Old 08-18-2021, 09:43 AM   #169
Trueweltall
Trueweltall's Avatar
Drives: 2016 Subaru BRZ
Originally Posted by Blighty View Post
I mean I think all these reviews also say something else.
They are effectively reviewing the 86/BRZ 1st gen with headers, e85 and a tune.
I think its fair to say that the proper amount of torque and power they are talking about is just as readily apparent for all those who would of upgraded their cars.
In the Throttle House video it seems that good tires would make up the difference on the track considering a 1G had a better time. The camera man has an FRS and ran a "low 1:15" compared to the 1:15.90 of the 2G. I would have liked to see them do a drag race between the two.
Trueweltall is offline   Reply With Quote
Old 08-18-2021, 09:55 AM   #170
ayau
Drives: Some rust bucket
really comparing apples to oranges.
i would like to see lap times from pobst in showroom spec (factory tires) on a real race track. i'm not a fan of trying to equalize the cars with the same tire spec.
Old 08-18-2021, 10:21 AM   #171
RZNT4R
Professional Mechanic
Drives: 2017 86 6MT Oceanic
Originally Posted by Yoshoobaroo View Post
IIRC correctly it was specifically mentioned in the Japanese comparison thread that the rear subframe was less tight to the body to encourage toe-out under compression. The toe arms are mounted to the subframe so letting the subframe rotate around the Z axis could provide a similar effect without having to make different toe arm assemblies for the Toyota.
I’m so curious to see the front suspension of those cars they had.
all the arms are mounted to the subframe, so letting it moves provides zero change in suspention geometry, just where the suspention is under the car. the thrust axis would move around, but not geometry under load.
Old 08-18-2021, 10:26 AM   #172
Pete
Pete's Avatar
Drives: 22 BRZ
Originally Posted by RZNT4R View Post
Toe change will be done with control arm bushings, not subframe mounting and swaybar. since the final subframe has extra tabs on it, it's safe to assume this is an off the line brz subframe
I am now more confused than ever. How hard is it for the manufacturers to simply tell you what they are selling?
Thanks to Paul at TFL for getting the info.
2013 FRS -> 2011 CTS-V -> 2006 Cayman S -> 2015 GTI -> 2022 BRZ
Pete is offline   Reply With Quote
Old 08-18-2021, 10:29 AM   #173
DarkSunrise
DarkSunrise's Avatar
Originally Posted by NARFALICIOUS View Post
The only 2 I've watched so far, SavageGeese and That dude in Blue did say the new car is faster and "fixed" the first gen's issues. They quoted 6 and 6.1 seconds 0-60.
However, after some googling, the 2013 FR-S runs 0-60 in 6.2 according to many tests.
Has anyone tested the 1/4 mile?
Btw, please don't start a MK1 MK2 trend.
I think it should either be ZN6 vs ZN8,
or FT86 (FR-S/BRZ/GT86/86) vs GR86 (GR86/BRZ) Edit... Wait that doesn't work.
Toyota quoted something like 7.3 seconds for the old one. Magazine tests got that down to around 6.2 seconds with an aggressive launch.
Toyota is quoting 6.1 seconds for this new one. Magazines should be able to get that down to the mid 5’s or better with a similarly aggressive launch. Jason Camissa has already said he’s done an “easy” 5.6 seconds with the new one.
2022 BRZ Build
2013 FR-S Build
The Following 2 Users Say Thank You to DarkSunrise For This Useful Post:
Dadhawk (08-18-2021), timurrrr (08-18-2021)
Old 08-18-2021, 11:00 AM   #174
Yoshoobaroo
TRACKBREAD
Yoshoobaroo's Avatar
GR86 first drive reviews thread
Fair, the geometry doesn’t technically change, it’s the thrust axis. It can provide a similar corner entry effect though, provoking the car to step out.
That’s really strange. Is Toyota reverting this change or are these preproduction versions that different from final spec?
Seems a bit misleading if they’re planning to change it still, since the sway bar mounting and subframe bushings determine the toe out on compression that they wanted to create, to mimic the Supra suspension behaviour. That’s been pretty controversial on the Supra.
