Old 07-29-2012, 07:28 PM   #1
RandomHero
SW5 Driver
RandomHero's Avatar
Drives: Asphalt FRS
HELP! Stone chip!
Hey guys got a stone chip about a week ago? Ordered a paint pen immediately. Got it today, looked at the paint chip and there are 2 fine spots of rust!!
Can I still use a paint pen? do i need to sand now? Is there any solvents i should use? Please help! Thanks in advance!
RandomHero is offline   Reply With Quote
Old 07-29-2012, 07:36 PM   #2
Gen
Drives: Scion FR-S
I wouldn't even bother with the paint pen, to be honest. 95% of the time it looks worse than the chip. You'll get more, I promise...
You could do what the cool kids do and bust out a sharpie.
Gen is offline   Reply With Quote
Old 07-29-2012, 07:38 PM   #3
RandomHero
SW5 Driver
RandomHero's Avatar
Drives: Asphalt FRS
But the chip has gone to the metal obviously, wont the rust get worse? There is no way im using a sharpie on this car. I intended to sand the paint pen with 1500 and 2000 grit sand paper and the cut it in with a nice polish but I dont know how to prep such a small area with rust
Old 07-29-2012, 07:40 PM   #4
20valvewynn83
20valvewynn83's Avatar
Drives: 2013 FRS/01 Tacoma
whats the location of the chip
20valvewynn83 is offline   Reply With Quote
Old 07-29-2012, 07:44 PM   #5
RandomHero
SW5 Driver
RandomHero's Avatar
Drives: Asphalt FRS
On the roof above the windshield
Old 07-29-2012, 07:50 PM   #6
RandomHero
SW5 Driver
RandomHero's Avatar
Drives: Asphalt FRS
Pics. Sorry if they are a little blurry, iPhone doesnt have macro mode.
Old 07-29-2012, 08:14 PM   #7
C. Charles Hahn
Drives: GMC Sierra Crew Cab
For an area as small as a chip, what I use is a small pick like they use when you go to the dentist. It allows me to "scrape" the rust away and access clean metal without enlarging the chip or otherwise causing damage to the surrounding area.
Really, anything small and sharp like that should work. Even a safety pin or bulletin board push pin if you're careful.
Charlie
C. Charles Hahn is offline   Reply With Quote
Old 07-29-2012, 08:18 PM   #8
Gen
Drives: Scion FR-S
Ah sorry, missed the part about the rust. That changes things.
Old 07-29-2012, 08:36 PM   #9
RandomHero
SW5 Driver
RandomHero's Avatar
Drives: Asphalt FRS
Ok I think power fist makes a "Dentist Pick Kit" I'll check out NAPA tomorrow. Poor FRS i wish this hadnt happened so soon!
Old 07-29-2012, 09:50 PM   #10
picus
Drives: FJ
Hey - you're in Ontario so this should help.
Head over to Canadian Tire, go to the automotive paint section and get some "rust converter". They will have an aerosol and a ~8oz liquid. Get the liquid. Put a little of the liquid on a microfiber (wear gloves if you're concerned about your manicure. ) and dab it on the chips liberally. Do this out of sunlight (you want the paint cold). Wait ~10 min then check the rust. It should be grey, the rust converter will have turned it to primer. If it isn't; re-apply. When it is fully grey, apply touch up *lightly*.
If you need help with the actual aesthetic of the touchup let me know. The rust converter will take care of any rust concerns. If you're losing your mind over it you can lightly sand the rust ahead of time (put alittle 2k grit on the tip of a pencil) and apply primer; but the rust converter should take care of it.
picus is offline   Reply With Quote
The Following User Says Thank You to picus For This Useful Post:
RandomHero (07-29-2012)
Old 07-29-2012, 11:17 PM   #11
RandomHero
SW5 Driver
RandomHero's Avatar
Drives: Asphalt FRS
Thanks ill give that a shot! From what ive gathered from google. I might scratch at this with a pick or a little sand paper, apply the rust converter u recommended, prep it, primer pen it, paint pen it, sand lightly, clear pen it, sand lightly, polish. I want it to be as invisible as possible as I have an opticoat appointment booked on the 10th!
Old 07-29-2012, 11:29 PM   #12
Hamza7
Drives: MiniVan
If your near Markham, I have a extra dentist pick I got in a 4 pack. Their also great for cleaning interior LOL. I would also NOT recommend sanding a spot so close to the edge. Paint on the edge of a panel like that is typically very very thin so sanding it could raise the potential to go through the clear of the "rest" of the area. I also have a 1mm disposable paint brushes that are ideal for laying down even, precise coats of paint. Way better then paint pens, personally I recommend paint pots.
But anyways come by if you want to grab the stuff, I have extra I'm not going to use this year anyways.
Hamza7 is offline   Reply With Quote
The Following User Says Thank You to Hamza7 For This Useful Post:
C. Charles Hahn (07-30-2012)
Old 07-29-2012, 11:35 PM   #13
rcm47
rcm47's Avatar
Drives: 13’ FRS (traded), 18’ CWP BRZ tS
How much is a paint pen? Can I just go to a Subaru dealership and purchase one?
rcm47 is offline   Reply With Quote
Old 07-30-2012, 12:40 AM   #14
C. Charles Hahn
Agreed. What I usually use to apply touch-up is one of these:
[ame="http://www.amazon.com/Paint-Cans-E-Z-APPLICATOR-PLASTIC/dp/B002GEONGU"]EZ Paint Cans 78000 E-Z DABBER APPLICATOR(40) E-Z MIX PLASTIC MIXING: Amazon.com: Home & Kitchen[/ame]
Charlie
Anyone changed out ECU Chip yet? pete39sp Engine, Exhaust, Transmission 7 07-28-2012 04:07 PM
First rock chip feldy Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) 8 06-27-2012 12:16 AM
