Old 08-25-2021, 07:02 PM   #2521
ACT86
ACT86's Avatar
Drives: English, French, Swedish & Japanese
Meaty Tire Thread
Hey guys, realise this isn’t the correct thread for this, but I tried the ‘will they fit’ thread with no luck. I thought you guys will be the experts on fitment so I’d give it a shot.
I’m planning to fit the following wheels. I’ve kept it reasonably conservative (for a change) and decided to stick with 8.5s to keep legal / weight down and I like the idea of a square tyre with no stretch.
Front: 18x8.5 ET44
Rear: 18x8.5 ET37
I’ll fit coilovers soon, and from my reading shouldn’t have any issues with stock struts in the interim.
My question: if I decided to run 255/35s instead of 245/35, would I have any clearance issues up front before the coilovers arrive (or after)?
Thanks in advance for your help.
EDIT: I’ve found a few examples on fitment industries with no scrub (both on lowering springs and coils). Think I’ll be ok with the 255s.
ACT86 is offline   Reply With Quote
Old 08-26-2021, 06:30 PM   #2522
APEX Race Parts
FT86Club Official Vendor
APEX Race Parts's Avatar
Drives: Launch-Year Whiteout FR-S
Front: 18x8.5 ET44
Rear: 18x8.5 ET37
Hello! In most cases if running a square fitment, it's nice to have the same offset front and back to allow for front to rear tire rotation to extend tread life. The fitment mentioned likely will work just fine. Most aftermarket coil-overs tend to increase clearance compared to stock as well.
An 18x8.5" ET44 setup front and rear should be a direct with with 245/35-18 or 255/35-18 size tire. If you went with an 18x8.5" ET37 fitment all around, There's may be a need for some additional negative camber with a 255 width tire to prevent rubbing rubbing on the fender, but it would be close.
A 245/35-18 tire would be the better choice imo as an 8.5" wide wheel will be lacking in terms of sidewall support for a 255 tire.
-Ian
APEX Race Parts is offline   Reply With Quote
The Following User Says Thank You to APEX Race Parts For This Useful Post:
gen3v8 (08-26-2021)
Old 08-26-2021, 06:37 PM   #2523
ACT86
ACT86's Avatar
Meaty Tire Thread
-Ian
Thanks heaps for the response Ian, greatly appreciated. I decided to modify the offset ever so slightly front to rear as I really didn’t like the poke at the front / flush at the back or flush at the front and inset at the back look these cars have. I’ve been extremely conservative as I usually go all out to fit the widest wheels I can (within reason). I did consider staggered, but really didn’t want to go down that route.
Yes, 245 was my aim as it’s near identical to stock in rolling diameter, there just seems to be way more tyre choice (at a better price) in 255 weirdly. I also really love the square sidewall on the 255/8.5” examples I have found.
Thanks again for your feedback
The Following User Says Thank You to ACT86 For This Useful Post:
APEX Race Parts (08-26-2021)
Old 08-26-2021, 07:36 PM   #2524
gen3v8
30 minute maintenance
gen3v8's Avatar
Drives: My18 wrxsti
Front: 18x8.5 ET44
Rear: 18x8.5 ET37
I did a fair bit of research and went with 18x9+42. I ordered 255/35 Zestinos coming soon. I`m confident.
The Following 2 Users Say Thank You to gen3v8 For This Useful Post:
ACT86 (08-26-2021), APEX Race Parts (08-26-2021)
Old 08-27-2021, 10:47 AM   #2525
CrowsFeast
CrowsFeast's Avatar
Drives: 2013 BRZ Sport-Tech
You could run a 7 mm spacer to make up the difference between +44 and +37 so you can use the same wheels on all 4 corners. I haven't seen a lot of discussion on it here but it seems that even with 3 mm spacers people suggest extended lugs. (suggested minimum engagement is 12 mm, roughly 9.5 turns.)
CrowsFeast is offline   Reply With Quote
Old 08-27-2021, 10:52 AM   #2526
Vital
Drives: 2015 BRZ
thats not exactly true, people have run 3-5mm spacers with OEM length studs and its not been an issue. Anything higher, yes that will require longer studs.
Old 08-27-2021, 11:51 AM   #2527
churchx
churchx's Avatar
Drives: 2014 GT86
"not been issue" as in they have luckied driven long w/o lugnuts braking off. Still, it's good practice to have sufficient number of threads used for extra ensurance, hence it's normal to suggest not to use too thick of slip-on spacers on non-extended studs.
Old 08-27-2021, 02:55 PM   #2528
max2002
Car Enthusiast
max2002's Avatar
Drives: 2015 FRS
Originally Posted by jflogerzi View Post
You boosted??
nope. just CAI, Unequal header, front pipe, over pipe and q300
IG: @86.Mik
2015 FR-S
Greddy RB Ver.1
max2002 is offline   Reply With Quote
The Following User Says Thank You to max2002 For This Useful Post:
kevaughan (10-07-2021)
Old 08-27-2021, 02:56 PM   #2529
max2002
Car Enthusiast
max2002's Avatar
Drives: 2015 FRS
Originally Posted by Aztec View Post
offset on those wheels? Also are those the toko front fenders?
Just curious of the fitment of the 275 up front
its 18x9.5 -2 and its RB V1 widebody
IG: @86.Mik
2015 FR-S
Greddy RB Ver.1
Old 08-27-2021, 03:32 PM   #2530
CrowsFeast
CrowsFeast's Avatar
That's exactly why I said, "with 3 mm spacers people suggest extended lugs" rather than saying extended lugs were required
Anyway, at 7mm They're probably required.
The Following User Says Thank You to CrowsFeast For This Useful Post:
Vital (08-29-2021)
Old 08-27-2021, 07:09 PM   #2531
ACT86
ACT86's Avatar
Thanks mate. Spacers aren’t legal here and it costs no more to adjust the offset (wheels are custom fitment)
Old 08-27-2021, 09:25 PM   #2532
VIP BRZ
VIP BRZ's Avatar
Drives: 2014 Subaru BRZ
2 cents,
I run 51mm rear spacers on stock studs for years now with 0 issues
VIP BRZ is offline   Reply With Quote
Old 08-30-2021, 03:14 AM   #2533
jflogerzi
jflogerzi's Avatar
Even 5mm is sketchy. 3mm is fine. I have run this at plenty of track events and still have stock lugs.
2013 Series 10 FRS #553
The Following User Says Thank You to jflogerzi For This Useful Post:
gen3v8 (08-30-2021)
Old 08-30-2021, 07:39 PM   #2534
gen3v8
gen3v8's Avatar
Drives: My18 wrxsti
12mm studs need 12mm of thread for the nut.etc etc
Winter Tire Review Thread (Please contribute) pastuch Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 344 03-13-2024 06:49 PM
Wheel Directory: Forgestar F14 18x8.5 +38/18x9.5 +38 ScionFR-S Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 97 09-09-2015 07:32 PM
Meaty rubber on flush spoke rims? red_comet Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 16 06-14-2013 01:21 PM
Official wheel/tire fitment thread needed empower-auto Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 4 06-22-2012 02:40 AM
The Wheel and Tire Fitting Thread EvoFanatic Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 2 03-15-2012 04:05 PM