GR86:
GR86 at us press event:
BRZ:
Edit: Just had a thought. The BRZ seems to be significantly ahead of the Toyota in the release schedule, The BRZ must be finalized by now. Could these be early production BRZs that were modified to match the toyota spec and cosmetics *but not 100%*? Some parts like the new subframe may not be ready, so the BRZ version was used. Do any of the videos from yesterday show the front knuckle? I haven’t seen any.
Edit2: this could explain the absence of a Neptune car at the event too.
Follow up:
I did a quick scrub on YouTube and managed to find a shot where the top of the front knuckle peeks above the brake disc. It was confirmed further in the thread these are aluminum.
Brz knuckle for reference:
The Following 3 Users Say Thank You to Yoshoobaroo For This Useful Post:
Bobharp (08-18-2021), dragoontwo (08-18-2021), Pete (08-18-2021)
Old 08-18-2021, 11:53 AM   #175
Blighty
Drives: WR Blue Pearl 2022 Subaru BRZ
I just don't see any way is a stock 86 beating a stock gr86.
I think that what the journalists said was the upgrade was pretty clear. They drove them back to back (the TRD updated version too).
Blighty is offline   Reply With Quote
The Following User Says Thank You to Blighty For This Useful Post:
Old 08-18-2021, 11:58 AM   #176
fitcious
Originally Posted by AnalogMan View Post
Of course this is an enthusiast's forum so we're all feverish with passion about the new BRZ/86, but it's great to see such interest and excitement over a new sports car. It's a dying segment and these may be the last days for sports cars in general, as we trudge forward into the soulless, bland, anodyne electric car and autonomous dystopian future.
We're very lucky that both the BRZ/86, and the new Nissan Z, are being introduced. It might be 'last call' for these kinds of cars. Let's enjoy them while they're here. Once they're gone, they won't be back.
Also the new integra coming out!
fitcious is offline   Reply With Quote
Old 08-18-2021, 12:00 PM   #177
RZNT4R
All of this strangeness and we dont even know what size swaybars those cars were running!
The Following 2 Users Say Thank You to RZNT4R For This Useful Post:
Pete (08-18-2021), Yoshoobaroo (08-18-2021)
Old 08-18-2021, 12:36 PM   #178
mazeroni
Drives: 2013 Scion FR-S Series 10
Saved?
Matt Farah found his footage, I guess.
mazeroni is offline   Reply With Quote
The Following 3 Users Say Thank You to mazeroni For This Useful Post:
Lonewolf (08-18-2021), Pete (08-18-2021), spike021 (08-18-2021)
Old 08-18-2021, 12:51 PM   #179
timurrrr
timurrrr's Avatar
Drives: 2022 GR86
Tires affect the lap times more than almost anything else.
Almost nobody does time trials on stock tires, and only "spec" classes designed to be beginner friendly run 215s.
Why should results of performance tests depend on what comes from the factory? What if I buy a car in winter and it comes on winter tires?
Old 08-18-2021, 12:53 PM   #180
timurrrr
timurrrr's Avatar
Drives: 2022 GR86
On our cars, the tires only really matter for the first few feet of a drag race. In the TH video, the 2nd gen was clearly pulling away more and more as the speed increased.
Old 08-18-2021, 12:58 PM   #181
ayau
i get that tires impact lap times the most, but the modifications can be endless.
but i still prefer to see lap times with 0 modifications/straight in showroom spec. the data is too messy when you start modifying the car.
Old 08-18-2021, 01:14 PM   #182
timurrrr
timurrrr's Avatar
Drives: 2022 GR86
Just compare all cars on the same tires, problem solved.
Now, that's expensive for the reviewers 😕
GR86 In R7 of the Toyota Gazoo Racing GT Cup + GR86 coming to Grand Turismo Sport Blighty GR86 General Topics (2nd Gen 2022+ Toyota 86) 28 07-18-2021 03:38 PM
Real World MPG Be-Are-Zee BRZ First-Gen (2012+) — General Topics 302 07-13-2014 03:06 PM
Full Report: Road & Track tests stickier FR-S/BRZ tires poormans_LFA Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 74 08-15-2013 01:10 AM
