Drives: 2020 Subaru BRZ
Porting the heads
Has anyone developed set of cams that will add performance to an engine with ported heads. Although the heads are pretty good, there is plenty of flow to be gained. This is supported by the intake and the exhaust. It seems the valve opening is the limiting factor.
Also, if I install the 1 am larger valves, can I recut the valve seats and throats or will I need to add larger seat stock Thanks |
#2 | |
https://www.counterspacegarage.com/piper-cams-stg3-fa20 You can +1 both sides of the valves, but how you decide to make them fit is dependent on who's doing the headwork for you. Go with their experience. |
#3 | |
Also, do you sell the +1 valves. If so, can you pm me a quote. But I wanted to verify if the block had been line bored or not. Crank is dead on the standard size. Thanks |
#4 | |
#5 | |
Drives: 2018 Subaru BRZ Limited with PP
| The Following User Says Thank You to Dzmitry For This Useful Post: | BrahmaBull1990 (08-25-2021) |
| Used BRZ Heads | pgranberg11 | Engine, Exhaust, Bolt-Ons | 3 | 12-31-2017 03:01 PM |
| porting header | Mike Brz | Engine, Exhaust, Transmission | 0 | 01-25-2015 04:16 AM |
| Heads Up BRZ Available In So Cal | ZmZMWagon | Southern California | 17 | 06-18-2012 03:10 PM |
