go_a_way1, MisterSheep
Old 09-21-2021, 05:27 AM   #23339
Bonburner
6/22/12-2/6/24
Bonburner's Avatar
Finally got my AC recharged!
I was getting warm/room temperature air blowing at a red light. Waiting to test later today and tomorrow when it hits high 80s to 90s to test how effective it is.
update: Much better. My car blows cold airs within 2 seconds of being turned on. It continues to blow cold air sitting at a red light. Wish I did this sooner!
Old 09-21-2021, 09:44 AM   #23340
SportyTaco86
SportyTaco86's Avatar
Drives: 2013 Scion FRS, 2012 Tacoma
So usually UPS drops off in my neighborhood between 6-8PM, meaning I expected to receive the rear sway bar yesterday and install it today. Luckily, UPS showed up around noon yesterday so I got the sway bar in (as well as the MXP catback). Great timing since as soon as I got the car back on the ground the sky opened up.
Took it for a quick drive to the store this morning, and I'm 99% sure the previous owner had a similar drop on it before it was traded in. The alignment was kind of funky before, but now it tracks straight and the steering wheel is no longer canted.
SportyTaco86 is offline   Reply With Quote
The Following 2 Users Say Thank You to SportyTaco86 For This Useful Post:
soundman98 (09-21-2021), Wally86 (09-21-2021)
Old 09-24-2021, 02:59 AM   #23341
Purist
Purist's Avatar
Drives: Subaru BRZ
New wheels. Copies of Work Meister 3 piece.
Sent from my SM-G973F using Tapatalk
Less More
Purist is offline   Reply With Quote
The Following User Says Thank You to Purist For This Useful Post:
RToyo86 (09-27-2021)
Old 09-24-2021, 11:34 AM   #23342
Cephas
Cephas's Avatar
Drives: 2017 Toyota 86 (860 SE)
Paid it off.
Cephas is offline   Reply With Quote
The Following 16 Users Say Thank You to Cephas For This Useful Post:
ACT86 (09-24-2021), BAM_Nyblodx16 (09-27-2021), Dadhawk (09-24-2021), DarkPira7e (09-30-2021), Jdmjunkie (09-24-2021), jflogerzi (09-25-2021), KMA KiCKz (09-24-2021), MJones_RB (09-24-2021), NLSP (09-27-2021), NoHaveMSG (09-24-2021), Overdrive (09-29-2021), Purist (09-24-2021), RToyo86 (09-27-2021), soundman98 (09-24-2021), StraightOuttaCanadaEh (09-24-2021), Ultramaroon (09-24-2021)
Old 09-24-2021, 04:15 PM   #23343
Originally Posted by Cephas View Post
Paid it off.
+5HP and +2MPG for not dragging that loan around any longer!
The Following 7 Users Say Thank You to Dadhawk For This Useful Post:
bcj (09-25-2021), Cephas (09-27-2021), MJones_RB (09-27-2021), NoHaveMSG (09-24-2021), Overdrive (09-29-2021), soundman98 (09-24-2021), Ultramaroon (09-24-2021)
Old 09-25-2021, 04:55 PM   #23344
jflogerzi
jflogerzi's Avatar
Because racecar Flat under panels from Verus and I already had the OEM JDM under panels. Turned out really good. Now just need Front Splitter and rear wing.
2013 Series 10 FRS #553
The Following 13 Users Say Thank You to jflogerzi For This Useful Post:
bcj (10-01-2021), boy_racer (10-23-2021), Cedric (09-30-2021), Cephas (09-27-2021), DarkPira7e (09-30-2021), kevaughan (10-16-2021), MJones_RB (09-27-2021), new2subaru (09-25-2021), NLSP (09-27-2021), Overdrive (09-28-2021), RToyo86 (09-27-2021), soundman98 (09-25-2021), wolffbite (10-06-2021)
Old 09-27-2021, 05:59 AM   #23345
Compelica
Compelica's Avatar
Drives: 86 GT
Gave it some exercise to a local dam today. Played about with the camera settings.
Compelica is offline   Reply With Quote
The Following User Says Thank You to Compelica For This Useful Post:
NLSP (09-27-2021)
Old 09-27-2021, 11:52 AM   #23346
RToyo86
RToyo86's Avatar
Drives: 17 Asphalt 86
Swapped in a AGM battery. I knew the old one was on its last leg but damn.. it practically fired up on the first half crank after install
Then gave it a bath and snapped a pic as it starts raining.
The Following 3 Users Say Thank You to RToyo86 For This Useful Post:
MJones_RB (09-27-2021), NLSP (09-27-2021), Wally86 (09-27-2021)
Old 09-28-2021, 06:01 PM   #23347
Overdrive
Sittin' Sideways
Overdrive's Avatar
Drives: 2016 Toyota FR-S
I've got this same plan. Looks great.
-O/D
2016 FR-S, Hot Lava
Overdrive is offline   Reply With Quote
Old 09-28-2021, 06:07 PM   #23348
Overdrive
Sittin' Sideways
Overdrive's Avatar
My driver's door lock actuator has been on its way out for a few months now, getting worse daily. I was having to manually lock and unlock the door just to ensure that it was secure. I'm surprised it didn't even last 5 years. The passenger one never had a problem but would occasionally make a strangled puppy noise during actuation. So, like almost anything you've got pairs of on here, I bought replacement parts for both and a buddy helped me install them (did the real work, really), made it look like child's play. Had a while-we're-in-there moment and put in my black door opening handles since the door panel was off. Installed the center console and steering wheel black trim pieces too since we were on a roll, so now I've got working door locks and as blacked out an interior as I can get with OEM pieces.
-O/D
2016 FR-S, Hot Lava
The Following User Says Thank You to Overdrive For This Useful Post:
Wally86 (09-29-2021)
Old 09-30-2021, 11:07 PM   #23349
DarkPira7e
Rust bucket enthusiast
DarkPira7e's Avatar
Finally started it after a year or two.
The Following 8 Users Say Thank You to DarkPira7e For This Useful Post:
Cephas (10-06-2021), DarkSunrise (10-01-2021), kevaughan (10-12-2021), MJones_RB (10-06-2021), RToyo86 (10-04-2021), soundman98 (09-30-2021), villainous_frx (09-30-2021), Wally86 (10-01-2021)
Old 10-01-2021, 11:49 AM   #23350
obscene_gesture
Drives: 2025 GR86 Premium MT
I finally got around to installing a cover for my steering wheel which has been peeling for a few years now. I went with a Loncky cover. It took several hours to sew it on. I didn't do a perfect job, but it's an improvement.
I also replaced the faux carbon fiber two-piece dash trim with the BRZ single-piece leatherette with red stitching. I wish it was suede with red stitching, but it's still a lot better.
obscene_gesture is offline   Reply With Quote
The Following 5 Users Say Thank You to obscene_gesture For This Useful Post:
DarkPira7e (10-05-2021), MJones_RB (10-06-2021), pope (10-02-2021), RToyo86 (10-04-2021), Wally86 (10-01-2021)
Old 10-04-2021, 06:26 PM   #23351
BigHugeFatGuy
BigHugeFatGuy's Avatar
Drives: 2016 FRS
Well, with FB and IG down, it's World Productivity Day.
Got these in the mail, so got them installed. Yes, I know brands don't match, -15hp. :/
BigHugeFatGuy is offline   Reply With Quote
The Following User Says Thank You to BigHugeFatGuy For This Useful Post:
Old 10-04-2021, 07:07 PM   #23352
Ashikabi
Ashikabi's Avatar
Those fit extended lugs?
Sent from my ONEPLUS A5010 using Tapatalk
