, dpfarr
Old 08-20-2021, 08:46 AM   #4215
Originally Posted by dpfarr View Post
I bought my kit used and dude fucked up and included stock tb coolant lines. I’ve been searching around on the edelbrock site and there doesn’t seem a clear option to buy new lines.
Anyone ever have to do this or have luck with similar unlucky circumstances?
Have you tried calling Edelbrock directly to see if they will sell you the parts? I'm relatively confident they keep spare parts around....
CSG Mike (08-20-2021)
Old 08-20-2021, 02:57 PM   #4216
dpfarr
Drives: BRZ ts
1 hour into being on hold...
dpfarr is offline   Reply With Quote
The Following User Says Thank You to dpfarr For This Useful Post:
Dadhawk (08-20-2021)
Old 08-23-2021, 12:49 PM   #4217
BrahmaBull1990
Howdy
BrahmaBull1990's Avatar
Drives: 2020 BRZ PP
I may get flamed for this, but I do not really like the UEL header sound. The engine sounds like it's burping and like a P51 Mustang. The racer noise (Honda) of the EL header is more appealing to me, personally. I currently have a Tomei UEL header (catless - if they even sell a catted one), which I will be selling.
1:Which EL would be best to pair with the Edelbrock; Ptuning, JDL, or Tomei?
2: I just got off the phone with my tuner and he said headers are odd and I may or may not need a retune going from UEL to EL. What do you all suggest? I am leaning towards just getting it retuned. @CSG Mike Do you have any good EL headers? I see JDL on your site, but the price is $0..so maybe an inventory thing.
There's a point at 7,000 RPM... where everything fades. The machine becomes weightless. Just disappears. And all that's left is a body moving through space and time. 7,000 RPM. That's where you meet it. You feel it coming. It creeps up on you, close in your ear. Asks you a question. The only question that matters. Who are you?
BrahmaBull1990 is offline   Reply With Quote
Old 08-23-2021, 02:54 PM   #4218
Chris3007
Drives: 2013 BRZ Limited 6MT
Edelbrock typically sends you to https://superchargersonline.com/ for replacement parts. I have oredered through them a few times and they have been very helpful/
Chris3007 is offline   Reply With Quote
The Following User Says Thank You to Chris3007 For This Useful Post:
dpfarr (08-23-2021)
Old 08-23-2021, 07:29 PM   #4219
Q8D
Drives: N/A
Jegs carries most if not all the replacement parts (based on the Edelbrock Part Numbers in their instructions). You can also contact Summit Racing. They should be able to provide you with replacement parts since they carry everything Edelbrock.
Q8D is offline   Reply With Quote
Old 08-24-2021, 03:00 AM   #4220
CSG Mike
CSG Mike's Avatar
JDL or Ace.
Available by request only. PM to order.
BrahmaBull1990 (08-24-2021)
Old 08-24-2021, 11:22 AM   #4221
brandonblt2
The Stig's African Cousin
brandonblt2's Avatar
Drives: 2014 wrb brz
Anyone else tuned with Delicious that has catless headers? Is it normal to have the CEL blink a few times after a reset? I believe the tune is suppressing the P0172 - System too Rich Bank 1. I continuously have this code pop up no matter what after the car warms up. I replaced my fuel pump thinking it was related to that but now I'm leaning towards O2 sensor, possible gasket leak near the headers, or the tune itself.
Instagram: brandonblt2
Build Thread: http://www.ft86club.com/forums/showt...86#post2219386
Flickr: brandonblt567
brandonblt2 is offline   Reply With Quote
Old 08-24-2021, 11:31 AM   #4222
Pgh_Area
Pgh_Area's Avatar
Drives: '14 Ultramarine Fr-S
How's your injectors? Any chance the ones in bank one are sticking?
Pgh_Area is offline   Reply With Quote
The Following User Says Thank You to Pgh_Area For This Useful Post:
brandonblt2 (08-24-2021)
Old 08-24-2021, 11:48 AM   #4223
BrahmaBull1990
Howdy
Drives: 2020 BRZ PP
I had two consistent CEL with DT on a car with 5k miles. P0507 -idle air RPM higher than expected and P105A - 02 Sensor Delayed Response Rich to Lean Bank 1 Sensor 1
After two revisions, they never went away for more than a week. I was told some care are just finicky?
When I had my Edelbrock installed, I had them tune it in-person with the Dynapack and I have not had a CEL since.
The Following User Says Thank You to BrahmaBull1990 For This Useful Post:
Old 08-24-2021, 01:11 PM   #4224
B T
Drives: 15 BRZ, 2003 MR2, '70 Elky, 06 TBSS
Catless here, no CEL. It could be the O2 sensor, but I don't think it would say it was rich if it was a leak after leaving the head. It's putting in more fuel than is required for the air reaching the cylinder. Are you sure the supercharger has a good seal on the heads?
B T is online now   Reply With Quote
The Following User Says Thank You to B T For This Useful Post:
Old 08-24-2021, 01:21 PM   #4225
brandonblt2
I replaced the injectors about 10k miles ago so they should be good. I also put a bottle of injector cleaner in my gas tank. I'll pop them off and do a visual check and bench clean this weekend tho.
Old 08-24-2021, 01:38 PM   #4226
brandonblt2
Hmm, I did the install myself so I'm pretty sure gasket was in place when I bolted the Supercharger down. I also hose clamped every vacuum line just to make sure I have no leaks.
This is why I'm not sure if its the tune or not. I was stage 2 for the longest time on OFT without any issues without the CEL popping up. But then again DT Tune ran fine after I replaced OEM injectors until recently.
Anyone know how to test if an O2 sensor is going? I'm at 175k miles most of those catless so I wouldn't be surprised if the sensor is starting to go. Power loss and seems pretty intermittent.
Old 08-24-2021, 02:46 PM   #4227
CSG Mike
CSG Mike's Avatar
You tuner can make an educated guess base don logs, but at 175k, it's definitely time to replace it.
Old 08-24-2021, 02:56 PM   #4228
BrahmaBull1990
Howdy
Drives: 2020 BRZ PP
Wow! 175k; how many boosted miles?
Vortech Owner Thread & Setup Questions reyruiz191 Forced Induction 340 05-17-2022 01:44 PM
Edelbrock E-Force Supercharger itsibarra Forced Induction 938 07-31-2021 05:48 PM
Most annoyingly over-asked questions on FT86 forums mit_peid Off-Topic Lounge [WARNING: NO POLITICS] 36 01-16-2014 03:48 PM
Brz Info/Specs (helpful info for questions asked often) Gaen BRZ First-Gen (2012+) — General Topics 0 05-24-2012 11:09 PM
