Northwest AK, ID, OR, WA
Old 04-14-2021, 04:36 PM   #1
Four_wheel_drifts
Drives: Whiteout track car; lava donor
Roof vinyl wrapper in greater Portland area?
My black vinyl wrapped roof film is starting to crack and peel.
Does anyone have a recommendation for a reasonable vinyl wrap artist in the greater Portland area?
I'll just go gloss black again, nothing fancy.
Thanks!
Four_wheel_drifts is offline   Reply With Quote
Old 04-15-2021, 04:49 PM   #2
Chen
Regional Moderator
Chen's Avatar
Drives: 00-AP1 20-A90 06-Z33 07-FA5 93-NA1
Thanks!
Message @Notvinnyy on ig. Does some good stuff.
Chen is offline   Reply With Quote
The Following User Says Thank You to Chen For This Useful Post:
Four_wheel_drifts (04-16-2021)
Old 04-15-2021, 05:21 PM   #3
shiumai
shiumai's Avatar
Drives: 2013 DGM BRZ, 2020 C8 Corvette
Do it in STEK Dynoblack PPF instead of vinyl. More expensive up front but looks better and will last longer.
shiumai is offline   Reply With Quote
The Following User Says Thank You to shiumai For This Useful Post:
Old 04-15-2021, 06:19 PM   #4
rice_classic
rice_classic's Avatar
Drives: Nevermorange FRS
I think I’m going to wrap the racecar this winter. What makes the SteK PPF stuff better than the 3M 1080 or 2080 stuff?
Edit: Four_wheel - what about doing it yourself if it’s just the roof?
PRO86 | WTCC | STL
The Following User Says Thank You to rice_classic For This Useful Post:
Old 04-17-2021, 06:19 PM   #5
shiumai
shiumai's Avatar
The Dynoblack is basically PPF (paint protection fim), just like XPEL etc, so it's thicker, glossier, lasts longer etc than vinyl wrap. Here's a pic of Dynoblack and 3M 2080 stuck side by side to the same plastic surface. You can see that the Dynoblack looks smoother/shinier.
Old 06-08-2021, 11:37 PM   #6
Sur
Sur's Avatar
Drives: GEN-1-86-MT-FI / 2022 KTM RC 390
I have the equipment to wrap but have only done mirrors and gas flaps. I’d be into doing a roof if you supplied enough wrap to do it.
Sur is offline   Reply With Quote
Old 07-14-2021, 02:53 AM   #7
Four_wheel_drifts
I’m bumping my own thread, but I have a noteworthy update.
It took me four evenings, at over 2 hours per evening, to remove the cracked, checked, failed wrap and adhesive, then polish the roof. There was one pin head sized dot where the paint chipped off. But otherwise the roof looks very good.
The film adhesive had actually yellowed the clear coat in huge splotches. An older thread on the forum said that the sun would make that go away in a day or two. It did!
I likely will not wrap it again. I can’t imagine going through this work every three years.
Three suggestions:
1) use a heat gun. Eventually you’ll get the hang of how long and how big a section to heat up at once. It depends on the structural integrity of the film. As damaged as mine was, I could only remove small pieces at a time.
2) Industrial strength goo gone, not the stuff in a plastic bottle for the dollar store, was the only thing I found that would remove the adhesive residue. It comes in a can. I tried most everything else except paint stripper which is likely way too harsh.
3) remove your wrap BEFORE it starts cracking. I bet I could have pulled it off as one sheet if I’d done it a year or more sooner.
Old 07-14-2021, 05:12 PM   #8
Ducati.Femme
Drives: 2017 BRZ Limited - Pearl White
A bit late.. but I saw that boiling water helps take the sheet right off. Granted yours was cracked, so it wouldn't have come off cleanly, but may have made it easier with less adhesive removal. But yeah, detailing trick for future use.
Ducati.Femme is offline   Reply With Quote
The Following User Says Thank You to Ducati.Femme For This Useful Post:
Four_wheel_drifts (07-15-2021)
Old 09-29-2021, 09:54 PM   #9
Four_wheel_drifts
Update #2. In the past week or less, the roof went from perfect to having a bumpy, acne paint outbreak that would make a teenage put a bag on their head.
Paint guy is saying that they’ve never seen this before with OEM paint. But it’ll be about $700 to sand it down and respray it.
Industrial pollution? The professionals can’t explain how/why it could be perfect for over two months then suddenly tiny paint bubbles everywhere.
Old 09-30-2021, 11:41 AM   #10
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
Sounds like it would be cheaper to sand it and rewrap it. The roof is pretty easy to do. I can ask my paint/body guy if you post a picture if he has seen it before.
Old 10-01-2021, 09:33 PM   #11
Four_wheel_drifts
Yeah, my body shop guy suggested that, too. It’s likely what I’ll do. $700 is a set of track tires, without mounting, of course.
Old 10-01-2021, 11:11 PM   #12
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
If you want a hand let me know. I just did mine.
Four_wheel_drifts (10-02-2021)
Old 10-02-2021, 07:49 PM   #13
Four_wheel_drifts
[IMG][/IMG]
Old 10-05-2021, 12:22 PM   #14
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
My paint guy said there was either water in the sprayer or something else causing rust to form under the paint. He does not believe moisture trapped under the wrap would cause this and is likely a flaw in the factory paint.
Looking at my car when I wrapped it, the trunk where the factory spoiler did the same thing, though not to the extent yours did.
FS: Nameless exhaust (Greater Vancouver Area) FT86.ca Canada Classifieds 0 09-17-2020 04:09 PM
Greater Sacramento Area BRZ/FR-S Owners BunnyRZed Northern California 624 08-30-2016 04:21 PM
Vinyl wrap in PDX area for roof? Aztec Northwest 5 09-30-2015 12:21 PM
discounts on new BRZ in greater Los Angeles/OC area stlgrym3 BRZ First-Gen (2012+) — General Topics 2 03-19-2015 09:33 PM
Anyone know of any good and reputable shops in the greater LA area? zoomzoomers Southern California 13 10-01-2012 05:26 PM
