Raceseng issue) and installed a set of SPC Adjustable Rear Lower Control Arms.
Sunday spent all day removing the engines out of #16 & #17, swapping the new plugs, new drive belt and new clutch off of #16's knocking engine and onto the #17 donor, then installed the #17 motor into #16. Was done at 9:00pm.
Monday (today) went to work and started installing Energy Suspension bushings on the company track NC Miata....got one side done....came home finished up the loose ends on #16; recharged A/C, bled cooling system, topped off all fluids, etc.
Been a little busy....
Code Monkey (10-04-2021), Wally86 (10-05-2021)
Old 10-04-2021, 04:36 PM   #284
e1_griego
e1_griego's Avatar
Drives: Many
I've got raceseng and MCS -- curious what the issue was.
Love this thread btw!
e1_griego is offline   Reply With Quote
Old 10-05-2021, 06:43 PM   #285
Opie
Opie's Avatar
#16 almost ready to go to a new home; Bone stock, clean & clear FL title, one owner, 2015 Engine installed with new plugs, drive belt, clutch, battery & tires. Cleaned up and runs great. Paintless dent repair comes out tomorrow to fix the small dent in the drivers fender...this one cleaned up easier and quicker than I expected.
Code Monkey (10-05-2021), soundman98 (10-05-2021)
Old 10-05-2021, 11:27 PM   #286
Dave-ROR
Site Moderator
Dave-ROR's Avatar
Drives: Stuff
Here's a video showing the issue. Description has more detail.
Not something I'd expect with a pretty expensive suspension setup. IMO the blame is a tiny tiny bit to MCS for changing the design (according to Raceseng anyways), presumably without notice, and a huge part Raceseng for their lackluster customer service (selling another adapter for the spring perch to spherical bearing with the same issue and then upon seeing the video basically just saying "sorry MCS must have changed their design" - no "wow let us make a new piece and see if that fixes it!").
As a result I won't be suggesting or buying anything from them in the future, which should hurt their bottom line just enough for their owner to have to skip McDonalds once every 5 years.
-Dave
DD: 2005 Acura TSX
Tow: 2022 F-450
The Following User Says Thank You to Dave-ROR For This Useful Post:
Code Monkey (10-06-2021)
Old 10-05-2021, 11:31 PM   #287
Dave-ROR
Site Moderator
Dave-ROR's Avatar
Drives: Stuff
And to keep it on topic.. got it ready for the DMV with the 4x4 ride height and the 2017+ header.
-Dave
DD: 2005 Acura TSX
Tow: 2022 F-450
Opie (10-06-2021)
Old 10-06-2021, 01:16 AM   #288
e1_griego
e1_griego's Avatar
Drives: Many
Oh, yeah, I have a box of spacers and things from playing with susp for 10+ years. I threw a spacer on, too. Didn't even give it a second thought.
99% sure I had to do the same with the MCS on my s13, too, though I can't remember offhand.
Old 10-06-2021, 09:38 AM   #289
Dave-ROR
Site Moderator
Dave-ROR's Avatar
Drives: Stuff
I'd be fine with it on a custom setup but when a company sells something for a specific purpose I expect it to work. We aren't talking body mods where some trimming might be required, etc.. this is simple stuff to get right if you are making a product for a specific application. And it would be simple for them to fix.
-Dave
DD: 2005 Acura TSX
Tow: 2022 F-450
soundman98 (10-06-2021)
Old 10-09-2021, 09:38 PM   #290
Opie
Opie's Avatar
#16 Sold!
#17 almost completely parted out.
#15 will be on track in November!
The Following User Says Thank You to Opie For This Useful Post:
Lantanafrs2 (11-07-2021)
Old 11-07-2021, 03:19 PM   #291
Opie
Opie's Avatar
Awesome weekend at Sebring with 5 of our rebuilds out on track. #1-mine, #8-Dave-Ror's, #6-our buddy Aaron, #13-Jim & we delivered #15 to its new owner who tested it out on the track. Great weekend for all!
The Following 10 Users Say Thank You to Opie For This Useful Post:
Code Monkey (11-07-2021), coolhandluke (07-05-2022), Dadhawk (11-07-2021), jflogerzi (11-07-2021), Lantanafrs2 (11-07-2021), Lonewolf (11-08-2021), RedReplicant (12-12-2022), soundman98 (11-07-2021), Stonehorsw (11-08-2021), villainous_frx (11-07-2021)
Old 11-07-2021, 06:55 PM   #292
jflogerzi
jflogerzi's Avatar
I would take a rebuilt first gen from you guys for the purpose of a track car!
Sent from my Pixel 5a using Tapatalk
2013 Series 10 FRS #553
The Following User Says Thank You to jflogerzi For This Useful Post:
Opie (11-08-2021)
Old 07-08-2022, 10:53 PM   #293
coolhandluke
coolhandluke's Avatar
Time to get to work on a build thread...
I can't overstate how well the car performed. Other than losing a turn signal, zero issues, despite the massive amount of work you and Dave-ROR to rebuild the car. :beer:
coolhandluke is offline   Reply With Quote
The Following User Says Thank You to coolhandluke For This Useful Post:
Opie (07-11-2022)
Old 12-12-2022, 01:12 PM   #294
Dave-ROR
Site Moderator
Dave-ROR's Avatar
Drives: Stuff
Rumor has it another WRB has been won.. if the broker doesn't F up.. happy now @dowroa?
-Dave
DD: 2005 Acura TSX
Tow: 2022 F-450
The Following 2 Users Say Thank You to Dave-ROR For This Useful Post:
dowroa (12-12-2022), Opie (12-12-2022)
RIP Dave Mirra STV3 Off-Topic Lounge [WARNING: NO POLITICS] 13 02-05-2016 02:00 PM
Dave-ROR: I know you want this rice_classic Tracking / Autocross / HPDE / Drifting 1 01-02-2014 10:15 PM
Sebring with Dave-ROR LDadrenaline Tracking / Autocross / HPDE / Drifting 9 11-13-2012 10:55 PM
Opie's BRZ thread Opie Member's Car Journals 6 09-25-2012 08:05 AM
