Old 07-29-2012, 09:10 PM   #15
serialk11r
Drives: '06 AM V8V Coupe
Okay I dug it up:
http://kaizenfactor.wordpress.com/20...e-know-so-far/
So while it's not the same transmission, I think it's probably safe to say it's not a good idea to try and put more than 30% above stock torque through that gearbox.
The Following User Says Thank You to serialk11r For This Useful Post:
BAE (07-29-2012)
Old 07-29-2012, 09:30 PM   #16
mike2100
mike2100's Avatar
Drives: 23 BRZ
From the lap times I've been seeing so far, the car hangs with e36 M3s quite well as it is.
mike2100 is offline   Reply With Quote
Old 07-29-2012, 10:05 PM   #17
Coheed
Coheed's Avatar
Drives: DGM BRZ Limited
Originally Posted by serialk11r View Post
Okay I dug it up:
It is rumored that the BRZ uses the same transmission as the S15 silvia. So read this: http://zilvia.net/f/tech-talk/362303...n-dummies.html
The gearbox may be "weak" but it should be plenty for 99% of owners out there.
Coheed is offline   Reply With Quote
Old 07-29-2012, 10:22 PM   #18
serialk11r
99% of owners won't be putting turbo/SC on their car. The 1% that do should probably worry a little about it.
Old 07-29-2012, 10:46 PM   #19
Coheed
Coheed's Avatar
Even the guys going turbo should be able to put 300wtq down without having issues with it blowing. That's my guess anyway, given the updates they have made with that transmission in the past 10 years.
If they gave it the S2k treatment, it will hold up to more than that even.
Old 07-29-2012, 11:11 PM   #20
Coheed
Coheed's Avatar
Billet gearset? It's pricey, but would make the transmission handle 400-500ftlbs
Old 07-29-2012, 11:20 PM   #21
chulooz
Registered you sir
chulooz's Avatar
Drives: 99 impreza coupe
Quoted for future reference. If a quality and proven kit comes out it will be a hit.
chulooz is offline   Reply With Quote
Old 07-29-2012, 11:36 PM   #22
BAE
BAE's Avatar
Drives: BRZ Ltd WRB
On slower tracks with a lot of turns and autocross the 86 should keep up well with an E36 M3. On faster tracks, it will suffer from worse power/weight ratio. I need 235 hp to match the power/weight ratio with a euro spec 3.0 M3. Is this important? Yes, two of my track day buddies are driving E36M3's.
Enkei RPF1/K&N/Perrin crank pulley/Visconti Stg1/Perrin catback and overpipe/KW V3
BAE is offline   Reply With Quote
Old 07-30-2012, 02:04 AM   #23
rice_classic
rice_classic's Avatar
Drives: Nevermorange FRS
Originally Posted by pcasso87 View Post
What about an inverted mounted supercharger mated to a sequential turbo system that uses unequal length headers to ease the pressure created from the flux capacitor therefore creating more spool from an inverted system. Wouldn't that be a better option for our cars?
Old 07-30-2012, 07:10 AM   #24
a-spec
متعة أفضل من السرعة
a-spec's Avatar
Drives: Talbot Arizona
Hope for you that 235hp will be enough. Euro spec M3 are as powerful than their brakes are weak
Straight Outta Eighties Lightweight GTI Taliban
a-spec is offline   Reply With Quote
Old 07-30-2012, 12:21 PM   #25
track_warrior
Track Junkie
track_warrior's Avatar
Drives: Faster than the Stig!
Originally Posted by rice_classic View Post
Compensating a heavy car with horsepower is like giving an alcoholic cocaine to sober him up...
track_warrior is offline   Reply With Quote
