Old 09-02-2021, 03:32 PM   #15
Dzmitry
Dzmitry's Avatar
Drives: 2018 Subaru BRZ Limited with PP
Originally Posted by OkieSnuffBox View Post
That's because in the real world it's not really practical to smack the rev limiter and then shift. That will cost more time then just going to 3rd.
True, but as the calculation states and even the photo from the OP shows, you don't need to redline at 7500 to hit 60. It's at like 7200-7300 in the photo. You would think from a couple redline tests to feel out the car, Jason would have easily noticed it gets past 60. Either way, I agree with what you're saying.
Dzmitry is offline   Reply With Quote
Old 09-02-2021, 04:04 PM   #16
trippinbillies40
trippinbillies40's Avatar
Drives: '22 WRB
It does 59 and change in 2nd according to GPS. True 0-60 requires a shift to third. At least in a BRZ premium...
trippinbillies40 is offline   Reply With Quote
Old 09-02-2021, 04:25 PM   #17
bcj
Geo Tyrebighter Esq
bcj's Avatar
Drives: '13 scion fr-s
A lot of the European and Asian reviews are all in Kph.
100 Kph = 62.1371 Mph
So there's that too.
Straight line bench racing applied to a vehicle tuned for corner performance.
Obviously Needs More Power!
The Following 2 Users Say Thank You to bcj For This Useful Post:
JesseG (09-06-2021), NoHaveMSG (09-02-2021)
Old 09-02-2021, 04:37 PM   #18
Sasquachulator
Pavement Grey
Originally Posted by FlyingJett View Post
It hits 100km/h in the second gear
Im going to have to check....
i could have sworn it was mentioned it hits 56 in second and you need to shift into third to get to 60
Old 09-02-2021, 04:49 PM   #19
OkieSnuffBox
Drives: '23 BRZ Limited
In reality, we are all splitting hairs because there is nothing else to talk about since the car still won't be here for months.
The Following User Says Thank You to OkieSnuffBox For This Useful Post:
Dzmitry (09-03-2021)
Old 09-02-2021, 04:59 PM   #20
timurrrr
timurrrr's Avatar
Drives: 2022 GR86
But why?..
Is it because the rev limiter is lower? Gear ratios are different?
Or the real tire height is smaller by just enough?
Have you checked the pressures or rear tires?
Old 09-02-2021, 05:02 PM   #21
trippinbillies40
Drives: '22 WRB
Originally Posted by timurrrr View Post
But why?..
Funny you should ask about tire pressures. Definitely were not checked and were sky high after being delivered, so yes I'm assuming it's tire height variation.
Old 09-02-2021, 05:09 PM   #22
Pete
Pete's Avatar
Drives: 22 BRZ
"most speedometers are designed to read slightly high. European regulations in particular allow most cars to display 10 percent plus 6 kilometers per hour (3.7 mph) above actual speed, but those same regulations do not allow for the reporting of a speed lower than the car is actually traveling."
https://www.roadandtrack.com/car-cul...ters-accurate/
Cammisa was probably using GPS because speedometers are designed to tell you that you are going a little faster than you actually are.
Edit: just realized that the article I linked was written by Cammisa. lol
2013 FRS -> 2011 CTS-V -> 2006 Cayman S -> 2015 GTI -> 2022 BRZ
Pete is offline   Reply With Quote
The Following 2 Users Say Thank You to Pete For This Useful Post:
Dadhawk (09-02-2021), trippinbillies40 (09-02-2021)
Old 09-02-2021, 05:35 PM   #23
RZNT4R
Professional Mechanic
Drives: 2017 86 6MT Oceanic
You all will remember that the change to a 4.3 ratio in 2017 came with mentions that you now needed to shift 3rd to hit 60.
Since the new car goes back to 4.1 (sadly) and the engine has the same redline and the transmission has the same ratios, it was safe to assume it would go back to being able to hit 60 in 2nd.
Old 09-02-2021, 05:38 PM   #24
I think we have two different conversations going here. It was made very clear in almost all reviews, and even some tests by folks here, back in 2012 that the Twins had to go to third gear to get to 60MPH on a MT. The AT easily gets to 60MPH in second gear, but because it has no launch control, it does it significantly slower than the MT. I'm talking stock here of course.
As far as the 2022 Twins, I think we'll have to wait and see the reviews, but it does appear that it does get there in 2nd gear on the MT. Whether or not there is enough buffer to overcome Speedometer "lies" is another question.
timurrrr (09-02-2021)
Old 09-02-2021, 05:52 PM   #25
FlyingJett
Drives: Scion frs
In 1 gen AUTOMATIC.
It has longer gears than manual.
FlyingJett is offline   Reply With Quote
The Following User Says Thank You to FlyingJett For This Useful Post:
Old 09-02-2021, 07:00 PM   #26
timurrrr
timurrrr's Avatar
Drives: 2022 GR86
Hmm but higher tire pressures would cause higher GPS speeds, not lower...
Old 09-02-2021, 07:37 PM   #27
timurrrr
timurrrr's Avatar
Drives: 2022 GR86
For the sake of illustration, assume that a stock GTI, when equipped with the OEM tire—a Bridgestone Potenza S001—has a perfectly accurate speedometer. Replacing its tires with, say, a Kumho Solus TA71 in the same 225/40-18 size would result in a road speed of 75.6 mph when the GTI’s speedo says 70.
In other words, a potentially big ticket. That nearly eight-percent difference in rolling circumference is calculated from the two tire manufacturers’ published specifications for revolutions per mile. And that brings us back to the fun part: The significant variation between two tires of the same size highlights just how silly it is to calculate speed via wheel rpm.
imma head out
The Following 2 Users Say Thank You to timurrrr For This Useful Post:
JesseG (09-06-2021), Ohio Enthusiast (09-02-2021)
Old 09-02-2021, 07:41 PM   #28
Ohio Enthusiast
Drives: 2018 BRZ
That's a really good point. It goes along with the (sometimes significant) variations in measured tread and section widths between tires of the same nominal size. Tread depth differences will also impact overall tire diameter.
