Old 09-01-2021, 07:15 PM   #80347
Captain Snooze
Because compromise ®
Captain Snooze's Avatar
Drives: Red Herring
Originally Posted by MuseChaser View Post
If you really needed to bore a board, is there a specific bit you've all found to be most effective? Does it come easily, or are there some practice drills you'd recommend?
Do we really need a rhetorical question thread?
Captain Snooze is offline
Old 09-01-2021, 07:16 PM   #80348
weederr33
Airborne at your service
weederr33's Avatar
Drives: '17 BRZ Series.Yellow
Man, I just saw an Evo IX MR on carsandbids and I honestly just get sad. The Evo is one my fav cars of all time and I know I'll probably never get to own one.
That is correct. You never will. Now go cry in a corner!
Jk, I feel the same way when I see various cars.
MS, CSCS, TSAC-F, CPT
weederr33 is offline
The Following User Says Thank You to weederr33 For This Useful Post:
spcmafia (09-02-2021)
Old 09-01-2021, 07:33 PM   #80349
MuseChaser
Feeling like thinking....
MuseChaser's Avatar
Can't we all just get along?..
No need to answer...'twas a rhetorical question.
If there are (at least) two sides to every issue...which side gets to label the other side as (insert favorite insult against intelligence or morality here)?
If all one has are misquotes, mischaracterizations, an almost pathological dependence upon strawman arguments, willful misrepresentation, and/or a total lack of reading comprehension , does that mean they still win arguments because they can write well, type a lot,and have lots of time on their hands?
Yes. I'm very pissed at being completely and totally misrepresented many times by certain prolific pompous self-righteous condescending close-minded fear-mongering posters here,to the point where correcting their misrepresentations of my statements would be a full-time job...and I just can't anymore. Hopefully,the reading comprehension skills of the majority of readers here will serve that function.
I tried... I really tried...but some pigs will never sing.
Ain't life fun?
Drive like everyone's life around you depends on it...
MuseChaser is offline
The Following User Says Thank You to MuseChaser For This Useful Post:
soundman98 (09-02-2021)
Old 09-01-2021, 08:25 PM   #80350
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
If all one has are misquotes, mischaracterizations, an almost pathological dependence upon strawman arguments, and a total lack of reading comprehension or willful misrepresentation, does that mean they still win arguments because they can write well, type a lot,and have lots of time on their hands?
Ain't life fun?
You probably wouldn't be surprised at the amount of posts I type, and then delete. I don't have an issue with someone expressing a different point of view even if it is drastically different then my own unless there is blatant misinformation. There are a lot of subjects I just won't touch here anymore.
One of them is oil coolers lol
NoHaveMSG is offline
The Following 5 Users Say Thank You to NoHaveMSG For This Useful Post:
Dadhawk (09-02-2021), MuseChaser (09-01-2021), soundman98 (09-02-2021), Spuds (09-01-2021), Ultramaroon (09-02-2021)
Old 09-01-2021, 09:25 PM   #80351
Sapphireho
Famous Potatoes
Sapphireho's Avatar
Drives: '15 ultramarine
I hope Jesse finds some help soon.
Me too.
Sapphireho is offline
Old 09-01-2021, 09:37 PM   #80352
Sapphireho
Famous Potatoes
Sapphireho's Avatar
@NoHaveMSG, how does your push button ignition work? I've thought about it since we talked. I think my Lotus is much different. You need a key to start it, then press the buttom. You put the key in a normal ignition on the steering column, and turn to run, then press the start button. To emergency turn off, same as normal: turn the key.
How do you normally turn your car off?
Old 09-01-2021, 10:32 PM   #80353
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
With key fob in the car clutch in and push button to start. Shut off is the same. If the car is moving you have to hit the button rapidly 3 times to shut the engine off.
Old 09-01-2021, 10:34 PM   #80354
Sapphireho
Famous Potatoes
Sapphireho's Avatar
Wow, can an old fashioned kill switch be put on the dash?
Old 09-01-2021, 10:47 PM   #80355
Right?! THERE'S ABSOLUTELY NO DIFFERENCE BLAH BLAH BLAAAH...
um...
Ultramaroon is offline
NoHaveMSG (09-02-2021)
Old 09-01-2021, 10:48 PM   #80356
Sapphireho
Famous Potatoes
Sapphireho's Avatar
um...
Wtf?
Old 09-01-2021, 10:57 PM   #80357
Wtf?
Are we not on the same page with the reference?
Old 09-02-2021, 12:03 AM   #80358
There is NO NEED for an oil cooler! Just use thicker oil! BLAH BLAH BLAAAH...
Old 09-02-2021, 12:34 AM   #80359
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
I may try to add something in the future I dunno yet. I have another engine harness I can mess with.
Old 09-02-2021, 12:37 AM   #80360
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
You are giving me anxiety. Though I really do need to get my logging setup figured out. I have no communication from the gauges to the logger and I need to calibrate the tach signal. I would think telling it that it’s a 4cyl 4 stroke would be enough but it is reading off. And it isn’t double the reading so it isn’t recording it as twin spark setup It shows 7-750rpm as about 1000-1100 rpm.
