Old 09-20-2021, 02:10 PM   #5041
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
Originally Posted by nextcar View Post
I do about 6 HPDE's a year, just for fun, and run stock power levels.
I have TRD lowering springs and Pedders offset tophats so I am just about -2 camber all the way around.
I currently run Pilot 4s tires (225/45/17), however I find them a little slippery as my times have improved...
I am looking for recommendations on a compromise tire for dual use... is there something better than the 4s?
Price does not matter much, however I don't want to be buying new tires every year if I am only street driving under 5000 miles/year...
Is it practical/reasonable to street a 200 treadwear tire in a warm, dry climate (e.g. San Diego)?
I'd just go SX2's. If you want something a bit faster RS4's.
Old 09-20-2021, 04:32 PM   #5042
TommyW
TommyW's Avatar
Drives: '13 Whiteout
I also do about 6-8 days and 3-5K street miles a year. The SX2 is a good choice or go with the Nitto NT01 if you want even better grip. You'd replace about once a year though. I'm on my 2nd set and don't have any reason to change to something else. Since you aren't a beginner they will be ok. They can take a lot of heat cycles and aren't that fussy about pressure. They have a LOT of grip. Since you're on 225's it won't be too much tire for stock power
TommyW is offline   Reply With Quote
Old 09-20-2021, 10:25 PM   #5043
CSG Mike
CSG Mike's Avatar
The two are generally mutually exclusive.
You'll want new tires regularly since tires will age out as well.
SX2, CUP2, RS4 are viable choices.
Old 09-30-2021, 11:39 PM   #5044
jflogerzi
jflogerzi's Avatar
2013 track owners. I am trying to figure out if I can replace one side with the newer 2015 harness and newer 2015 coils and leave the 2013 on the driver side... I keep popping the P0351 code
Sent from my Pixel 5a using Tapatalk
2013 Series 10 FRS #553
Old 10-01-2021, 07:26 PM   #5045
CSG Mike
CSG Mike's Avatar
You'll want to do ALL of them.
You can also get newer coil packs and an adapter harness.
Or, just upgrade coil packs to IP.
The latter is the easiest solution.
Old 10-01-2021, 08:33 PM   #5046
jflogerzi
jflogerzi's Avatar
Some had said its the harness that's also part of the issue. Where are these adapters you speak of? Any particular you recommend?
Old 10-01-2021, 08:41 PM   #5047
CSG Mike
CSG Mike's Avatar
https://www.icefabrication.com/produ...grade-to-2015/
I just know they exist. I don't have any opinion for or against them.
jflogerzi (10-01-2021)
Old 10-04-2021, 12:29 PM   #5048
downshiftxlr8
downshiftxlr8's Avatar
Drives: 2020 86 Hakone
Ahoy friends, hoping for some decent tire recommendations after heat cycling my RS4s this weekend at BRP. Nothing against the tires, they lasted me a few months with around 6 track days and daily driving, just looking for something that has a little more grip.
Currently using the stock wheels and 225/45/17, getting a set of RPF1s 17x8's that I can swap out at the track now. What would you do ? Tried to find some SX2's but all the places I know were out of the size I wanted
downshiftxlr8 is offline   Reply With Quote
Old 10-04-2021, 01:04 PM   #5049
Kelse92
At the track
Drives: '14 FRS - Former e92 M3
Falken rt660 if you want something better than the RS4 and at a cheaper cost. The expense will be faster wear, but I'm thinking you have more life in the RS4's... they should start chunking on the shoulders well before they are heat cycled out.
I wouldn't necessarily daily/track drive the 660's though, you can, but again the expense of higher wear at little benefit if not on the track. The square set of 17x8's is definitely the way to go and keep the stocks for street driving and do the wider wheels for track. I agree on 8's because all 4 fit with back seats folded down and 9's do not (one must go in the trunk)
#ladydriven Nasa TT4 FRS // JRZ RS Pro // Karcepts Sway Bars // K24 Swap (in Progress) // AP Endurance BBK // Cobalt Friction brake pads // Safeplace Auto
Kelse92 is offline   Reply With Quote
Old 10-04-2021, 04:51 PM   #5050
downshiftxlr8
Oh the chunking started for sure which is why I'm looking into something different before the end of the month (another track day), a friend did suggest I give the RT660s a try, so I guess I'll bite on them. Considering I drove on the RS4s daily these may hold me over the same amount of time if I'm only tracking them the rest of the year.
Old 10-04-2021, 04:59 PM   #5051
CSG Mike
CSG Mike's Avatar
This indicates either a setup error or driver error.
I suggest you figure out why your tires chunked before going with stickier/faster tires.
Old 10-04-2021, 06:11 PM   #5052
Kelse92
At the track
I agree only 6 track days is probably setup related too.
Old 10-04-2021, 06:42 PM   #5053
downshiftxlr8
Car is mostly stock , so this is probably a me thing.
I haven't changed the suspension at all, how much camber do these cars like to run front and rear ?
Tire pressure hot was 33-34 for many of the sessions.
Old 10-04-2021, 06:48 PM   #5054
CSG Mike
CSG Mike's Avatar
Do you have a complete modification list and alignment spec?
Simple question, hard to find answer... Mango22 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 5 05-16-2013 06:23 PM
Silly question about protecting track rims sw20kosh Tracking / Autocross / HPDE / Drifting 16 04-25-2013 12:34 PM
Asking the question that I already know the answer to. Are the engines the same? Bigmaxy Engine, Exhaust, Transmission 10 01-19-2013 07:47 PM
Random dog-related question for those who have their BRZ GMU-BRZ BRZ First-Gen (2012+) — General Topics 11 05-31-2012 07:48 AM
Got my answer - BRZ comes with HID headlights as STD Z_Rocks BRZ First-Gen (2012+) — General Topics 20 01-10-2012 09:54 AM
