Old 08-25-2021, 01:54 PM   #1
LightningCount86
LightningCount86's Avatar
Drives: 2013 Scion FRS
Hunting down my P0172
So I've been getting a rich code in my 2013 FRS, It's accompanied by a raspy start up that feels like it wants to stall but never actually does (it always evens out a few seconds after starting), a hesitation around 4000rpm that becomes more noticeable at WOT, and a pretty consistent misfire around 2.5-3000rpm.
I've cleaned the MAF, checked the intake and oxygen sensor, Replaced the spark plugs and had all 8 injectors cleaned and tested.
Mods include an intake, ft86factory header, nameless helmholtz resonator, and an invidia n1 catback exhaust
I've been chasing this issue on my own for over a month now so any input helps,
thanks in advance
LightningCount86 is offline   Reply With Quote
Old 08-25-2021, 06:12 PM   #2
x808drifter
LMGTFY
x808drifter's Avatar
Drives: 13 FRS, 91 Miata
thanks in advance
Catted or uncatted?
If your not tuned I'd get that done first.
Old 08-25-2021, 07:14 PM   #3
LightningCount86
Originally Posted by x808drifter View Post
Catted or uncatted?
It's the catted UEL, and do you really think a tune would change that much ?
Old 08-25-2021, 07:42 PM   #4
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
You are not tuned???
And the part you have is a nameless front pipe. The helmholtz resonator is just an add on to the part. This means you also have a high flow cat in the front pipe too.
Old 08-25-2021, 11:35 PM   #5
LightningCount86
Yes that's correct, If it was simply a tuning issue though that'd probably make my job alot easier which is why I initially bet against it being the problem.
Old 08-26-2021, 06:48 AM   #6
x808drifter
LMGTFY
Miss-posted a bit.
If you were uncatted it would matter, being catted I don't think it would matter as much, but I could be wrong.
Old 08-26-2021, 11:30 AM   #7
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
Probably not, but it is not helping. I'd be curious what a log looks like. Could be coil pack but I would think it would be misfiring more.
Old 08-26-2021, 12:29 PM   #8
LightningCount86
Well like I said there is a pretty consistent misfire, usually around 2.5-3000rpm
Old 08-26-2021, 12:32 PM   #9
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
Reading comprehension fail on my part I would say likely a coil pack. Would be nice if you had a way to log so we could see which cylinder was misfiring, then rotate the packs and see if it follows to the other cylinder.
Old 08-27-2021, 07:03 PM   #10
LightningCount86
I'm ordering a set of coil packs tonight, I'll be sure to post an update on what happens.
I also heard someone say it could possibly be the camshaft position sensor but imma check this first and see what happens
Old 08-31-2021, 01:12 PM   #11
zc06_kisstherain
zc06_kisstherain's Avatar
Drives: SWP BRZ
small and easy fix first then move to next step
enjoy replacing coilpacks which i dont want to do with this boxer engine
i would replace spark plugs when you do this as well
Old 09-04-2021, 01:25 PM   #12
LightningCount86
Update: So I changed out the coilpacks, car feels noticeably faster at lower rpm but still has the hiccup and hesitation at 2000 and 4000 rpm
Old 09-08-2021, 12:39 AM   #13
FrickingReallySlow
Drives: 2015 FR-S
You mentioned you have an aftermarket intake. That would require MAF REscaling especially if it’s CAI
FrickingReallySlow is offline   Reply With Quote
The Following User Says Thank You to FrickingReallySlow For This Useful Post:
Dzmitry (09-08-2021)
Old 10-08-2021, 01:27 PM   #14
LightningCount86
Update: So I found a stock intake, new MAF, new filter, still running rich. Problem is actually getting worse tho, as the car recently starting stalling out when coming to stop coming to stops and also occasionally while moving. Once again any help goes a long way,
check engine, misfire, p0172, rich
Advice on Used BRZ Hunting jello_fello BRZ First-Gen (2012+) — General Topics 24 03-06-2021 03:55 PM
Idle Hunting/Surging Newtothegrounds Issues | Warranty | Recalls / TSB 3 01-23-2018 01:27 AM
Idle Hunting/Surging Newtothegrounds Issues | Warranty | Recalls / TSB 4 01-22-2018 10:36 PM
brz - idle is hunting kravi Issues | Warranty | Recalls / TSB 9 01-17-2016 09:37 PM
Idle hunting on park WishIhad86 Issues | Warranty | Recalls / TSB 7 04-12-2015 01:19 PM
