Old 08-12-2019, 01:03 PM   #71
SuperTom
SuperTom's Avatar
Drives: C5, GT-86, '24 Colorado TrailBoss
Originally Posted by TofuJoe View Post
Good-win Racing confirmed that 17x8 won’t work with the PP brakes.
Maybe a small slide on spacer would do the trick
SuperTom is offline   Reply With Quote
Old 08-12-2019, 01:06 PM   #72
timurrrr
timurrrr's Avatar
Drives: 2022 GR86
From the PP Brembo thread: a 3mm spacer might be enough
Originally Posted by stanrc View Post
I have the Konig Hypergram 17x8 +40 and I would say technically they do fit. The rubber cap on the bleed valve comes incredibly close though. I put on a 3mm spacer on the front just to be safe.
Old 12-08-2020, 02:24 PM   #73
timurrrr
timurrrr's Avatar
Drives: 2022 GR86
Ordered as set of Hypergrams in 17x9 et40 5x100 with Bridgestone RE71R in 245/40 for autox next year.
Took some pictures on my Performance Package Brembos for other folks to have a better idea how these look.
As you can see, there's plenty of clearance even if you turn the bleeder cap the wrong way
The Following 6 Users Say Thank You to timurrrr For This Useful Post:
jflogerzi (12-09-2020), mrg666 (12-19-2020), solidONE (12-22-2020), SuperTom (08-15-2025), Tatsu333 (06-21-2023), weepel (08-03-2021)
Old 12-19-2020, 12:30 AM   #74
jflogerzi
jflogerzi's Avatar
Stock PP suspension?
2013 Series 10 FRS #553
The Following User Says Thank You to jflogerzi For This Useful Post:
SuperTom (02-12-2022)
Old 12-22-2020, 07:06 PM   #75
timurrrr
timurrrr's Avatar
Drives: 2022 GR86
CSG Spec Tein Flex A, max camber in the front (~-3.1º)
The Following User Says Thank You to timurrrr For This Useful Post:
jflogerzi (12-22-2020)
Old 12-22-2020, 07:20 PM   #76
NaturallyAspirated
NaturallyAspirated's Avatar
Drives: 2019 BRZ w/ PP
Man that looks good...
NaturallyAspirated is offline   Reply With Quote
The Following User Says Thank You to NaturallyAspirated For This Useful Post:
timurrrr (12-23-2020)
Old 12-22-2020, 07:34 PM   #77
jflogerzi
jflogerzi's Avatar
Second. Super clean
Old 12-22-2020, 09:18 PM   #78
solidONE
solidONE's Avatar
Drives: FR-S Whiteout
a lot of yes.
Intent > Content
Old 05-22-2021, 03:04 PM   #79
CBRZY
CBRZY's Avatar
Drives: 2017 BRZ PP (White)
Originally Posted by solidONE View Post
a lot of yes.
are you running with hubcentric rings?
CBRZY is offline   Reply With Quote
Old 05-22-2021, 03:54 PM   #80
solidONE
solidONE's Avatar
Not my car, but I did have aluminum hubcentric ring in my aftermarket wheels.
Intent > Content
Old 05-22-2021, 05:35 PM   #81
jflogerzi
jflogerzi's Avatar
I will have some 17x8 hypergrams up for sale soon if your in the SoCal area
Old 09-13-2021, 10:43 AM   #82
weepel
Dr. Fünke, Analrapist
weepel's Avatar
Drives: 2013 BRZ Limited, 2004 WRX STI
Recently purchased some 17x9 +40 Hypergrams in gunmetal for my BRZ. Had them wrapped in Yokohama Advan A052 235/40/17s. I'm running stock dampers lowered 1" on Eibach springs. Heads up I needed 3mm spacers to clear the spring perch. Also with the meatier tires, on track I consistently knocked out my side markers.
Hat tip to @ATL BRZ for the tip on the 3mm spacers, I would've been a sad panda without them
Also as noted by @jflogerzi, the 17x9s easily clear BBKs. I'm running the Stoptech C43 kit on mine and have plenty of clearance.
2013 Subaru BRZ Limited
2004 Subaru WRX STI
My Garage, past and present
Last edited by weepel; 09-13-2021 at 10:54 AM. Reason: Photos were initially added as URLs, not embedded
weepel is offline   Reply With Quote
The Following 2 Users Say Thank You to weepel For This Useful Post:
ATL BRZ (09-21-2021), SockMonkey (09-14-2021)
Old 09-14-2021, 01:09 PM   #83
SockMonkey
Drives: '13 BRZ Limited
Awesome info man, thanks! Did you have to run the 3mm spacer with the 235/40's as well? Besides the springs anything else? How much camber are you running? Any camber bolts?
SockMonkey is offline   Reply With Quote
Old 09-14-2021, 01:55 PM   #84
weepel
weepel's Avatar
No problem! I do not have to run any spacers on the 235/40/18s on my 18x8 +35 Enkei NT03s (I've kept those wheels to be my "street" setup). I haven't had the Hypergrams wrapped in anything other than the 245/40/17 Advans. I am running "crash bolts" which give me about -1° up front, but otherwise using stock top hats.
I do plan on upgrading eventually to a decent set of coilovers as after ~7 years of tracking the car, the stock dampers have taken a beating and it would be nice to get more camber and to not have to run the 3mm spacers for these wheels.
2004 Subaru WRX STI
Konig Rims- what do you think? KatrinaR Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 3 05-25-2015 01:35 PM
Konig Torch 18x8.0 +35 khan Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 1 05-21-2014 12:27 AM
WTB- Konig Daylites solort Want-To-Buy Requests 0 01-07-2014 11:07 PM
Konig Wheels pghfan19 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 14 04-25-2013 12:24 AM
Konig deception oaroyale Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 11 02-02-2013 09:02 PM
