Old 08-22-2021, 09:04 AM   #295
RZNT4R
Professional Mechanic
Drives: 2017 86 6MT Oceanic
Originally Posted by Yoshoobaroo View Post
and in the past ~5 years most are actually going back to conventional automatics since they have gotten so fast
That is... exactly my point. A fast and smooth AT is fine, no need for fancy doohickeys.
I referenced the SMG because as it's still technically a manual, there are bound to be some who'd justify that choice with a "bububut motorsport!" argument, while in real life in a road car, an SMG or as you said, even a DCT does't even have a clear advantage over an AT.
But I'll tell you what though, for all their failings, I still like the feel of the SMG-II in the E46 M3 and E85 Z4, there's a "chill-ness" to it driving around slow in the softest mode. The damn thing tries so hard to be smooth it starts in 2nd :lol
The Following User Says Thank You to RZNT4R For This Useful Post:
Yoshoobaroo (08-22-2021)
Old 08-22-2021, 09:21 AM   #296
StE92ve
StE92ve's Avatar
Drives: 2014 Mazda CX-5
Originally Posted by timurrrr View Post
But some autos are pretty good indeed, and some are quicker than manual for performance driving.
For whatever reason, I need to go auto with my GR86. What I'd really like to hear is some real world non-track reviews of the Gen2 AT. This car will never feel the asphalt of a track (maybe if I take up the free track day that Toyota is offering and I'm within 3 hours of Lime Rock so that's a possibility) but I want to know how much fun I'll be losing, if any, while doing some spirited driving on local roadways with the AT vs the manual.
StE92ve is offline   Reply With Quote
Old 08-22-2021, 09:29 AM   #297
Blighty
Drives: WR Blue Pearl 2022 Subaru BRZ
The auto in the GR86 is quite an old style one, that essentially uses liquid to engage the gears (imagine a water wheel - kind of), what that means is that there is always a bit of a lag because the transfer of liquid and build up of torque is slow.
There is a great variation in how good/bad these type of autos are. The GR86 has a really good one, so its not to 'slushy' or 'laggy', and the electronics are really quite good at doing the right thing on the track - which is NOT easy for a car with comparable (to sports cars) low power. High performance cars might have worse electronics but you wouldn't know because they just have so much power in all the gears.
DSG and the other things are essentially like robotics made to change gears using a clutch - they can generally always beat a human because they cheat, and are not limited to working with just one clutch
Neither as as quick and not _quite_ the brutal engagement of a dog box on a sequential manual though - they will always be faster, but they are really track and racing only.
Auto or not, this is the ultimate drivers car (within reason) - your still rear wheel drive and still running on this magnificent low and tight platform.
One thing about auto's though - dont stick to the book for changing your automatics transmission oil. Unlike a manual, they a FUCKING EXPENSIVE to fix, and while transmission oil isn't cheap, do not hesitate to get it replaced at half the interval it says for you to to. These older autos will last forever if you just keep replacing the oil fairly regularly.
Blighty is offline   Reply With Quote
The Following 2 Users Say Thank You to Blighty For This Useful Post:
StE92ve (08-22-2021), Yoshoobaroo (08-22-2021)
Old 08-22-2021, 10:07 AM   #298
Blighty
I wonder if they have done the BRZ drives yet?
Everyone was saying it was 2 weeks away at the GR86 day, and that was like the 8th or 9th.
Its exactly two weeks now!
The Following User Says Thank You to Blighty For This Useful Post:
Old 08-22-2021, 10:35 AM   #299
Yoshoobaroo
TRACKBREAD
Yoshoobaroo's Avatar
This cannot be overstated. I helped a friend troubleshoot a 90s ZF box in a BMW. 200,000 miles on the original fluid. It was dropping shifts and tried to engage REVERSE at the same time as 5th gear. We flushed the fluid and replaced the filter, and then again after a few hundred miles. Ran like a champ after that.
The Following 2 Users Say Thank You to Yoshoobaroo For This Useful Post:
Blighty (08-22-2021), StE92ve (08-22-2021)
Old 08-22-2021, 11:31 AM   #300
Ernest72
Except some autos actually suck
Even in the last ~10 years, there were a bunch of cars where a manual was way quicker than the same car with auto.
Sure some autos suck, and some MTs suck too.
Old 08-22-2021, 11:44 AM   #301
RZNT4R
One thing people don't consider is, you can't really empty an automatic transmission of all it's oil without taking it apart and replacing the torque converter or unplugging the oil cooler lines and using massive quantities of new oil to push out the old oil until it runs clean (unless it's a mercedes with a drain plug on the converter, those are cool).
