Old 09-02-2021, 01:37 PM   #1
Panda Grahams
Panda Grahams's Avatar
Drives: '22 BRZ
Post 60 MPH in 2nd
I thought it might be interesting to note that the GR 86 will hit 60mph in 2nd gear, as seen in TheTopher's POV test drive. I think every video I've seen of attempted drag races and 0-60 tests have shifted to 3rd just before hitting 60. Do we think hitting 60 in second will reduce the claimed 0-60 times by Toyota and journalists?
Name:  60 in 2nd.jpg
Panda Grahams is offline   Reply With Quote
The Following User Says Thank You to Panda Grahams For This Useful Post:
dowroa (09-02-2021)
Old 09-02-2021, 01:38 PM   #2
series.trackday
series.trackday's Avatar
Drives: '17 Subaru BRZ series.Yellow
Of course it will. That's why you CAN hit 60 in second.
series.trackday is offline   Reply With Quote
Old 09-02-2021, 01:44 PM   #3
bucketfoot
bucketfoot's Avatar
Drives: 2020 Toyota GT86
Yep, has absolutely nothing to do with the drivability of the car. This 100% for a completely useless (in the real world) lower 0-60 time.
This post sent using 100% recycled electrons.
bucketfoot is offline   Reply With Quote
The Following 2 Users Say Thank You to bucketfoot For This Useful Post:
dowroa (09-02-2021), JesseG (09-06-2021)
Old 09-02-2021, 01:53 PM   #4
Panda Grahams
Drives: '22 BRZ
Gotcha - and totally agree!
I am curious if Toyota's time had included hitting 60 in second, because it seems like they haven't. In C&D's test I think they hit around a 5.8(?), while Toyota claims 6.1. All-in-all it's too early and ultimately not important. I'm just very excited and trying to gain a sense of the car prematurely. Hitting redline is going to feel and sound great.
JesseG (09-06-2021)
Old 09-02-2021, 01:55 PM   #5
dowroa
Old Guy
Drives: 16 STi, 22 MX-5 RF BBS, 04 OBS RPA
Useful to know the end gearing with the stock tire circumference and if that changes per gear.
For autoX, it baselines and tire size changes you need to make for course setup.
Since this is a car that was primarily designed for work such as this, that is important.
From what I can see in first and second (I haven't found all the ratios anywhere yet), it doesn't look like an appreciable change.
Interested to see if these cars make it into an SCC2 or something similar.
Last edited by dowroa; 09-02-2021 at 01:58 PM. Reason: Updating with more information related to SCCA Solo II AutoX classing thoughts
dowroa is offline   Reply With Quote
The Following User Says Thank You to dowroa For This Useful Post:
Panda Grahams (09-02-2021)
Old 09-02-2021, 01:58 PM   #6
Vital
Drives: 2015 BRZ
the AT in the current gen hit 60mph in 2nd gear
The Following 3 Users Say Thank You to Vital For This Useful Post:
Dadhawk (09-02-2021), FlyingJett (09-02-2021), whataboutbob (09-02-2021)
Old 09-02-2021, 02:00 PM   #7
timurrrr
timurrrr's Avatar
Drives: 2022 GR86
According to https://www.tremec.com/calculadora.php,
at 7500 rpms with 4.1 FD and tire height of 24.618" (215/45R17) and the 2.189 transmission ratio in 2nd gear, the car should reach 61.2.
The 215/40R18 are even slightly taller (24.772") and reach 61.59.
Both are less than 100 km/h (~62.1 mph).
The Following User Says Thank You to timurrrr For This Useful Post:
Dzmitry (09-02-2021)
Old 09-02-2021, 02:02 PM   #8
timurrrr
timurrrr's Avatar
Drives: 2022 GR86
LMGTFY
https://www.subaru.com/2022-brz
-> https://media.subaru.com/pressreleas...l-new-2022-brz
-> https://s3.amazonaws.com/subarumedia...ecs_-FINAL.pdf
dowroa (09-02-2021)
Old 09-02-2021, 02:07 PM   #9
timurrrr
timurrrr's Avatar
Drives: 2022 GR86
What's interesting is that Jason Cammisa specifically says he tested and the car only reached 59 in 2nd...
https://www.instagram.com/p/CSsZdsBFLW-/
The Following 2 Users Say Thank You to timurrrr For This Useful Post:
dowroa (09-02-2021), Pete (09-02-2021)
Old 09-02-2021, 02:10 PM   #10
mazeroni
Drives: 2013 Scion FR-S Series 10
But that was with the Primacy tires that are 17" right? So the tire is less tall... if I'm understanding correctly.
mazeroni is offline   Reply With Quote
Old 09-02-2021, 02:11 PM   #11
timurrrr
timurrrr's Avatar
Drives: 2022 GR86
See my calculations above, they were for 17's.
mazeroni (09-02-2021)
Old 09-02-2021, 02:47 PM   #12
dowroa
Old Guy
I am assuming he uses GPS to calculate speed and not the speedo, hence the need for the shift in reality.
Old 09-02-2021, 02:59 PM   #13
OkieSnuffBox
Drives: '23 BRZ Limited
That's because in the real world it's not really practical to smack the rev limiter and then shift. That will cost more time then just going to 3rd.
The Following User Says Thank You to OkieSnuffBox For This Useful Post:
Old 09-02-2021, 03:23 PM   #14
FlyingJett
Drives: Scion frs
Originally Posted by Vital View Post
the AT in the current gen hit 60 in 2nd gear
It hits 100km/h in the second gear
FlyingJett is offline   Reply With Quote
The Following User Says Thank You to FlyingJett For This Useful Post:
Vital (09-02-2021)
