Old 09-14-2021, 11:05 PM   #1317
CSG Mike
CSG Mike's Avatar
Originally Posted by DarkPira7e View Post
What are people doing for a filter on a 4" inlet? I bought an AGP filter but it's too long. I'm going to run a turbo screen for the time being, but I'm curious what others have done. A filter straight off the inlet puts me straight into the front support framework
I'll likely end up putting an ugly looking pipe + filter into the pocket where the windshield washer reservoir lived.
Run a tube down to the washer reservoir area and feed it cold air, ideally.
Please tell me you have an oil cooler!
brianbui23 (01-30-2022), DarkPira7e (09-14-2021)
Old 09-14-2021, 11:10 PM   #1318
DarkPira7e
Rust bucket enthusiast
DarkPira7e's Avatar
It's in the works, that pocket is where I wanted to put an oil cooler with a fan.
Old 09-14-2021, 11:14 PM   #1319
CSG Mike
CSG Mike's Avatar
While more complex, you're better off running an oil cooler to the other side, so you can preserve that space for your intake air.
If you got the standard or similar intercooler, the GReddy oil cooler integrates with the JDL kit perfectly. No fan needed to keep oil temps down that way.
Old 09-15-2021, 07:06 AM   #1320
DarkPira7e
DarkPira7e's Avatar
For a street car, you think it'd be more beneficial to have open air while driving vs a fan for when stuck in traffic? This car likely won't ever see a track, it's going to be a fun cruiser with a 3-4 pull once a day while it's being driven.
It also will be driven up until it snows ( Maybe in the snow) so having the fan as a dual purpose time saver for me, so if I have to drive the car at -10 degrees f, I don't have to block off the oil cooler like I did with the Mishimoto unit.
Since I have you, what are your thoughts on the Turbo Guard? I really don't like the idea of it, but a fine mesh screen is better than nothing for the moment, until I figure out the intake piping
Old 09-15-2021, 12:10 PM   #1321
CSG Mike
CSG Mike's Avatar
Always keep fans.
You need something there to protect the turbo. How well sealed is your engine bay?
Old 09-15-2021, 03:02 PM   #1322
DarkPira7e
DarkPira7e's Avatar
Always keep fans.
I meant a fan on the oil cooler itself. This may be getting a bit far off topic, I'll make my own thread about it so I'm not wasting space on this one. Thank you for the help Mike!! To be continued?
Old 09-15-2021, 03:11 PM   #1323
CSG Mike
CSG Mike's Avatar
Oh, in the case of the oil cooler, open air is plenty fine for a street car. Fans are only used on oil coolers if there is no guided airflow, and there's no other way to package the coolers to get the flow needed.
DarkPira7e (09-15-2021)
Old 10-04-2021, 05:07 PM   #1324
trinidadj
Drives: '16 FRS-MT Ablaze Red
Hi Mike,
Do you have any pictures or how to go about mounting the greddy oil cooler with the JDL bash bar? Thanks
trinidadj is offline   Reply With Quote
Old 10-04-2021, 06:35 PM   #1325
CSG Mike
CSG Mike's Avatar
Originally Posted by trinidadj View Post
Hi Mike,
I actually have mine mounted "floating" with just foam cushioning on the top and bottom. Normally it's secured to the impact beam the bash bar replaces.
I've had it floating like this for 3 years without issue, and know of quite a few other users doing the same thing.
CSG has some GReddy oil coolers and bash bars in stock if you need it.
Old 10-14-2021, 03:31 AM   #1326
Jollibee86
Jollibee86's Avatar
Drives: 2014 Scion FR-S
Looking to buy a brand new kit from another member but the kit has the open dump wastegate. Is it possible to buy parts to turn into recirculated separately?
Jollibee86 is offline   Reply With Quote
Old 10-25-2021, 02:36 PM   #1327
nexceda
Hey All,
I’ve been scouring forums all of yesterday and today but to no avail.
I just installed the JDL V2 turbo kit on my car. GT2860RS turbo. Supposed to be a 3 bar map sensor but JDL didn’t send it. Mishimoto Oil Cooler. DW900CC Injectors. Ptuning EBCS. Turbo Smart waste gate (It’s a hyper gate 38 and has 2 pressure references. I used the bottom one) and BOV.
We flashed the ECU and the car starts when I give it WOT while cranking. It starts, but then the response is extremely lagging and starts jerking and sputtering in 1st or 2nd gear and won’t accelerate beyond a max of 40MPH. Very dangerous and can’t get up to freeway speeds.
The bov is stuck wide open and never closes. I have the T-fitting for it in the brake booster line before the bulge. I had heard that the automatics and the manuals differ in how they route and that could affect the vacuum.
I’m looking for a million suggestions rn. I’ve also hit up my tuner (Zach @ counterspace garage) to see if he knows anything.
Thanks for any help guys!
nexceda is offline   Reply With Quote
Old 10-27-2021, 11:10 AM   #1328
DarkPira7e
DarkPira7e's Avatar
PSA to anyone buying this kit new who plans to fit their own larger turbo-
Get a Vband flange, do not use T3. With JDL's choice to angle the turbo away from the engine, it is extremely hard to get the cartridge clocked for optimal oil drain, the T3 flange impedes. So if you're thinking big, and you're not using one of the turbos JDL provides as an option, do yourself a favor and opt for Vband.
Old 10-29-2021, 08:51 AM   #1329
trinidadj
Did you use the side bracket support? Or just the foam on top and bottom?
Old 10-31-2021, 08:21 AM   #1330
jmai
jmai's Avatar
Drives: 2019 PP BRZ
Hey guys, just purchased my kit and was wondering if the hks ssqv is a direct swap or any modifications needed to make it fit?
jmai is offline   Reply With Quote
HKS Supercharger owners thread wbradley Forced Induction 1054 10-26-2024 01:18 PM
P&L Turbo kit Owners thread Hawaiian Forced Induction 73 07-07-2018 02:31 AM
To Greddy Turbo Owners (or SBD/Zage Turbo).... Melted Radiator Fans? General Opinion? xuimod Forced Induction 106 09-01-2016 07:33 PM
**Offical 213/323/626/818 owners thread** mr. slim Southern California 71 10-07-2013 12:58 PM
P&L Turbo Owners Topic Thread GTB/ZR-1 Forced Induction 4 09-01-2013 06:27 PM
