Old 08-13-2021, 11:19 PM   #1
jjswamp
Drives: scion frs 2013
Exclamation rebuild 2013 scion fr-s engine still knocking?
Please help >.<
I have had my engine rebuilt by changing the short block due to the infamous issue with these engines going bad. Just like many other frs/brz 2013/14 owners, after i got my car back from the engine valve spring recall it went bad. For mines, since i baby it too much i barely drove it, and the problem came after 1year. It had a rod knock. I had second/third/fourth/ opinions with the diagnose and they all said the same. And then, I had it fixed by replacing the short block. Now my question is with this video Im going to attach. Do i still have a knock?
please watch the whole 28 seconds as i move the phone around.
jjswamp is offline   Reply With Quote
The Following 2 Users Say Thank You to jjswamp For This Useful Post:
humfrz (08-14-2021), theneptune86 (08-16-2021)
Old 08-14-2021, 12:26 AM   #2
Originally Posted by jjswamp View Post
Please help >.<
Well, jjswamp, welcome to ye ol forum. Sounds like you have had some nasty luck with your car -
A few questions:
How many miles on the new block?
Do you have any power mods?
Have you tracked the car with this engine?
To me, it doesn't sound like a rod knocking, it sounds more like a valve tappet out of spec.
Others will chime in soon.
Good luck.
Old 08-14-2021, 02:33 AM   #3
Yo, @Ultramaroon - this fellow @jjswamp , needs some help. What do you hear?
He says the block has about 10,000 miles on it; he hasn't tracked it; no power mods.
Others?
Where is everybody? -
Ultramaroon (08-14-2021), YamahaR86 (08-17-2021)
Old 08-14-2021, 04:00 AM   #4
Ooo... That's bad. I agree with you, @humfrz. That's a valve. Bent?
humfrz (08-14-2021), YamahaR86 (08-17-2021)
Old 08-14-2021, 05:05 AM   #5
bobel
Drives: GT86
Would be inclined to agree, I don’t think it’s rod knock, sounds more like the valve train, I would not be surprised if your valves are out of tolerance, having built the valve train on an FA20 it’s a time consuming meticulous job and “close enough” is not good enough. Either way I think your going to have to strip the heads to find your problem, and hopefully it’s not a bent valve.
bobel is offline   Reply With Quote
The Following 4 Users Say Thank You to bobel For This Useful Post:
humfrz (08-14-2021), soundman98 (08-14-2021), Ultramaroon (08-14-2021), YamahaR86 (08-17-2021)
Old 08-14-2021, 04:19 PM   #6
I agree. If it has sounded like that since the first startup, it just needs properly shimmed.
Please delete, thank you. b3nko Cars for Sale/Trade 4 08-02-2021 04:33 PM
2013 with JR C30 Engine Rebuild must dos? RallyKeith Forced Induction 1 04-26-2021 02:22 PM
SOLVED: Is this 2013 Scion FRS Engine Knocking/Tapping normal? N1rve Issues | Warranty | Recalls / TSB 215 08-24-2019 02:04 PM
2013 scion frs engine scion123 Engine, Exhaust, Bolt-Ons 16 10-13-2014 09:03 PM
