Drives: '13 BRZ Limited
22mm F / 16mm R swaybar change in handling
Problem I'd like to correct : a bit of mid-corner understeer. That being said, I don't want to do anything drastic to hurt the street-ability, so was considering sway bars.
Looks like most of the swaybar kits (RCE/Eibach/Whiteline) are 22mm/16mm rear equiv bars. Whiteline says this is a 123/167% increase in front stiffness and ~0/29%/65% increase in stiffness over my 2020 stock bars of 18mm/15mm as I understand it. The large increase in front diameter vs the pretty small increase in rear stiffness makes me think these sway bar kits would maybe increase understeer but I know there are a lot of other factors like motion rato/etc. The 22/16 seem to have come out before the 2017 refresh moved to a 15mm (vs 14mm) rear bar. Is that still a good size combo with stiffer than stock (and square) springs? (I'm running RCE SS1s w/330 lb/in F/R about 1" lowered from stock and 245/40-17 RS4 tires on 17x9 wheels. No other real changes. Alignment ~ -3.6/-2.4 camber with near zero front toe, tiny bit of toe in at the rear. Tire wear is good - they wear down evenly across the surface, but I know wear isn't necessarily equal to grip). 22/16 kit, or maybe just adding a 16mm rear bar instead and leave the stock front? Thanks in advance of advice. |
#2 |
FT86Club Official Vendor
Drives: Miata, GT350, FR-S
Looking at the RCE strut on their site, it looks like it might have less bump travel than OEM. That's more likely the source of your understeer than sway bar diameters. Everything else in your setup would make for a slightly loose car. Fix for that is raising the car to get it off the bump stops or adding camber plates with lower stack height. Our camber plates would add bump travel and fit the KW/ST made shocks that RCE offers. Adding more front bar would make it tighter than it already is.
Separate note, make sure you have OEM toe setting in rear. That's what we run. Too much rear toe in can cause mid corner and turn in push.
| The Following 2 Users Say Thank You to 949 Racing For This Useful Post: | 86league (09-27-2021), Goingnowherefast (09-28-2021) |
#3 | |
I'm toward the upper end of the ride height that I think would be decent to run with these - the helpers are completely compressed and there is a decent amount of "preload" on the springs. Worried going much higher would end up hurting droop travel and or/requiring several hundred pounds of load before the springs start moving in a bump that causes full extension. So not sure what to do about ride height. I know others are running these lower than I am. |
#4 |
Drives: Crapcan
The fix for mid corner understeer on my car was going stiffer on the front bar. I was already running the Perrin adjustable 22/16 setup. Going to the stiffest front bar setting helped get rid of most of it. I am on 7kg spring setup square.
#5 | ||
What kind and what size tires are you using? - Andrew |
#6 |
#7 | |
What are the details of your suspension? (how low, etc). What tires are you using? Was going to look this up but the garage link just reports "HTTP ERROR 500" |
#8 |
If the shock setup has enough bump travel and you have a decent amount of camber then the focus should be on adjusting weight transfer towards the rear. The RCE setup uses the same spring rate front and rear. we have found that works too.
Rake is the next thing to play with. Raising either end will raise roll center which effectively raises roll stiffness. So raising the rear has a similar effect to increasing rear sway bar diameter. I'd try that first. As a general rule, we try to stay within about 1/4" of OEM rake on any platforms we work with. Roll center axis is baked into the chassis and it's usually not a good idea to fight it. If raising rear ride height doesn't bring the balance back, then try a 16mm rear bar.
| The Following User Says Thank You to 949 Racing For This Useful Post: | 86league (09-27-2021) |
#9 | |
Agreed, some rake can help. I would consider adding stiffer springs all around...7 kg/mm works well on SS1 and is only a small change in ride. Could also try a 20/16 swaybar kit. - Andrew |
#10 |
What is OEM rake for these cars? It's been a while since my car was stock. I may have that measurement, but I'll have to check my notes.
#11 | |
Drives: Crapcan
I thought so too but it worked. I talked to a couple others before trying it. My setup: -1.25 ride height from stock RCE T2 7kg springs Verus camber plates, stock rear mounts -3.6 front camber, -2.4 rear, zero toe. White line anti dive kit adds .5 degree of caster. White line roll center correction. 22mm front sway full stiff, 16mm rear sway on soft.
#12 |
@Racecomp Engineering, @949 Racing - any comments on NoHaveMSG's experience going stiff/soft on a 22mm/16mm bar set to cure understeer? Apparently he's not the only one.
As to the recommendation of a 20/16mm bar combo (or the more common 22/16) - can anyone explain why this wouldn't jut add more understeer? It apparently works, but that's a +2mm on the front (or +4mm) on soft but only +1mm for the rear. Seems like that would just stiffen the front and add understeer. Soft/hard would allow +2mm/+2mm combo I guess. Thanks for the info! |
#13 |
Drives: Crapcan
My understanding is it has to do with the poor camber curve of the Macstruts.
#14 |
Mac struts don't have a camber curve. It's so small that you can consider it zero.
| FS: Whiteline 22mm front bar and 16mm rear bar | justint5387 | Brakes, Suspension, Chassis | 7 | 08-12-2019 08:11 PM |
| STX handling.. Whiteline 22mm? | Skurj | Tracking / Autocross / HPDE / Drifting | 6 | 08-22-2018 06:15 PM |
| FS: Whiteline 16mm Rear Swaybar | smg1138 | Brakes, Suspension, Chassis | 0 | 04-30-2017 06:37 PM |
| FS: Strano 22mm Front Swaybar (SOLD) | Gliderx | Brakes, Suspension, Chassis | 2 | 04-30-2016 12:15 PM |