It's not uncommon for the oil pan to hold about half of the oil capacity, so they are quite right: A pan drop & fill at half interval will be the easiest way to keep all of the oil fresh and new enough at all times.
Old 08-22-2021, 11:59 AM   #302
StE92ve
StE92ve's Avatar
I don't know Martin Padgett but this is what he says about the auto in the GR86:
https://www.motorauthority.com/news/...ew-photos-info
"I’m better with the automatic—everyone and anyone would be, and should be—as I slap it sideways into its manual-shift mode, and point and shoot through corners. The brakes help calm the few ripples in the 86’s eager demeanor; they’re not particularly numb or sharp, but they brush off speed efficiently and settle the car into long sweepers.
The automatic doesn’t like to let the engine reach full bore, and when you try to hit redline it rings and dings and denies the shift. Still, it’s best kept in manual mode and flipped through the gear range with paddles,
Buy the automatic if you intend to drive the GR86 mostly on open roads, if only for the safety gear it gets that manual cars do not (automatic emergency braking, for starters). It’s fine, but switching back into a Premium car with the 6-speed manual and 215/40R18 Michelin Pilot Sport 4 tires reveals the car Toyota engineers want everyone to track, every weekend. It has the extra grip that encourages deep and late braking. That builds confidence, and though my feet still klutz it up once or twice, the training wheels eventually bring me to a smooth-shifting, single-lap Monticello blitz before it’s all done. It’s really good as an automatic; as a manual, the GR86 is the senior-year achievement test that places you in graduate school (Supra, and higher)."
The Following 2 Users Say Thank You to StE92ve For This Useful Post:
Blighty (08-22-2021), Dadhawk (08-22-2021)
Old 08-22-2021, 12:23 PM   #303
Yoshoobaroo
TRACKBREAD
What a weird take. Picking a transmission has nothing to do with where you plan on driving it. Street or track doesn’t matter. Get the auto if you want the auto, get the manual if you want the manual. It’s that simple.
soundman98 (08-23-2021), spike021 (08-22-2021)
Old 08-22-2021, 12:46 PM   #304
Spuds
The Dictater
Spuds's Avatar
Drives: '13 Red Scion FRS
That's a strange way of saying "Just get the auto if you can't drive stick".
The Following 3 Users Say Thank You to Spuds For This Useful Post:
spike021 (08-22-2021), timurrrr (08-22-2021), Yoshoobaroo (08-22-2021)
Old 08-22-2021, 04:15 PM   #305
DocHolidayXR
Guest
Posts: n/a
There's no excuse good enough for going automatic in an 86. Unless you are impaired and physically cannot drive one lol. It doesn't need Rev matching either. That's not fitting with the ethos of the car. And definitely not purity imo.
Old 08-22-2021, 04:27 PM   #306
Well the good news is the buyer doesn't need an "excuse" of any type to choose it if they want it, so there is that.
If I were buying a 2022 86, which I'm not for reasons I've stated, I would consider the MT this time, but only because they didn't add the one thing the AT needed, launch control. However, I do not regret a single one of the 190,000+ miles I've put on my AT FRS. Having a manual would have added nothing to the experience.
The Following 6 Users Say Thank You to Dadhawk For This Useful Post:
Blighty (08-22-2021), Ernest72 (08-22-2021), humfrz (08-23-2021), soundman98 (08-22-2021), StE92ve (08-22-2021), Yoshoobaroo (08-22-2021)
Old 08-22-2021, 04:46 PM   #307
DocHolidayXR
Guest
Posts: n/a
Then good for you. I would cry it I had to have an automatic and simply sould not want it. Again, imo, no reason good enough. Bunch of rationalizations but not valid. Again, imo. And i am buying one. Because I'm a purist and truly know how to drive ��
Old 08-22-2021, 04:55 PM   #308
soundman98
ProCrastinationConsultant
soundman98's Avatar
i'm still pissed that they removed the manual spark advance from the concept!
The Following 4 Users Say Thank You to soundman98 For This Useful Post:
Dadhawk (08-22-2021), humfrz (08-23-2021), LimitedSlip (08-22-2021), NoHaveMSG (08-22-2021)
GR86 In R7 of the Toyota Gazoo Racing GT Cup + GR86 coming to Grand Turismo Sport Blighty GR86 General Topics (2nd Gen 2022+ Toyota 86) 28 07-18-2021 03:38 PM
Real World MPG Be-Are-Zee BRZ First-Gen (2012+) — General Topics 302 07-13-2014 03:06 PM
Full Report: Road & Track tests stickier FR-S/BRZ tires poormans_LFA Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 74 08-15-2013 01:10 AM
