Old 08-20-2021, 07:47 AM   #1
pro_turbo
Drives:
Stock oil press
Does anyone here can give me stock idle on normal temp like 90'c coolant.
How many psi or kpa ?
On idle..
800-850rpm
Thanks
pro_turbo is offline   Reply With Quote
Old 08-20-2021, 08:39 AM   #2
Yoshoobaroo
TRACKBREAD
Yoshoobaroo's Avatar
From the manual:
The Following 3 Users Say Thank You to Yoshoobaroo For This Useful Post:
humfrz (08-21-2021), jcw99 (08-23-2021), pro_turbo (08-23-2021)
Old 08-23-2021, 12:49 PM   #3
pro_turbo
Drives:
Originally Posted by Yoshoobaroo View Post
From the manual:
Thanks the best
The Following User Says Thank You to pro_turbo For This Useful Post:
Yoshoobaroo (08-23-2021)
Old 08-24-2021, 06:21 AM   #4
pro_turbo
Drives:
From the manual:
Does this have to tested from that location?
how if I test on the oil filter adapter ? will it be the same ?
Old 08-24-2021, 01:47 PM   #5
Dzmitry
Dzmitry's Avatar
Drives: 2018 Subaru BRZ Limited with PP
I am no expert on this, but I would expect there to be a pressure difference testing it at the oil filter adapter.
Dzmitry is offline   Reply With Quote
Old 08-25-2021, 08:15 AM   #6
pro_turbo
Drives:
Yes finally.. i will install 2 sensor and monitor them tpgether. And i will report back here.
Old 08-27-2021, 09:53 AM   #7
Trueweltall
Trueweltall's Avatar
Drives: 2016 Subaru BRZ
At the oil filter, while at operating temp I see single digits. It'll set off my gauge alarm(5psi) depending what weight and brand of oil I use. The manual is spot on.
Trueweltall is offline   Reply With Quote
The Following User Says Thank You to Trueweltall For This Useful Post:
CSG Mike (08-27-2021)
BRZ in the Press Capt Spaulding BRZ First-Gen (2012+) — General Topics 32 12-17-2017 03:18 AM
Press 6 key question? BadMoon Scion FR-S / Toyota 86 GT86 General Forum 8 09-07-2013 08:35 AM
does anyone else accidentally press the buttons on the key fob while starting car? fiveoneoh Scion FR-S / Toyota 86 GT86 General Forum 19 04-14-2013 11:30 AM
quotes from the press Wheelsoffracing Scion FR-S / Toyota 86 GT86 General Forum 2 07-27-2012 07:12 PM
Official FT-86 II Concept Press Release, Press Photos, Videos Hachiroku Scion FR-S / Toyota 86 GT86 General Forum 126 05-18-2011 02:27 AM
